Question about Microsoft Office 2003 Standard Student&Teacher Edition Full Version OEM (50300288OEM)
In microsoft word document the format is changed and its been appearing as symbols and hypen along with the sentance,kindly helpme out in sorting the problem
  • 1,679 Answers
In Microsoft Word 2004
Click on Tools in Menu bar
Click on Options
Under View - You will find Enable/disable highlighted text - Uncheck this and you will find the symbols gone.
Posted on Jul 03, 2010
Problem with section numbers not being linked in a word document that I'm updating using word 2007. The original document was created with an earlier version of Microsoft word.
When you create or open and edit a (.docx) document in Microsoft Word 2007, the Save As option gives you the opportunity to save it as a the (.doc) document in the formats of older versions of Word.
If it is not already too late, try to recover (using the AutoRecovery function built-into Microsoft Word 2007) , the earliest and most error-free version of the document in question you can recover and then use Save As, rather than Save to make an experimental copy of the document in an older Microsoft Word format.
Another option to consider is to download and install the free Office Suite Application Open Office, which can open, edit and manage many Microsoft Office documents and then copy and paste the most error-free version of the document in question into the appropriate Open Office Program and then see what sort of job the Open Office Word Processor makes of handling the tricky formatting.
For the future, as a general rule, whenever editing any document that contains complex formatting, always remember to start by copying and pasting the text of the original document into a new blank document (remembering to close the original document so you don't accidentally toggle between the two). Then your experiments could be conducted on a copy of the document, rather than the original, enabling you to repeat the method and continue creating experimental copies freely, until you have developed a workable strategy for dealing with the formatting issues.
Furthermore, remember to always use the Save As function, giving the experimental documents distinct and varying names (test.doc1, test.doc2, test.doc3 etc.) so you can keep track of your progress in mastering the formatting issues, then each document you save, is a copy, leaving the original document unchanged and available as a template for further experimentation, if necessary.
Nov 26, 2011 | Microsoft Office Professional 2007 Full...
I have my old documents in word 2003 and today i needed them urgently so opened them and they couldnt open and gave error of file conversion in the beginning and then i selected it and it changed all the...
have you changed the program these documents were made with
using another program to open these documents may cause you this problem
or open word select tools from the drop down list you will see language you can change the language
also open up word select view from the drop down list select toolbars select standard ,formatting
also open up word across to the left you will see arial,times new roman,arial black to name a few of the different languages from the drop down list your documents will be read in
hope this helps
dont forget to vote
Feb 09, 2011 | Computers & Internet
I can't write ? : ; ? etc... correctly :S
Go to your control panel and select Regional & Language settings.
Make sure the Formats tab has English as the current format, the select the "Keyboard and Languages" tab, select Change keyboards, and make sure the default input language is English.
Apr 14, 2009 | Microsoft Office Professional 2007 Full...
This is a formatting problem. Just had Word 2007 installed. I do transcription work and need to be able to type one hypen by itself or two hyphens without a space and not have two hypens change to one...
all you need to do change the auto-format options
just follow these steps and it will be solved-->
* open the word document and select the "office button" on the left hand side top
* at the bottom you'll find the "word options".Select it.
* goto the third option "proofing" and then choose "auto format options" and then "auto format as you type"
* deselect "hyphens with dash" option
and the problem is solved.hope i was clear enough.please do post comments if any doubt.
Jan 16, 2009 | Computers & Internet
If I write a document on microsoft works word processor and send it to someone with microsoft word, will they be able to read it on microsoft word?
PECIFYING FILE COMPATIBILITY
As different versions of Word have been released over the years, there
are noticeable differences in the way text layout and formatting
appear. Sometimes it’s necessary to make changes to an existing
document so that it emulates the formatting of a previous version of
Word. Having this ability makes viewing these types of documents
easier. The changes you make aren’t permanent, so you can change things
back to the old display if you need to.
1. Open the document.
2. Go to Tools | Options | Compatibility.
3. Click on the Font Substitution button to substitute non-supported
fonts with supported ones, and click OK.
4. Choose the version of Word you want to emulate from the Recommended
Options For drop-down list.
5. Enable the appropriate check boxes in the Options list to select any
additional desired display aspects.
6. Click OK.
Today we get to deal with compatibility problems between Office 2007and previous versions. Office 2007 is supposed to be able to openstandard 2003 and previous files, but you still have font problemsoccasionally. If you’re using an older version of Office, you candownload the Compatibility Pack which is supposed to make OpenXML documents work in Office 2003, but it’s kind of a hit and miss affair.
Sep 16, 2008 | Microsoft Computers & Internet
Re Samsung R50 Lap Top Microsoft XP Home installed from new by Samsung, unable to write personal letters,address and sentances print all moved on the paper I am trying to do this on Wordpad can you advise...
could be few things
predictive text turned on or formating - go into control panel -> keyboard options to turn off
try another text edit program, does it happen in notepad?
download a free edit program like open office (www.openoffice.org)
see if it happens with that
formating options in word pad arent great - does this happen on screen or just when You print?
Jul 16, 2008 | Computers & Internet
Word document
Dear misseap, you probably have put the 'track changes' option on. You can remove it by pressing CTRL+SHIFT+E. This should stop removing paragraph symbols from your text.
You might also like to select all the text and right click to find format option. In this options you can make the changes to formatting of the text.
If this was helpful please press solved.
Nov 28, 2007 | Microsoft Word 2003 for Students &...
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
