Question about Epson Stylus Pro 7600 InkJet Printer
Epson Pro 7600 Service required error
Hi, my Epson Pro 7600 shows Service required error and flashing with all lights so I cannot print... How I can fix this problem ?
  • 4 more comments
  • alan1957 Aug 21, 2008
    I have an Epson Pro 7600 it has stopped working with service 101 on the printer screen how do I override this problem
  • cgibelize Nov 12, 2008
    paper, maintenanace and ink lights are flashing red
    all the others are flashing green
    it gives me service required 0001001B
  • Jadine Johnson Nov 18, 2008
    Aloha, my epson 7600 has a service required error message 00010000C. Any idea on how to fix this w/o calling a service tech?
    Aloha! I have an epson 7600 with a service req 00010000C error code. Any idea on how to fix this w/o calling a tech? I called tch support and tried moving the print head and unplugging the printer but the message is still there and they said I need to call a tch out which will cost $$$$. Look foward to a reply. Thanks!
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 11, 2010
    Do you see an error code as well? like 00010005 or 00010006?
  • prakash Oct 08, 2013
    it gine me service required A0000160
I have a Epson pro 7600 and i am getting a error code.
-00010005
It has something to do with the printhead..
Does anybody know how to fix this myself or if this is possible
Posted on Sep 04, 2009
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Posted on Nov 21, 2008
  • trytobluff Feb 03, 2009
    Paper source + eject + paper feed are the buttons actually
    New Friend:
Epson printer stylus pro 7880 in problem error in A0000170 so in solutions
Posted on Oct 08, 2013
How do your replace the cutter blades on the Epson 7600 Printer
Posted on Feb 16, 2009
    Genius:
  • 1,447 Answers
If you are getting that error try this
Check to make sure the locking bracket and screw have been removed from the print head.
Turn off the printer.
Open the lower cover on the front of the printer and remove the bracket and screw holding the print head in place.
Close the printer cover and turn on the printer.
The Pause light, begins flashing and the printer starts charging the ink delivery system.
If a different error then update me, thanks!!
Posted on Apr 17, 2008
2 Suggested Answers
aicaxz
  • 511 Answers
SOURCE: Epson Pro 7600 Service required error
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
Posted on May 30, 2009
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
I have an Epson 7600 that I just purchased on EBay. I tested it when I picked it up and it worked fine. When I try to print from home I get a "Command Error" and all the ink lights flash red.
In addition to searching for the Model number of your printer, try adding the P/N (part number) which is usually found on the bottom of the printer. I have found that some models of printers can have different drivers especially when they have been manufactured a couple of years apart. When I searched for your printers driver, I came up with a file very similar to yours except that it was called epson12167.exe. Here is the link to that file. I hope it makes the difference:
Epson Stylus Pro 7600 Print Engine with UltraChrome Ink
Oct 19, 2014 | Epson Stylus CX6600 All-In-One InkJet...
Epson 7600 all lights flashing red and reads command error
Could be you are using the wrong printer driver or damaged data was send to your printer.
Check page from 166 of the manual.
link to manual:
http://files.support.epson.com/pdf/pro76u/pro76uu1.pdf
Oct 25, 2013 | Epson Stylus Pro 4800 Color Photo Printer...
Using a Epson 7600. I send the job to the
1. The CR Encoder and the T Fence must be free from dust and dirt or any other
foreign matters.
2. The CR Timing Belt must be free from any defects and the belt must be in
proper tension.
3. The carriage must slide smoothly, free from undue load.
4. Measure the resistance value of the CR Motor. (5.8Ω)
5. Execute encoder checking by “Encoder ” in the selfdiagnostics
menu.
6. All the harness must be connected properly and free from short circuit or
broken wire.
Jan 07, 2010 | Epson Stylus Pro 7600 InkJet Printer
My printer prints well, but with a displayed problem
This indicates that the Pump motor operation count has reached its limit. The remedy is to Perform Maintenance Mode 2 [CLEAR COUNTERS / CLEANER]
Sep 21, 2009 | Epson Stylus Pro 7600 InkJet Printer
May 27, 2009 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
5,192 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
