Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Water is not spraying well while dishwasher is running. We had a service call and the technician cleaned a trap clogged with food near the water pump. I think the same thing happened but do not know how to access the trap.
  • 36 Answers
You have to remove the sprayer arm, it's cover, and the cover underneath that located on the bottom of the dishwasher, inside the dishwasher. If you find a large amount of grease/food under these covers then you are not rinsing your dishes enough before placing in the washer.
The disposal unit in these units are nothing more than a cheap metal blade spinning over a metal grate. Anything tougher than a piece of cake and it's frosting runs the risk of breaking the gears that drives this.
Clean all the food/grease that you can access. Be careful while removing the gunk, I have found glass shards from broken dishes. Locate the disposal impeller and screen. It can be removed. Inspect it for damage and reinstall after cleaning.
Your water flow can be restricted if this is plugged.
Posted on Jul 04, 2010
My dishwasher will not drain
It can bequite common for a dishwasher to not drain because either the drain hose or theair gap (if the unit has one) is clogged up. Drain hose clogs commonly occurwhere the hose is attached to the main household drain line, or where the hoseconnects with the garbage disposer. Turn mainswater off and disconnect mains power Tryremoving the drain hose to unclog any debris. Don't forget to reattach the hosebefore you start your dishwasher again.The drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hotrunning waterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 07, 2012 | Maytag 24 in. MDB5600A Jetclean II...
Kitchenaid dishwasher - small pieces of food are left on otherwise clean dishes. Water level comes to about 1 inch below heater coil. I ran it without dishes (or soap) and added about a quart of water so...
hello
contact the Help line
Call 1-800-334-6889
Major Appliances:
8 am - 8 pm EST (Mon - Fri)
Countertop Appliances:
10 am - 5 pm EST (Sat)
KitchenAid Experience® Store
1-888-886-8318
Thank You
Sep 11, 2008 | Dishwashers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
E 15 problem code on Neff dishwasher
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.It can bequite common for a dishwasher to not drain because either the drain hose or theair gap (if the unit has one) is clogged up. Drain hose clogs commonly occurwhere the hose is attached to the main household drain line, or where the hoseconnects with the garbage disposer. Turn mainswater off and disconnect mains power Tryremoving the drain hose to unclog any debris. Don't forget to reattach the hosebefore you start your dishwasher again.The drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.Turn the main water supply and main power offE15 error means the anti-flood system as activated; you havehad an overspill of water into the base plate below the sump.
If you take the kick plate off from below the door youshould be able to access the base to remove any excess water.Behind your kick board is a plate below the door. Remove theplate.
With the power off push a rag into the base plate to soak up the water.
Failing that pull out the dishwasher onto the floor and tilt the machine backto allow the water to run outSwitch the water and power back on and restart the programto test.If the appliance is less than 2 years old Neff/Bosch Groupguarantees it
Apr 07, 2012 | Neff 24 in. S5456 Built-in Dishwasher
Dishes not clean
It sounds like two possible problems.
1. A clog in the water system from previous food is restricting the spray pressure of the water.
2. Water pressure pump that provides the spray wands pressure is either stuck or inoperable.
Without spray pressure and the hot water, the food is gonna stay.
Dec 18, 2011 | KitchenAid KUDS301V Dishwasher
Dishwasher is not draining. how do you unclog? Removed all screens and traps, can't figure out where the clog is?
Those models commonly get food stuck in the spray arms. I would suggest you disassemble one or both and check for clogs there.
If you've checked all the screens and traps (and spray arms) in the dishwasher, have you checked the water flow in the hose to the sink and at the air gap (the small metal cylinder that sits on many sinks)? A dishwasher is typically connected to the air gap, then a short tube goes down and connects to the garbage disposal (if one is installed). The hose running from the dishwasher to the sink can become clogged as well. An easy way to check it is to tap the hose or pick it up close to the dishwasher. If it sounds full or is heavy, you've probably got a clog in the hose. If you do, be careful when you go to clear it, because the hose is full of water.
Feb 28, 2011 | Frigidaire 24 in. FDB635RF Built-in...
FOOD PARTICLES ON DISHES
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Its a GE dishwasher and water is left in the bottom of the dishwasher. I have run it through its cycle twicw it sprays water around in the dishwasher but doesnot want to drain.
There is a solenoid valve located near the motor which should activate to either drain or to spray. These often get jammed up with food particles. Locate it and take it apart. Clean out what ails it and put it back in service.
Jul 19, 2008 | Dishwashers
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
The top rack is not getting clean.
This is one common possibility
It may be the food chopper assembly. Mine broke last year from a toothpick,
the food doesn't get chopped because the blades are broken, then the filter clogs and water wont spray high enough.
Heres a test--turn on the dishwasher and wait until you can hear water running then open the door really fast and look at how high the water is spraying--there should be alot of water all over the top rack running down
Jan 31, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
563 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
