Question about Zebra Stripe S500 Thermal Label Printer
Configure to print certain labels?
I have two S500 zebra printers. One is configured fine. The other one I just got off ebay and it prints but it doesnt print the UCC labels correctly. I figured how to print the config page off both printers and they are different. I am assuming this is the problem. Ok..so I am not an IT person...have to tried to research how to re-config it and....need help. thanks in advance!!
  • 35 Answers
Go to http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
and download the manual for the S600, which is the same procedure as the S500, follow the set up an calibration routines.
Any further problems cantact me at www.lancerlabels.co.uk
Posted on Dec 31, 2009
    Champion:
  • 254 Answers
You could use the windows driver from
www.seagullscientific.com to send the parameters to your printer
Posted on Sep 16, 2009
All labels are printing at a reduce size how do I change?
Hello there,
You normally configure a label size from 2 places:
a) Printer Driver(I reccomend downloading the one from Zebra from www.nicelabel.cl)
b) Directly from Printing software option
In both cases, search for the "Genera"l tab and you will be able to configure the label size
Jun 09, 2014 | Zebra 105SL Thermal Label Printer
How can you configure Zebra printer 105sl (over network) to print labels in IE and have a regular printer from reducing the document size from a thin client?
I have this issue whenever I set my default printer to a label printer. Use the other printer as the default and set to the zebra only when you need it.
Dec 07, 2011 | Zebra 105SL Thermal Label Printer
How do I configure a Zebrazm4 Plus printer for a
Usually the easiest way to do this is to make sure the printer driver you're using is set for continous labels. This setting will vary depending on the driver / software being used to print labels. You can also go into the SETUP mode on the printer and make sure MEDIA TYPE is set to continous. Be aware that most printer drivers will override the setting in the printer. You may set to continous in the printer but if the software is set for die cut labels, then the printer will act for printing die cut labels when a format is sent to the printer.
Mar 25, 2010 | Zebra Z4Mplus Label Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I have TLP 2844 its printing very poor quality
Download zebra setup utility and use it to configure print quality.
Sep 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Small label is being cropped at the top
Have you tried the menu settings for start top of label? If other printers work, you are talking about a configuration setting. I would get a configuration off another printer that works and look at yours real close.
May 01, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
Printing every other label
download the segull driver(www.seagullscientific.com) reset to factory defultIt is possible that is on continuos labels but you need to be on non-continuos. you can do it with the botons, but is easy with the driver.
Sep 16, 2008 | Zebra Stripe S500 Thermal Label Printer
How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
Zebra Stripe S500 Thermal Label Printer Logo
251 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
