Question about Toshiba Tecra 8100 Notebook
Toshiba tecra laptop
I loose all my information on my laptop every time i switch off what is the problem and solution
  • Anonymous Apr 18, 2008
    i was working and the battery power shut down, i connect the power but the laptop, doesnt start.
  • One Million Network Inc
    info like be more specific please?
    Champion:
  • 230 Answers
Lee : what information are you loosing ?
Guest make sure your RAM is tightly secure. I had same problem. had to push my RAM in on boot-up.
Posted on May 13, 2008
Toshiba Tecra A7 Won't Turn On
You may trying pulling the battery out while its unplugged. Another issue may be the socket where the AC adapter plugs into the laptop. Is it loose, broken prong inside the socket. It should have been able to power up at least for a brief moment just on the battery. Hope this helps ya.
Apr 20, 2012 | Toshiba Tecra A7-S712 Notebook
Trouble install soundcard di toshiba tecra
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Jun 08, 2010 | Toshiba Tecra A8-EZ8313 Notebook
Need to restore factory setting for my toshiba tecra a7 laptop without cd?
impossible
you can reinstall windows and download the drivers on the toshiba web site the technically it factory
May 08, 2010 | Toshiba Tecra A7-S712 Notebook
I don't have no driver from toshiba tecra M1
Toshiba is very good with the tech support. I had the same problem and they sent me the original installation disk that came with the computer. these disk will look at your system and install the needed drivers. It will also restore the computer to the original configuration when it was first purchased. If you use this option you will loose all that is in the computer now. YOu must backup anything you want to save. I do this on my own computer when it gets to the point that nothing is working properly. I have also found original disk on Ebay for older computers.
Sep 19, 2009 | Toshiba Tecra M1 PC Laptops
Can you please inform me how to perform the ''reset the CMOS'' in a
This will require you some disassymbling the bottom of your laptop and look for a cmos battery, disconnecting it then replug.
Why not consider to clean/reseat it RAM, most of it does not make a unit to turn on when not detected.
Apr 04, 2009 | Toshiba Tecra 9000 Notebook
Toshiba Tecra M2vS330- crashes when wireless card switched to "on
Hi, your problem does not have to see with the openoffice that download, It coincides with your card mini - pci wireless I damage, and is for it that whenever you ignite the wireless your Laptop restarts for hardware malfunction. the solution is to replace the mini wireless board.
Jan 09, 2009 | Toshiba Tecra M2V-S330 Notebook
Wirerless
toshiba tecra 8000 does not have built in wireless, you need to install an external wireless adapter (usb or pcmcia), and use the software provided with the wireless adapter to configure it
Jul 06, 2008 | Toshiba Tecra 8000 Notebook
Drivers for Toshiba Tecra 8100
Arifin,
  • You should goto toshiba make registration of your product and download drviers which you want.
  • Or click here, select your model number and make download.
Gud Luck
Iqbal
Apr 17, 2008 | Toshiba Tecra 8100 Notebook
Toshiba Tecra 8100 doesn't charge
Good morning, Steve!
Plain and simply, you have one of two problems.
First, the power socket is loose or defective. A loose socket will usually allow you to wiggle it around when the cord is inserted. Not a lot of movement, but some. There should not normally be any movement. Whether it is loose, or defective, the motherboard will have to be removed for replacement/re-soldering. This is not an uncommon problem.
Second, The A/C adapter cord has a broken wire in it. This is most easily repaired by replacing the cord if separate from the adapter, or replacing the adapter if the cord is not removable.
If you are adventuresome, you may be able to cut part of the covering off of the cable and repair it.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Nov 23, 2007 | Toshiba Tecra 8100 Notebook
Toshiba Tecra 8100 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
