Question about Maytag Neptune MDG9700A Gas Dryer
Dryeer front load dryer has load sqeak noise while running
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryerdryeer - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Jul 04, 2010
Frigidaire affinity dryer sqeaking
Hello Jim Miller - From what you have described it sounds like you either have a problem with the belt, front and/or rear bearing, or a loose connection with the motor or drum. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replace depending if they are worn, damaged or loose.
Sep 30, 2012 | Frigidaire Dryers
Sqeaks and won"t spin
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 24, 2010 | Whirlpool LGR5636L Gas Dryer
GE DBXR463ED2WW dryer making loud sqeaking noise when full load in dryer? What is causing this and how can I fix
there are some pads that are like teflon that the drum rubs on. get some more and re place
Oct 24, 2010 | GE DBSR453EBWW Electric Dryer
Neptune dryer sqeaks while running
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Jul 18, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer making sqeaking noise
greetings,
the most likely answer is the belt pulley..the rollers can also make noise,but they usually will make a thump thump noise..remove belt pulley and lubricate and see if this helps
May 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Problem is the belt around the drum is sqeaking and the pulley appears to be causing the noise. The drum stops turning as the belt starts to move from its original position. How do i get the pulley and the...
Sounds like you need to replace the pulleys and the belt...
heatman101
Apr 15, 2010 | Kenmore 94702 Front Load Stacked Washer /...
The dryer started making a noise and I need to open the top to look into the drum...can someone tell me how to open the top of Frigidaire GLER642AS2?
assuming it is like most dryers, it has a top sepaate from the base. with gentle prying at the front corners, the top should pop up and then lift up and flip back on hinge clips at the rear. as far as the sqeaks, usually lubricating the rollers and tension pulley solves the sqeaking problem.
a screwdriver is usually enough to pop the top, but be careful not to chip the enameled paint. a plastic or wooden wedge works well also.
good luck....jay
Jan 04, 2010 | Frigidaire Dryers
Dryer makes a lot of noise when spinning, sqeaking, etc.
hi thanks for the question it sounds lie the front glides are worn & te back bearing check those parts
Sep 27, 2008 | GE DBXR463EBWW Electric Dryer
Amana dryer sqeaks at start up
Going in through the front is usually an absolute last resort when working on white goods. Based on experience with other machines (I don't know yours):
If you pull the dryer out then tip it back a bit, you may be able to get to some of the components through the bottom.
There is almost certainly a large access panel on the back (probably your best way in if you have belt problems).
Working from the back of the machine, if you take some of the top edge trim off, you will probably be able to get the top cover off if you need to.
A.
Mar 09, 2008 | Dryers
Maytag Neptune MDG9700A Gas Dryer Logo
64 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
