Question about Konica Minolta Office Equipment & Supplies
Hi, My konica 3340 is displaying the following message: -service please call: 18-04 with p-key handling errors Please help.
    Problem Solver:
  • 10 Answers
Pretty sure is to do with main paper bin lift up mechanism try opening paper bins and using manual feed thru the side the try each bin in turn. hope this helps
Posted on Jul 11, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica Minolta biz hub c550 error code c-EEE3 Help please
To reset the malfunction code press follow keys:
Turn OFF the copier,press and hold pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message on the display and release the Utility key.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Good luck.
Mar 21, 2013 | Konica Minolta Office Equipment & Supplies
How to solve error c2551 in Konica bizhub c220
C 2557,C 2558 Black TCR sensor.
C 2551,C2552,C 2559 Cyan TCR sensor.Check de consumabile life,if you have possibility change the Black and Cyan Imaging unit.Enter in the service mode Press Utility key - Metercount- Details- Stop 00 Stop 01 select Sistem 1 or Sistem 2and read the messages.For reset turn OFF the copier,press and hold the Utility key turn ON the copier and then the display appaire Trouble reset release the Utility key and touch the reset,turn OFF the copier wait 2 minutes and turn ON.
Feb 07, 2013 | Konica Minolta bizhub C250 All-In-One...
My Konica Minolta Magicolor does not fully INITIALISE. As it starts up, the only message displayed in the LCD is Magicolor 4650 EN 256 MB memory ram. and it halts there. Any help?
Update the firmware using the following link:
http://kmbs.konicaminolta.us/productsattachments/manuals/FirmwareUpdaterGuide.pdf
The following manual was read by me. The Troubleshooting section and error message section didn't mention the 256 MB memory ram error.
http://kmbs.konicaminolta.us/productsattachments/manuals/magicolor4650EN_4650DNUserManual.pdf
However, there is supposed to be an 'initalizing' message if the printer is initializing.
Also, there is a 'memory full' error when there are too many fonts on the memory card, but this is not something you mentioned.
If you can't solve the problem with the above, I would consider having the unit serviced by Konica Minolta.
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html?model=magicolor4650&cat=Printers&subcat=magicolor&SsdModelId=1042%26productid%3d1041
877-778-2687 is the number for service information at Konica Minolta for your printer.
Please call 877-778-2687 for service information.
Jul 22, 2010 | Konica Minolta magicolor 4650DN Laser...
Error message M1
Press Utility / Counter -> {STOP}{0}{0}{STOP}{0}{1}, now you should be in Service Mode. Go to Service Choice - > IU LIFE STOP MODE -> and choose CONTINUOUS.
Mar 19, 2009 | Konica Minolta bizhub 180 All-In-One...
Konica is constantly on display
you need to have a firmware upgrade on your copier.
Jan 15, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
May 12, 2008 | Konica Minolta bizhub C250 All-In-One...
Help! i get the "Machine Trouble" error
are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
Dec 04, 2007 | Konica Minolta Di1610 Copier
118 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
