Question about Liebherr Refrigerators
I went on vacation for 6 days and when I left the seal on the refridgerator was not firm... I returned home last night to a warm refridge, spoiled food, fridge motor on. I turned to supercool, no response. I have not turned the refridgerator off. Freezer was sealed and is fine. How do I fix this?
    President:
  • 1,099 Answers
If your refrigerator door is leaking, it can wreak havoc on your electric bill. While there are many of the parts of a fridge that seem too complicated to fix for the average homeowner, replacing the refrigerator door seal is a fairly easy do-it-yourself job that can save you money.
Before You Get Started
Before you order your new seal, take a quick moment to inspect the door liner under the seal. If the liner is cracked you will need to replace that as well, as the door seal will not seal properly
Buying and Sizing
Refrigerator door seals can be found at almost any major home improvement or hardware store. You can also find them online. No matter which route you choose, buy a factory seal that will fit your brand of refrigerator. Be sure you write down the correct model number before you make the purchase. When it comes time to repair, make sure that you have the right part by holding it up against the old door seal and making sure they are the same size.
Cleaning
As with any project involving sealing, make sure that all the surfaces you are working with are clean by using warm, soapy water. You may also want to soak the new seal in hot water to make it more flexible when it’s time to install. Make sure all surfaces are dry before proceeding.
Installing
Make sure the refrigerator is level.
Loosen the screws by lifting the edges of the seal. These screws hold the liner and the seal together. Loosen just a few at a time. DO NOT take the screws all the way out, as this will allow the door liner to fall out and make more work for you.
Pull the old gasket out. It should easily slide out from behind the plastic liner.
Attach the new gasket by slipping the small lip of the new door seal behind the plastic liner. Once you start attaching the seal you can start tightening the screws. Do not tighten them all the way. It is best to start in the corners. Check the alignment as you continue to tighten the screws, as well as checking that the seal is straight.
Rub some baby powder around the hinge corners of the door seal and where the seal slides to prevent sticking
Small gaps and wrinkles will generally work themselves out over a few days, but can sometimes be removed with a hair dryer.
Check Your Work
To test your seal, use the dollar bill test. Close the refrigerator door on a dollar bill and gently pull. You should feel a slight resistance as you try to remove the dollar bill from the seal. Repeat this around the door. If you do not feel a slight pull on the dollar, the door is not sealing properly.
Posted on Jul 03, 2010
  • mariahemming Jul 03, 2010
    Forgot to mention that I closed the door and it sealed but will not cool. Yes seal is a problem in that these Liebherr's do not seem to seal automatically. they need the extra pressure. But fridge is sealed not...but no cooling.
    Problem is not cooling with motor on, so turned motor off.
  • Sanyade Akinwale
    Sanyade Akinwale Jul 04, 2010
    First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the fridge and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the fridge section, look at the back wall- any frost buildup there?
    Hope this solution helpout....
Brinks 42-1009 ez vacation timer instructions
The Brinks 42-1009 EZ Vacation Timer is preset with 7 full days. You cannot choose when it goes on and off.
To set, spin the dial (clockwise only) until the arrow in the upper right of the center face is near the current day and time. Plug everything in and switch the upper tab to the right. On certain days, it will turn on in the early morning as well as evening or late night.
You cannot choose when to turn the light off. However, if you are home, you can turn the light on by switching the upper tab to the left. Remember to switch it back to the right in order to activate the timed on/off periods.
Jun 10, 2012 | Hampton Technologies Brinks Timer
Side by side fridge. came home after a weeks vacation and all the food was spoiled and it was warm inside of the fridge and freezer. There were no power outages during the time we were gone.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | Kenmore 55223 Side by Side Refrigerator
Won't turn on
The power supply module may have gone out, need to check and see if you do have 5vdc standby voltage at the power supply module, also check the fuse in the power supply.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
May 09, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Kenmore refrigerator model 106 will not cool fridge or freezer
is your refridge leveled if not level it and stable. Try turn it off for a couples of hours and then put it back. does the refridge move a lot when u open it fix this refridge doesn't has to be moving when opening when on and moving this agitates the freon creates more pressure so it has a pressure switch and turns off the compressor to protect it from over or under pressure
Jul 24, 2009 | Kenmore Refrigerators
Fridge/Freezer working sometimes. Starts and stops
Need you to check the compressor to see if too hot to touch. If so unplug and don't leave it plugged in until we find the problem. This could be start capacitor, start relay, overload or a bad condenser or evaporator fan motor. Like to know he model number to help you better, Let me know, Sea Breeze
Jul 21, 2009 | Refrigerators
Bad Compressor, valve sticking in the compresser
Contact Whirlpool Customer Care about this. There has been a serious problem with the Embraco compressors they are using.
May 15, 2009 | Whirlpool GD2SHGX Refrigerator
Dodge Neon 98 Engine Oil Pressure
you might try and change the pcv valve, my car hand a similar problem in the summer and i never changed it. the pressure blew my cam seal and i was leaking oil like crazy. i dont know if it will fix it but they are cheap. i would give it a try.
Jan 14, 2009 | 1998 Dodge Neon
Refridgerator (Bottom Frzr-French Door) not getting cold....Freezer is o.k.
could be a few issues, id open teh freezerdoor at looka t back panel id tere frost building up??? if so youhave a defrost issue, can you here the fan in freezer conmpartment spinning you may have a bad evap fan
Mar 16, 2008 | KitchenAid KBFA20ER Bottom Freezer French...
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
Refrigerators Logo
46 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
