Question about Peg Perego John Deere Turf Tractor
I disconnected the gas pedal relay and can't remember where the wires reconnect
    President:
  • 670 Answers
There should be three wires that connect to the gas pedal. Red, White and Blue, (how patriotic!). On the gas pedal switch, the middle connection is the white wire the closer to one of the end is the blue wire, and the other is the red wire. Hope this helps.
Posted on Jul 03, 2010
Testimonial: "Fitting how the wires are red white and blue, yes! I figured it out but instead of running while pedal is depressed it's the opposite now. pressing down stops it, ugh. thank you for your help!"
  • btshat Aug 20, 2011
    Swith the red and blue wires around. I had the same problem.
Someone gave my grandson a gator and we bought a new battery for it and it still does'nt do anything. what could it be?
Posted on Apr 29, 2011
91 Nissan 240 sx. Tach doesn't work until gas pedal pushed. Also wipers go when tach starts??
Could be some faulty wires, I would check out the wiring to see if anythings been disconnected/ reconnect wrong.
Jun 23, 2016 | 1991 Nissan 240SX
Wiring diagram model 7466 i am trying to reconnect a foot pedal on my singer sewing machineu
The foot pedal is generally plugged in on the right side of your machine. There should be a hole that matches the end of the plug. The user's manual is available as a free download on Singer's site.
Sep 22, 2014 | Singer Sewing Machines
Why is there a clicking noise by fuse box under hood?
Relay clicking in the fuse box or relay box near it, find which relay and the problem associated with it. The gas thing is from the ECM being reset, it has to relearn running the motor.
May 09, 2014 | 1999 Chevrolet Camaro
The wire is disconnected in the pedal. Disassemble?
release the clips from underneath with a flat head screwdriver to release the gas pedal assembly
Apr 09, 2014 | Peg Perego John Deere Turf Tractor
Reduced power
APP (accelerator pedal position) sensor is bad. Basically means you can floor it, but the signal going to the computer is only a reading a fraction of what it should, which in turn gives you the decreased power. You will need to replace it (basically the entire gas pedal assembly). I've seen them run anywhere from $60 to $120 new, depending on where you go, so shop around. Or, if you're comfortable enough buying used & have basic knowledge of hand tools (or know someone who does), go to a junkyard and pull the entire gas pedal assembly out of a scrapped Impala (make sure its the same year). They run an average of about $25 + tax here in TX, but I imagine that varies from state to state. All it is, is 2 bolts holding the assembly to the floor pan and either one or two wiring harnesses (sorry, it's been a while since I did my wife's & I can't remember for sure). Simply disconnect the wiring harness(es) (you may need something like a philips head screwdriver or something to depress the little latch to get the clip out that hold the harness securely in place) & remove the two bolts with a socket wrench. Then bolt the new pedal assembly in place & reconnect the wiring. After that, you may need to clear the code in the computer. This will get the messages and lights in the dash to turn off. Just take it to a dealership or local mechanic (any of them will have an ODB2 diagnostics tool) and ask them to clear the code. two minutes later, you'll be back on the road and the car will be running like new again. Hope this helped... Good luck!
Dec 25, 2013 | 2007 Chevrolet Impala LS Sedan New Cars
Push the gas pedal and switch gear just maks a click noise i replaced that thermal fuse but still just clicks. i relaced the switches and pedal and battery. im runnin out of things to replace. please help
I had this same problem with a turf tractor and it ended up being a bad motor, so disconnect one of the motors and see if the problem persists if it does then disconnect that motor and reconnect the other motor and see if the problem persists, if it works fine with one motor connected but not the other then the disconnected motor is probably bad, but then i would test the wires from that bad motor on the good motor just to make sure that the wiring isn't bad
Aug 08, 2011 | Peg Perego John Deere Gator HPX Ride on...
How to replace brake light switch?
How to Replace a Brake Light Switch
Parts:
1. Brake Light Switch
Tools:
1. Needle Nose Pliers
2. Flashlight
3. Combination Wrench Set
Steps:
Step 1 * Insert your key and turn the ignition switch to the ON position.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 * Turn your headlights on.
o Tip: Have an assistant check to make sure your tail lights are both working properly.
Step 3 * Step on your brake pedal and have an assistant check to see if the brake lights illuminate.
Step 4 * If all the brake lights are out, locate the brake light switch on the brake pedal linkage. Check for 12 volts into and out of the switch.
o Tip: Turn the key to the OFF position before starting any electrical work.
Step 5 * Disconnect the wiring harness from the brake pedal switch.
Step 6 * Disconnect the brake pedal switch from the brake pedal linkage.
o Tip: You may need to remove a c-clip to do so.
Step 7 * Remove the old brake pedal switch and replace it with a new part.
Step 8 * Reconnect the wiring harness to the brake pedal switch.
Step 9 * Repeat steps 1-3 to confirm that the repair has solved your problem.
Hope help with this (remember rated an comment this help) Good luck.
Mar 02, 2010 | 1993 Buick LeSabre
95 tercel tail lights won't turn off
Stoplights are usually turned on by a switch mounted above the brake pedal. When the pedal is fully released, it presses on the switch and it breaks the circuit. When you press the pedal, it releases the switch and the circuit completes, turning on the lights.
Most likely cause of this is that the switch is either broken or misaligned.
Adjust the switch to be depressed when the pedal is up. If the lights turn off, you're done.
If this does not fix it, unplug the switch from the wiring harness. If this makes the lights go off, your switch is broken, buy a new one. If it does not, you have a short circuit in the wiring. You will need to trace the harness, find the damage and repair it by splicing or replacing the harness.
May be you could try these steps:
  1. 1 Check the brake-pedal switch. This small button behind the brake pedals is activated when you press down on the brake pedal and makes the brake light go on. Press the switch by hand to see if it's stuck. If it is, pressing it may force the stuck part.
  2. Step 2 Find the fuse for the brake light and pull it out. Remember to put it back in before driving again
  3. Step 3 Find the brake lightbulbs and remove them. Remember to put them back in before driving again.
  4. Step 4 Disconnect the negative battery cable. You will have to reconnect it again to start and drive your car.
Jul 16, 2009 | 1995 Toyota Tercel
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
Peg Perego John Deere Turf Tractor Logo
645 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
