Question about Toshiba Televison & Video
Hi there, I have TOSHIBA ''14vl33b'' LCD tv, which got different inputs like AV,TV,PC...so that i can use this lcd tv as my pc lcd screen as well, however my problem is i havn't got remote control for this LCD tv & i don't know how to change different inputs like TV to AV to PC. Can any one help me to get manual for this or tell me how can i switch between different inputs without remote control????? Thank you very much in advance..........
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
  • 93 Answers
SOURCE: would like to switch tv mode to cable mode
go to the menu button,press it, in menu service you to choice either air or cable. then select the cable
Posted on Nov 07, 2007
SOURCE: Code for Direct TV remote control
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Best of luck
Posted on Dec 03, 2007
SOURCE: Programming code for GFM LCD TV
Hello Sandrp,
I too had been looking for a code to program my remote. The problem was that GFM is not a recognized TV company like most other companies. So I figured it must have been done by another company and Meijer just put their brand on it and I was right. The company that made the TV is Funai. If you try looking for that company in the list it may be their. I know I was able to find it for my Directv remote. Hope this helps.
Gmatrix
Posted on Aug 24, 2008
  • 4 Answers
SOURCE: Remote control code for a Toshiba Regza 46'' LCD TV
0154 0156 0060 1256 0845 0832 1356 0650
Posted on Dec 21, 2008
I have a problem with my samsung lcd it shows me black and white screen i try to set it with manual shows component -pc instead of av -tv
Looks like you need to reread the manual & properly connect. you are plugged into the PC & not the AV input & this is most likely your issue.
Dec 31, 2014 | Samsung LN-26B450 26 inch Series 4 LCD...
Connect pc laptop
This TV has a PC interface VGA (HD-15) , so all you need is get a VGA to VGA cable to plug between the VGA output on the PC and TV.
On the PC select the display as external monitor.
On the TV pick the PC input as required input, not the TV tuner.
Here is the manual.
LCD TV 47HL167 Support Toshiba
Jan 05, 2014 | Toshiba REGZA 47HL167 TV
Hi i was wondering i have a toshiba lcd 40 in tv and when i go into my input screen alot of my input selections are locked how do i unlock these to access hdmi and pc options
Try and connect your HDMI and PC inputs ,switch them on then access them ,sometimes they only get enable when they received something. Thank you n Good luck.
Sep 03, 2011 | Toshiba Televison & Video
TOSHIBA REGZA 24" LCD/TV cannot
"JUST PRESS CINEMA MODE ON YOUR REMOTE CONTROL AND SELECT APPROPRATE VIEWING MODE" it might be located under the left of 0 with an image like stretching as indicated on my remote. It is the issue about the overscanning and underscanning of tv using HDMI connection. I have been the same problem as you but I did solved it using this. Hope this would help!
Mar 10, 2011 | Toshiba REGZA 47HL167 TV
I have and older toshiba tv and we can not get the xbox to come in. we have tried every channel and get nothing but snow
I think you will find that the X-Box signal is not on any channel number and you will need to select an external input/source on the TV.
Switch on your TV and your X-Box so there is a signal being sent to the TV. Then look for a button on your remote or the front of the TV marked "INPUT", "SOURCE", "AV" or "TV/AV". When you have located this button, press it slowly and repeatedly until you are able to see the signal from the X-Box on the TV screen. If you press too many times and skip past it, just keep pressing it until the picture from the X-Box appears again. You will also need to use the same method to return to watching TV when you have finished using the X-Box.
If you are still having difficulty, please let me know the model number of the Toshiba TV and any remote control you are using and I will let you know the exact method for your TV.
Hope this helps.
Regards,
BElectric
Jan 08, 2011 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Bush LCD tv wont allow Wii to be tuned thru AV
Hi, the av lead with the three connectors at the end make sure you have them connected correctly -
Yellow - Video
White - Left Audio
Red - Right Audio
It's a simple mistake to make , but check it.
Let me know - Anthony
Feb 10, 2010 | Televison & Video
Not able to get picture when connected to PC via HDMI
bbutler,
Your Toshiba can handle PC screen resolution up to 1024 x 768
Lower the resolution of the PC screen to somewhere between "640 x 480" and "1024 x 768". It will work just fine.
It's not likely that there is a any physical problem with either the PC or HDTV.
1. Right-click anywhere on your desktop
2. [Properties]
3. [Settings] tab
4. Slide the "Screen Resolution" pointer to the LEFT to adjust and click on [OK]
*DONE*
Oct 16, 2009 | Toshiba 37RV525R 37 in. LCD HDTV
Toshiba Satellite L25-S1194 attached to TV monitor can't get display on laptop at same time HELP!!
Connect your TV to the computer with an S-Video cable. Turn the TV on and choose the AV option (of your TV) to S-Video. It will tell you that there is no signal on the TV.Press the Fn key on the keyboard. While keeping that key pressed, press the F5 key. A small rectangle appears on the screen showing different connection possibilities (LCD, LCD +TV, LCD+CRT, TV only, CRT only). You can cycle through the options by pressing F5 repeatedly. You select the output option (TV + LCD).Release the keys . You will then have your two screens.
Note: I assumed you connect the TV through the S-Video. If your TV can be used as a monitor (it has a VGA adaptor), then with the F5 key select option LCD and CRT
Hope it helps
Aug 28, 2009 | Toshiba Computers & Internet
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
VGA Input
If it says no support then it can't read the computer. There is no way around this unless you have a RGB (this is a computer input port) input port on the TV
Jul 10, 2017 | Polaroid FLM-2625 26 in. HD-Ready LCD...
Televison & Video Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
