Question about Nordic Track NordicTrack Elite zi Treadmill
My nordictrack exp 1000 incline stop working - Nordic Track NordicTrack Elite zi Treadmill
  • 64 Answers
SOURCE: nordictrack treadmill will not close
Check elevation position.
Posted on Jun 08, 2009
FrogCatcher
SOURCE: NordicTrack Exp 1000...stops after 40-55 minutes
My EXP000 is doing the same thing. But it is doing it when it is cold also.
http://sites.google.com/site/antiquebriggsandstratton/
Posted on Nov 18, 2009
maxtreadmill
  • 832 Answers
SOURCE: My treadmill is stuck in the max incline position
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Jun 11, 2010
2manyhobbies
  • 127 Answers
SOURCE: I have the EXP 2000 NordicTrack incline treadmill
Manuals can be downloaded at http://www.iconservice.com/CustomerService/manuals
First perform an incline calibration.
Insert the safety key/magnet. Press the incline up button. While the numbers are changing, remove the key. Release the incline up button and reinsert the key/magnet. The machine should go to the top and then back to the bottom.
If it only starts then stops, the incline sensor may be defective. Be sure all the plugs are secure on the controller board.
If the sensor is defective, you will need to order a new incline motor..
If the incline motor does not move at all, the controller may be defective..
Posted on Dec 15, 2010
SOURCE: My NordicTrack EXP 1000 stops in the middle of a
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Posted on Jan 23, 2011
How do i turn on a nordictrack treadmill exp 1000 x
they have a small switch Red in lower part to the side to the power cord.
see you instruction manual, or download free www. iconservice.com
God bless you
Jun 17, 2012 | Nordic Track Nordictrack Exp 1000...
I need a mannual for my nordictrack exp 10000 xI. Can you help?
Here is a list of many different versions of the NordicTrack Exp 1000XI. If you know your exact model number you can click on your version and view a parts list and purchase an owner's manual. If you just need to look at a diagram of all the parts many of the equipment pages have that available to view for free. Hope that helps.
Sep 12, 2011 | Nordic Track Nordictrack Exp 1000...
My exp 1000 sudenly stops , the counters reset to 0 all the lights are on but the control pannel is nonresponsive an error code 07 showed up once. Any ideas?
I don't have any suggestions for fixing it but I wanted to give you a resource should you need to purchase a new motor control board, you can choose your specific model and browse parts list here. Hopefully you can get it to work though, depending on the model it looks like a replacement can run you $100-$200.
Feb 21, 2011 | Nordic Track Nordictrack Exp 1000...
I have a norditrack exp 1000x, on the lower part,of the control panel,the functions,have stopped working.but the upper function keys are ok.what do think is wrong.?
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
Aug 11, 2010 | Nordic Track Nordictrack Exp 1000...
How do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
Aug 01, 2010 | Nordic Track Nordictrack Exp 1000...
Jun 11, 2010 | Nordic Track Exercise & Fitness
I have a NordicTrack EXP 1000 X. Just bought it froma guy on craigslist, and it was working fine at his house. Messed with the belt tensioner bolts a bit when I brought it home, and now when I walk/run on...
It sounds like the belt is bogging down, this condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
The only certain way to test for a worn walking belt is to take a DC amp draw . Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test.
The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
May 23, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
  • For questions about parts, service, user's manuals or non-working products, please call our NordicTrack Customer Service Department at 1-877-993-7999.
  • For questions about parts, service, user's manuals or non-working products, if you purchased your equipment at Sears, please call our NordicTrack Sears Customer Service Department at 1-888-825-2588.
Apr 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Elite zi Treadmill Logo
143 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
