Question about Sony Network Walkman NW-A1200 MP3 Player
Not Recognized Everytime i plug my Sony walkman in it says that its not recognized. i been stuck with the same music on the walkman for 2 years now. what can i do to fix it?
    Problem Solver:
  • 5 Answers
Plug in what? in the computer? its just in the chord. maybe the chord you are using to connect your walkman to the computer is not functional.
Posted on Apr 22, 2008
Music idownloaded into sony Walkman digital player nw s203f is not playing
SONY ' eSupport - The portable player is not recognized by ...
https://us.en.kb.sony.com/.../the-portable-player-is-not-recognized-by-th...
Aug 15, 2015 - If it the portable player is not recognized or does not begin to charge after waiting 5 ... available on the NWZ X series and some NWZ E series Walkman players. ... If the Walkman player is still not recognized, restart the computer. ... Portable Audio; Digital Music Player; NWZX Series; NWZW Series; NWZA ...
Oct 15, 2015 | Sony Audio Players & Recorders
Sony walkman nwz-b135 when i connect it to my laptop it will add music etc, but will not charge thanx
I'm sorry to know that the Walkman player is not getting charged. I'll be glad to assist you with this. Please perform the following steps:
If the New Hardware Wizard appears and is prompting for a location of the driver, point to the following directory: C:/WINDOWS/INF .
To function properly, your Walkman player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below:
Connect the portable player to the computer using the supplied USB cable.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer .
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not recognized by the computer, try a different USB port.
Under the Common settings menu of the player, format the player using the built-in Format utility.
Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system.
If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later.
If you did not have the latest service pack, test the connection status again after it has been installed.
If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Thanks for contacting FixYa.
Aug 08, 2011 | Sony Walkman NWZ-B135 MP3 Player
What driver do i use for my sony mp4 player... model number nwz-s616f.. please help me
It is not required to install any Driver for connecting the Walkman Player to the Computer. The Driver for recognizing the Walkman Player as a MTP Device is already installed in the Computer. You can install the supplied Windows Media Player 11 Software for transferring the files to the Player. You can either Drag and Drop the files using the Windows Explorer to the MUSIC Folder which appears as a Removable Drive or can use the Windows Media Player 11 for transferring. If the Player is not recognized by the Computer, try connecting to different USB ports and try re-installing the USB Driver from the Device Manager.
Thank you for using FixYa!
Nov 23, 2010 | Sony Walkman NWZ-S616F MP3 Player
DOES NOT RECOGNIZE PLAYER WHEN CONNECTED
ive got the new version of the sony sonic stage downloaded onto my laptop,and when i plug my player into my laptop via usb cable,the player itself is recognized straight away as a harddrive/removable disk etc,and you have to transfrer music onto the player as from sonic stage music library,and you also have to creatate you own music library via sonic stage,and u can also transfer music from your own music library wich you use via windows media player,and also u can transfer a cd into you sony sonic stage music libraty,and this is similar to when your using the windows media player as to rip a cd or transfer music onto an mp3 player,as i use all diffrent types of mp3 players myself,and i find the archos gmini sx 202 player to be pretty awesome player,as ive got to of them as well,and i use windows media player as to transfer music files onto them,and i cannot transfer any music files onto the sony ones via windown media player as those music file wont show up on the player at all,and ive tried this myself,and it will only work via sony sonic stage.
May 28, 2009 | Sony Network Walkman NW-HD3 MP3 Player
Sony walkman is not being recognized by XP as a portable device
I remembered that I had another problem with Windows Media 11 that seemed impossible to fix until I found somewhere that uninstalling or rolling back WM11 to the previous version then reinstalling fixed the issue. I decided to give that a try with this problem we're having and sure enough it worked. The Walkman is now recoginized as a Portable Device under Device Manager and in My Computer it is displayed as a Walkman and not a removable disk.
All you have to do is use add/delete software, delete or rollback WM 11 and then either use the Sony disc with WM11 or download a new version. All together it only took a few minutes and I'm back in business. No music or playlists were lost. Try it and let me know if it works for you.
Mar 14, 2009 | Sony Audio Players & Recorders
I bought the Sony Walkman Sport Series NW-S205F 2 gigabytes  and i didn't realized that i can't just drag and drop songs from the computer. i have a IMAC computer and the software that comes with it...
ok i'll try this one im not to familliar with macs but as far as i know the walkman does support drag and drop just open up the walkman and then the music folder and try it im sorry if im wrong but i know they support drag and drop at least in windows
Feb 23, 2009 | Sony Walkman Sport Series NW-S205F MP3...
Sony walkman nwz-a816 getting usb device not recognized
okay, try plugging it in. Go to Startmenu, right click 'My computer', and select properties. Go to the 'Hardware' tab, then Device manager. Down at the bottom, you should see a section of the tree that can be expanded, entitled 'Universal Serial Bus Controllers' Find the Unknown device part. Select that, then go to 'Action','Uninstall'. After un-installation, the computer might restart. Unplug your walkman. When windows is back up, plug it in, and see if that works. if not, I have an alternative solution
Dec 30, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
My Laptop wont recognize my mp3 player Sony walkman NWZ-E438FBLK
Was having the same problem. All I did was plug it into my usb port in my laptop, made sure HOLD wasn't on, and then hit the reset button. A few seconds later my computer recognized it. All the songs and everything I had on there previously are still all there. Hope this helps. :)
Nov 20, 2008 | Sony NWZ-E438F Digital Media Player
MWZ-S615F will not charge or connect
I'm sure it's the cable that's not functioning properly. Mine started doing the same thing and after wiggling and adjusting the cable inside the MP3 itself, the computer finally recognized it and I was free to charge and add music. Also you can try to connect it to a different USB port on your computer. The beeps however are news to me, unless I just never noticed. One piece of advice is to never let the MP3 battery die, because after I let it happen mine began to experience more severe problems.
Oct 15, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Not recognized by computers
To fix this try the following using an account with administrator privileges and internet access:
1. Open Device Manager (While holding the windows key, press the Pause / Break key. This will open up the System Properties box. Select the Hardware tab and click Device Manager)
2. Find and expand the Portable Devices folder (a problem icon should appear beside the WALKMAN NWZ-A815 device)
3. Right-click WALKMAN NWZ-A815
4. Click Update Driver...
5. Select Yes, this time only
6. Click Next
7. Select Install the software automatically
8. Click Next
9. Click Finish
Open Windows Media Player 11, connect your sony nwz-a815 and wait for it to appear then try to sync some files.
Mar 31, 2008 | Sony Walkman Video NWZ-A815 Digital Media...
Sony Network Walkman NW-A1200 MP3 Player Logo
196 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
