Question about Archos 7 Digital Media Player
My archos 7 light is only red and won't turn on
  • 3 Answers
Try Removing the Battery for about 30 seconds then plug it back in
Posted on Aug 12, 2010
  • asc66 Nov 28, 2010
    where is the battery locatated?
My archos WON'T TURN ON.
check the power supply connection i.e., battery connection and AC connection
Oct 14, 2012 | Computers & Internet
My archos 28 internet tablet wont turn on... the light comes on and then it goes off after like 7 seconds
LOL, you're up the creek. Never buy a computer that does not have a CD Drive on it because that is what you need now.
May the AC Adapter Power Cord is bad. Some of them have a indicator light on them when you plug them in the wall. Does yours have a light on it and does it light up?
When you plug the power cord in the tablet do you see any lights?
Apr 24, 2012 | Archos 28 Internet Tablet
Archos 70 won't turn on
I have the 8gig Archos 70, the whole thing froze as described in other posts. The solution is not for the feint of heart though. Mine would do absolutely nothing. So what the heck, I opened it up (nothing to lose at this point). Messed about a bit. Read that when it "Bricks" like this there is nothing that can be done. If it is Bricked, something locks it in the memory and function. As long as the battery is connected, it will remain that way no matter what.
Solution. Cut the black power wire from the battery (there are three long wires red white and black), leave for 20 minute, and solder the wire back together and heat shrink the joint. Reassemble, plug in power cord and it should reboot...
My archos is about 3-4 years old, and is mounted to the wall in my kitchen for use as an internet radio
Feb 28, 2012 | Archos 70 android tablet Notebook
Archos Clipper how do i turn it off and also how do i know when its fully charged. Many thanks
To swich this on and off you have to hold down the "Play" button for about 7 seconds. It's fully charged when the red LED light is solid and not flashing. :-)
Dec 13, 2010 | Audio Players & Recorders
My archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
Jan 12, 2010 | Archos Internet Media Tablet MP3 Player
Archos tv+ has constant red blinking light. Froze
I know this was a while ago, but just in case you never fixed it, or someone else needs help with the same problem, here's a possible solution. I had this same problem recently, but didn't realise it was thanks to Archos's latest firmware being dodgy. I actually took the hard drive out at one point, put it in my PC and backed up all the contents. In fact, you simply press the TV button on the remote when the red light is blinking quickly. That takes you to a recovery menu, where you can attempt to repair or format the drive. If you hook it up a PC via USB, you should also be able to access everything on it to back it up.
Anyway, the repair and format options will tell you to connect your device to a PC, but that's just to load a firmware file onto the hard drive. You can just as easily put this file on a USB pen drive, though, and load it from there. You can get firmware files from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en&#firm. The latest one is there, but ignore that and install the previous version. Hopefully, that should get the TV+ booting again. It worked for me, anyway.
Nov 15, 2009 | Archos TV+ DTV Receiver / Video Recorder
My archos 7 wont charge the red light comes on but wont charge tried resetting batery no use put a new battery in green light came on looked like charging but didnt in the end
If the archos was purchased new from Archos stores they have warranty on them call tech support to find out. Have your serial number and product model number handy.
Aug 03, 2009 | Archos Internet Media Tablet MP3 Player
Can't link my archos to my laptop
1. Copy all factory installed files from the Archos on to your PC hard drive or write a CD / DVD.
2. Download the latest software from www.Archos.com and keep a copy safe (not on the Archos!) … there was a new version last week by the way …1.5.12
3. If you record any films, music, or TV that you want to keep forever then don’t keep them on the Archos!
4. Factory installed samples (photos & films), wallpaper, etc are available for download from FTP://support.archos.com
5. If you need to format the drive but it won’t talk to the PC through the normal USB, try plugging a flash memory card (the bigger the better) into the other (left hand) USB socket and copy stuff onto it.
6. Avoid changing back & forward between ‘hard drive’ and ‘windows device’ … not sure if this was the cause of the problem but you never know!
7.Always have mains power (not battery) when moving files around.
Nov 13, 2008 | Audio Players & Recorders
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
Archos 7 Digital Media Player Logo
649 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
