Question about Tecumseh Enduro Vertical Engine 16 HP 1in x 3 532in Shaft Model OHV16204230F
Tecumseh 16 hp ohv adjustment
Hi I have a Tecumseh 16 hp ohv and need the valve adjustment specs
  • 760 Answers
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
Posted on Jul 04, 2010
20hp Tecumseh ohv ajustment
I have found a video that should be very similar to adjust the 20hp engine. Need to know the specs for clearance too.
https://www.youtube.com/watch?v=CSZ_gYUDUwA
Jul 07, 2015 | Mtd Garden
What is the valve clearance on a 13.5 hp Tecumseh ohv 130 motor?
Set the intake and exhaust both at .004. This should get you running smooth. GOOD LUCK FRIEND.
Jun 06, 2015 | Tecumseh Garden
I need a free diagram of a tecumseh carburetor 5TPXS.3582AA Spec. 206915F
You can find a free diagram at www.sepw.com, use the part number of the carburetor as a model number under tecumseh brand lookup. Your carb part number is 640065a.
Jul 12, 2013 | Garden
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Have a 12 hp Tecumseh engine that bvackfires with ohv
Your problem could be one of several things.. A bad spark plug, bad gas, failure to lower the idle and let it run a few seconds prior to shutting it off, unadjusted valves, etc.
I'd start with the plug and some fresh gas, then go from there. Always idle the engine down for a few seconds before shutting it off. This allows all the gas in the combustion chamber to be burned up preventing backfire.
Jan 14, 2012 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Spark plug specs
The plug you need for a Tecumseh Enduro OHV16 is a Champion N4C, and it should be gapped at .030 .
Hope that helps.
Jan 01, 2012 | Tecumseh Enduro Vertical Engine 16 HP 1in...
I have a Tecumseh 12.5 hp vertical ohv engine Model OV358EA (OHV110-135) The rocker has come loose, pushrod jumped out and stopped engine. I need to reset valve clearances, I have no manual to give me...
My 13.5hp ov358ea is .004 both valves. Would like to know model of your engine. I want to replace the non-adjustable carburetor of my 13.5hp ov358ea with an adjustable carburetor.
Retired Airline Mechanic
Jun 26, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Husqvarna LR130 burnt out starter
it has one but the way to fix it is to adjust the exahust valve thay should know that thats is how to fix that now the reason you cant find any thing on this is becous tecumseh is out of buisness thay have been out since 2008 i hope this helps you if not call me and ill help ya 918-7281822
Mar 06, 2010 | Husqvarna Garden
Canaballing parts
Hello tim38663:
Depending on the Engine Model and Spec this Tecumseh Usually has the Same External Parts as a 15 HP to the 18 HP Single Cylinder Tecumseh Engines.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tecumseh Enduro Vertical Engine  16 HP 1in x 3 532in Shaft Model OHV16204230F Logo
2,246 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
