Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator works sometimes
We have a side by side GE refrigerator that automatically shuts off completely and then after a few hours, it starts up again and works fine. It cools thinks when it is working and it makes ice. The issue is that while it is off, water starts leaking from bottom. Once it starts, it freezes and we have to manually break up ice so that when it happens again, it will not leave all over the floor. This has been going on for quite a while. I don't want to get rid of it because it does keep food cold. Any suggestions would be greatly appreciated.
  • 47 Answers
Check the thermostat
Posted on May 05, 2017
  • 1462 Answers
SOURCE: GE refrigerator
this may be water from the defrost cycle. if this drains to tray over compressor, check tray is not too full (water evaporates from heat of compressor) otherwise defrost water will go to a seperate container which may have a split or is overflowing. fault can also be caused by poor door seals which would produce too much ice on evaporator pipes
Posted on Mar 21, 2007
  • 54 Answers
SOURCE: My GE Profile PSS26MSTSS is not keeping food cold.
You need a new defrost heater
Posted on Jan 04, 2009
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
  • 358 Answers
SOURCE: the ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Posted on Apr 26, 2009
Beeping sound on ge refrigerator side by side
Sometimes you'll get that if the door isn't completely shut because something is stuck between the door and gasket. If you check that and it all looks good try unplugging the fridge for 10 minutes and then plugging back in. That usually resets the computer.
Mar 24, 2015 | GE Refrigerators
Refrigerator control panel failure, causing dispenser to run for hours, filling refrigerator with burned plastic smell
I have a artic and it has a motherboard in it. This is the most common problem.They are easy to replace and you can get one on the internet pretty cheap.First look at the mobo for any burnt spots on it. If so then get the # off the board and search for it.
Mar 16, 2014 | GE Refrigerators
My ge refrigerator model pss26sgpa is not cooling in fridge or freezer
make sure the condensor fans are clean they are prob. full of dust. bottom rear of unit.
Apr 18, 2012 | GE PSS25NGM Side by Side Refrigerator
Water fliter
For a GE (which you posted under) just turn the filter a quarter turn counter clockwise to remove the old filter. Water will shut off automatically, so you will only loose a few drips. Install new filter by lining up arrow/ cheveron and turning quarter turn clockwise.
Jul 04, 2010 | GE GSS25LGM Side by Side Refrigerator
Water not working, ice is. fridge is set at 2.stuff freezing
i have this exact same problem. Started about 3 months ago with the crisper and now the water. when I turn the fridge off after a few hours the water works again. I'm calling the repair person tomorrow
Jan 30, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Doors don't swing shut automatically
The GE side by side refrigerator has 2 cams on the bottom hinge that helps shut the door. If the cam wears out then the door will not close properly. One of the cams is riveted to the hinge assembly and an extra cam is shipped with it. The cam assemblies can easily be replaced by using the information on the website that refers to the GE TFX22R refrigerator.
Apr 25, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Compressor makes "clunking" noise when it turns off
No I did not get any replies on my GE Profile refrigerator problem. Your question said "Amana".
Jan 17, 2009 | Amana ARSE66MB Side by Side Refrigerator
Ge profile refrigerator
sounds like a defrost or sensor problem. or the main P.C.board. probably the board and sensors.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
