Question about Fedders A6Y12F2B Y Chassis Room Air Conditioner w/ 12,000 Cooling BTUs & Electronic Controls
Can't change temp on Fedders ac #a6y12f2a-m
The ac comes on at 75 degrees and the buttons won't allow it to go down any. The buttons "click" when I push them but the digital # stays at 75 and no change in the physical temp either. Anybody know??
  • 4 Answers
SOURCE: Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Posted on Dec 29, 2007
TheMobilian
  • 8220 Answers
SOURCE: model A6T12F2A. digital control panel is stuck on
More than likely you is gonna have to replace the control.Sometimes getting a wash rag real hot and going over the buttons will help unstick them.
Posted on Jun 25, 2009
  • 233 Answers
SOURCE: I have a fedders ac unit that has temp settings.
you can get a manual analog dial thermostat, atan appliance store and substitute it for the current stat, some boards also have installer settings that you can reset the limits, (I would try that first) there also are some that have dip switches that can be set to override, the issue with the last two would be finding an installers set-up manual, as I said I would search for that before I tried any non factory components
Posted on Jul 16, 2009
mikeangie304
  • 15 Answers
SOURCE: Our thermostat is set at hold with the fan on
it is ok to run your fan continously. constant air filtering as long as it pauses before a/c cycles on. will not use any more electricity than a toaster. is there a fan programing feature on t-stat. if so you will need to turn programing to fan off
Posted on Aug 20, 2009
gear001
  • 59 Answers
SOURCE: anybody there?
It depends on the room varables, If it has an attic, tile ceiling, what type of walls, where in the building is the room and so on? The biggest problems is all ways the power. Get a free estaimate from an A/C company. Everyone and myself needs to see the room before they give you an recomndation that can truly be applyed to your situation. But to give you some ideas, I would put a 2.5 ton - 3 ton unit just for over kill. Go with a straight cool package unit. If your company tight on cash just get a mini split system with a 30,000 BTU to 36,000 BTU cooling capacity. Cost for something thats going to last 20 years, avg. is $4,500- for the package unit and as low as $3,000 for the mini split.
Posted on Oct 18, 2009
How do i add freon to my fredders service # a6y12f2a-a
Hello, wimdow air conditioners do not come with service acsess fittings, so you must add a piercing valve to the unit to add refrigerant.
Jul 16, 2012 | Fedders AEQ07FBG Air Conditioner
Fedders Air conditioner
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
Jun 07, 2008 | Fedders A6P09S2A Air Conditioner
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
Where to connect three wires
You should have:
one wire from the compressor that will hook to "HERM".
one wire from the fan motor that will hook to "FAN"
one wire from the relay ("hot" wire") will hook to "C".
Apr 14, 2010 | Fedders Y Chassis A6Y12F2A Air Conditioner
I have a fedders ac unit that has temp settings. I was wondering if there is some way to override the 66 degree setting to make it run cooler to make the room colder. (like the older styles...down to 50...
Jul 15, 2009 | Fedders Appliance Air Conditioner Wall
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
The numbers it is showing for the temp.
It is showing degrees Celsius instead of Fahrenheit. Push both the up and down temp buttons at the same time to toggle between C and F.
Jun 02, 2008 | Fedders AEY08F2FCOM Wall/Window Air...
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Fedders A6Y12F2B Y Chassis Room Air Conditioner w/ 12,000 Cooling BTUs & Electronic Controls Logo
87 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
