Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
After fixing the brake line, my husband's pickup shuts off when he applies the brake or when he turns on the headlights? Any ideas?
  • 532 Answers
Bleed the brakes with High Performance Brake Fluid first.
Thanks.
Posted on Jul 03, 2010
1990 Isuzu pickup turns off at stop sign
If this is a petrol engine have a look at the brake booster leaking vacuum and running the engine too lean to idle. Test by allowing to idle with out your foot on the brake If applying brake pressure shuts the engine down ,replace the brake booster..
Jan 24, 2015 | 1990 Isuzu Pickup
2010 Kenworth t402
by releasing the park brake you are in fact putting air in the park brake (spring brake diaphragms) that compresses the springs and allows the brakes to release. When you apply the park brake you are in effect dumping the air out of the system and allowing the spring brakes to come on. The light is telling you that there is insufficient air in the park brake circuit to fully release the spring brakes. Some ideas are that the air lines on the trailer are opposite to the prime mover(tractor), there is a kink in the air lines in the trailer , the air tank that holds emergency air for the spring brakes system has an internal leak in a valve between chambers or externally between air tanks. I would make very sure that I fixed this problem before I travelled as the consequences of a trailer wheel lock up at speed could have very serious results.
Jun 06, 2014 | Cars & Trucks
When I apply brakes I get a severe vibration in whole pickup
I would say your problem is still possibly brake related because of your experience with clamping the rear lines. You have changed everything out in the system except the Master Cylinder and the actual brake lines. Never heard of Master Cylinder causing symptoms you describe, but I am only a shade tree mechanic. My only other suggestion would be to verify your rear tires are properly balanced. There is very little weight in the rear of a pickup and unbalanced tire(s) would exhibit the symptom in any car, but most especially in the rear of an unloaded truck. This is a tough one! Keep us posted on your progress in getting this one fixed.
May 03, 2014 | 2010 Chevrolet Silverado 1500
I have a 99 Jeep Grand Cherokee Limited i have brake lights that work when i apply brakes, but as as soon as i turn my headlights on the fuse blows and i have no working tailights with the headlights on. ...
There is definitely a short in the park lights system. Did you just have a radio installed....since the illumination wire sometimes gets grounded and will cause that fuse to blow until you fix that wire.
Aug 17, 2011 | 1999 Jeep Grand Cherokee
There is a new light that just appeared on my dashboard, it resembles the high beam light, but its green, and the light coming out of it is in dots, instead of lines, and i dont have an owners manual, any...
that's day time running lights, your high beams are on when ever your ignition is on and headlights are turned off. If you apply the parking brake it turns off the running lights and the light on the dash goes off, if the parking brake is depressed just to the first racket click the lights will be off.
Dec 04, 2010 | 1997 Chevrolet C1500
Broken brake line on 1990 chevy 4x4 pickup (K1500) broke and drained master cylinder. Front disc brakes/rear drum brakes. ABS system. Once brake line fixed what is the bleeding procedure that must be...
1990 Chevy 4.3 l engine runs rough at idle half the time-- sometimes it's OK, other days it's rough and can smell raw gas, as tho it's running rich... any ideas?
Nov 27, 2010 | 1990 Chevrolet K1500
1994 GMC pickup front brakes are sticking. Replaced brake pads, rotors and calipers. What next?
By "sticking" I am assuming that you mean that the brakes are staying applied (calipers are not releasing)and burning the brake pads and rotors up.
The most common cause of this is brake hoses.
The hoses that connect your calipers to the steel brake lines have an inner lining and a reinforced outer "shell". sometimes the inner lining tears loose from the outer shell inside the hose. (It cannot be seen by "looking" at the hose.) The inner lining then starts to act similar to a "heart valve" where it allows fluid to be pushed down into the caliper, then collapses inside the hose, blocking the fluid from returning to the master cylinder when the pedal is released. This can happen just because of the age of the hose, but is more commonly caused by someone allowing the caliper to hang by the hose while replacing the brake pads without using anything to support the weight of the caliper.
To diagnose this condition, raise and support the vehicle and remove the wheels. Make sure that the transmission is in "Park" (Automatic Transmission) or "Neutral" (Manual Transmission) and apply the parking brake. Then start the engine and apply the service brake. (Press HARD on the pedal) Shut the engine off, release the service brake and open the bleeder screws on the calipers. If brake fluid squirts out of the bleeder screw under pressure, then the hoses are the cause of the calipers not releasing.
Oct 17, 2009 | 1994 GMC Jimmy
No tail lights
Try checking the headlight switch it may have broken contacts in it. Easy fix go to a salvage yard find same make and model truck, swap headlight switches.
Dec 27, 2008 | 1997 Chevrolet S-10 Pickup
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
35 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
