Question about LG 16X DVD 52X DVD ROM SATA Drive Internal DVD Drive
My DVD drive is not reading any disc - LG 16X DVD 52X DVD ROM SATA Drive Internal DVD Drive
Your Lens is Expaird or if your Dvd room is new then Check your Data cable.
Posted on Jul 03, 2010
Cannot read the dvd disc
Your problem could be the DVD itself (make sure that the disc is not scratched or dirty) or the DVDD drive. If the drive will read other discs then the problem is the actual DVD. If the drive will not read anything else then it is time to replace the drive.
May 05, 2011 | Computers & Internet
Dvd/cd is not working
You can follow these methods to try to isolate and resolve the problem. Use these methods in the order in which they are presented.
Method 1: Clean the disc
When you have problems with a CD or DVD drive, always check the disc first to see whether it is damaged or dirty. To clean the disc, follow these steps:
1. Remove the disc from the drive.
2. Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth.
Note Do not use a paper cloth, and do not use a circular motion to clean the disc. These can scratch the disc.
3. Reinsert the disc in the CD or DVD drive.
If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to step 4.
4. Try again to clean the disc by using a cloth dampened with water, or dampened with a commercial CD or DVD cleaning solution.
5. Dry the disc thoroughly, and then reinsert it in the CD or DVD drive.
6. If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to method 2.
Method 2: Check the disc for damage
If the disc is clean, check whether it is damaged. To do this, follow these steps:
1. Remove the disc from the drive, and then examine the disc for scratches or cracks.
2. If the disc is damaged, try another disc to see whether the CD or DVD drive can read it.
3. If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive.
If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement.
Method 3: Try a different disc drive
If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps:
1. If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc.
If your computer does not have more than one disc drive, you can insert the disc in a different computer.
2. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5.
If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4.
Method 4: Make sure that the disc is compatible with the drive
Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
* A DVD disc is incompatible with a standard CD drive.
* A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
* A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
If the disc is compatible, go to method 5.
If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement.
Method 5: Use Windows Update to check for updated drivers
If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing.
Good luck
Jan 21, 2011 | Computers & Internet
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Driver needed for TSST Corp CDDVDW TS-H653N SCSI CdRom Device please. DVD drive shown in My Computer, and MS says I have the correct driver for this device. But, it doesn't work.
If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive. If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement. Method 3: Try a different disc drive If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps: If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5. If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4. Method 4: Make sure that the disc is compatible with the drive Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive. A DVD disc is incompatible with a standard CD drive. A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs. A DVD disc is incompatible with a drive that does not have a DVD logo on the front. If the disc is compatible, go to method 5. If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement. Back to the top Method 5: Use Windows Update to check for updated drivers If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.com If these methods do not resolve your issue, try the advanced troubleshooting steps in this article. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help, or you might want to contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ If methods 1 through 5 did not resolve the issue, you can follow these methods to try to isolate and resolve the problem. Method 1: Test the disc by using the command prompt to copy files Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive. To test the disc by using a command prompt to copy files, follow these steps: Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files. Click Start, and then click Run. Copy and paste (or type) cmd in the Open box, and then press ENTER. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:*.* HardDiskDrive:cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder. Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files. If you are asked whether cdtest specifies a file name or a directory name, press F. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER. If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement. To continue trying to isolate the problem and test the CD or DVD drive, go to method 2. Method 2: Test the CD or DVD drive in a "clean boot" state If the disc is readable and undamaged, there may be some hardware or software that is interfering with the CD or DVD drive. You can test this by inserting the disc into the drive after restarting your computer in a clean boot state. This helps you determine whether any hardware or software is interfering with the CD or DVD drive. To test this, follow these steps: Restart the computer in a clean boot state. Note For more information about how to start Windows with a minimal set of drivers, click the following article number to view the article in the Microsoft Knowledge Base: 310353 How to configure Windows XP to start in a "clean boot" state After the computer is restarted, exit all programs and applications that may be using the CD or DVD drive. First, right-click each icon in the notification area, and then click Exit. Note The notification area is located at the far right of the taskbar, near the clock. Some programs that are listed in the notification area do not have an Exitcommand. Therefore, you may have to click Quit, Close, or Disable, depending on the commands that are available for that program. Click Start, and then click Run. Copy and paste (or type) taskmgr in the Open box, and then press ENTER. Windows Task Manager opens. Click the Applications tab. If any programs appear in the Task list, click the name of the program to select it, and then click End Task. Repeat the previous step until the Task list is empty. Close Windows Task Manager. Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, there may be other programs preventing the drive from reading the disc. Go to method 3. If the CD or DVD drive still cannot read the disc, go to method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the "Next Steps" section. Method 3: Change the CD or DVD drive configuration If there are programs that are preventing the drive from reading the disc, you can try to resolve this issue by configuring the drive to run in direct memory access (DMA) mode. DMA mode is a high performance mode for transferring data to and from devices. These include CD and DVD drives. To configure the CD or DVD drive to run in DMA mode, follow these steps: Configure the CD or DVD drive to run in DMA mode. For more information about how to switch your computer's disc drive controller to DMA mode, click the following article number to view the article in the Microsoft Knowledge Base: 310751 Device settings are hard to find in Windows XP Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, you are finished. If the CD or DVD drive still cannot read the disc, try to troubleshoot DVD components by using method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the “Next Steps” section. Method 4: Troubleshoot DVD problems If the advanced troubleshooting methods 1 through 3 do not resolve the issue, and you have problems specifically with a DVD drive, follow these steps to try to isolate and resolve the problem. Prerequisite You must use a DVD drive with a DVD logo on the front, not a standard CD drive. Step 1: Unplug any cables that are connected Unplug any cables that are connected to the video outputs of the computer. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, you may have problems with the video hardware installed on your computer. Contact the manufacturer of the video hardware for support or for a replacement. If the DVD drive still cannot read the disc, go to step 2. Step 2: Update the DVD driver Contact the manufacturer of the DVD drive to obtain an updated driver for the DVD drive, and then follow the manufacturer's instructions to install the driver. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated driver. You are finished. If the DVD drive still cannot read the disc, go to step 3. Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder Contact the manufacturer of the DVD drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer's instructions to install the decoder. Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated DVD decoder. You are finished. If the DVD drive still cannot read the disc, make sure that the sound card in the computer is compatible with the DVD drive. To do this, contact the manufacturer of the sound card. Reinsert the disc in the DVD drive.
Feb 27, 2010 | Compaq Computers & Internet
Can't read dvd photo disc
Maybe your DVD drive is a older date !!
Many new dvd can not bee read with older DVD drives
Try to see if the dvd phot disc can bee read on a new dvd drive. You can start to see at your friend or working place/ liberary
Please rate my answer
Aug 22, 2009 | Compaq Computers & Internet
Drive can not read CDs..read Dvds
I suppose that you have windows XP. Pls follow these steps Clean the disc - Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth. Check the disc for damage - Remove the disc from the drive, and then examine the disc for scratches or cracks. Try a different disc drive - If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. Make sure that the disc is compatible with the drive -Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
  • A DVD disc is incompatible with a standard CD drive.
  • A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
  • A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
Use Windows Update to check for updated drivers - If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.comRegards
Jun 18, 2009 | Computers & Internet
DVD Writer not reading disc
Please do the followings steps:
First check other dvd are able to read by your dvd drive if yes the your dvd drive is not compatible with the mentioned DVD+R M33-8067 disc
Second if your drive is not able to read other dvd discs then try to clean it by good quality lens cleaner available in the market
If still problem persist then you have to change your DVD drive .
I hope this solution can assist
Regards
Balisonu79
Feb 13, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
How do I read the disc on a computer?
• Windows XP Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as external DVD-RAM drive in Windows Explorer. DVD-R disc is read from the camcorder “ drive”. • Windows 98SE, ME, 2000 Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as two external drives such as a removable drive and a DVD drive in Windows Explorer. DVD-R disc is read from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
LG 16X DVD 52X DVD ROM SATA Drive Internal DVD Drive Logo
81 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
