My totaline digital 2 stage thermostat keeps buzzing. I have to turn the whole a/c unit off to get it to stop. Lately it hasnt helped much as when I turn it back on it is still buzzing. Help
    President:
  • 1,515 Answers
Hi, relays will also buzz causing units to loose transformers, I have seen this in the past years also. A 2-stage heat-pump stat? I would remove the front to expose the wiring terminals and pull the hot wire red, 24 volts and that should kill the buzz. If so, the circuitry is going out and you will need a new thermostat. I would, if you have a volt meter check the incoming voltage to the stat to make sure it doesn't exceed the proper voltage rated on the cover. Max would be 30 volts ac. If its over that, the transformer is putting out to much on the secondary side and should be replaced, or it will eventually take all of the low voltage controls out. Try removing the 24 volt hot wire and also if you have a friend that has a meter or you do, check the voltage coming in to the stat. Get back to me if it exceeds the rating, as this will cause the buzzing. It may just be faulty contacts in this stat also. I wish you the best, and ask that you are kind when rating me in helping you. Please keep me posted if you need my help.
Sincerely,
Shastalaker7
A/C Heating & Refrigeration Contractor.
Posted on Jul 03, 2010
I have no idea how to use my totaline digital thermostat,
Totaline is a brand name of the Carrier Corporation. Go on www.totaline.com and research the model of your thermostat. User manuals are available.
Nov 11, 2013 | Heating & Cooling
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
GE Zoneline 1000 - heat stopped working this morning, A/C is working fine, fan is working fine, buzz sound when heat is turned on as normal, thermostat seems fine as room is still warm, can turn thermostat...
Sorry to read about your problem, I hope this helps you out.
Sounds like you may a defective, reverse heat pump switch. If you were in Denver,Co I would be glad to work on it for you. They are no different than large units to work on.
and no, you cant work on the unit.....takes special tools
Just keep calling around for a person who will work on the unit..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | GE Zoneline AZ25E12D3B Air Conditioner
We have bought a home with the wite rodgers thermostat 1f85-275 it doesn't seem to be working. on the top right of the screen it states 1&2 stages? anyway, help would be appriciated
Hi, this thermostat is for central heat and air systems that have more then 1 stage of heating or cooling. For example, your unit may have 2 stages of cooling, as in 2 compressors, or 1 stage of cooling and 2 stages of heating as used in commercial heat pumps. This is a multi-stage heat pump thermostat. It may be just a matter of programming the stat. If you can find a manual on it, this would help. If you open the cover, it should have directions on how to program it.Make sure you have power to everything, check all breakers to see if they may be shut of, even if you have a display, doesn't mean you have high voltage to run the unit. Make sure fan is in auto, and on heat or cool, and temperature set for it to come on. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating Contractor
PS Your unit has 1 stage of cooling, and 2 stages of heating.
Nov 05, 2010 | Heating & Cooling
I am installing a totaline progammable thermostat, the old one is a rheem, i hooked the b wire to the b terminal the r wire to the r terminal the g to the g terminal and the y to the y terminal the e l and...
First off, make sure that the wires you are connecting at the thermostat match the circuit board of the unit. It is good practice, but not always followed to do a "1 for 1". To answer your question, W2 is simply when there is 2-stages of heating. If your furnace does not have 2-stage heating, then leave it empty on the t-stat. "C" is common. Common is neutral, so it should have continuity to the ground or L2. If your old stat did not utilize this, I wouldn't worry about it, unless the new stat is a touchscreen and constantly lit stat. Just keep this in mind. W-warm (heat), Y-cooling, G-fan, R-hot (main 24v power from furnace to thermostat), C-common (not always required), AUX (auxillary, if there wasn't one used on your last furnace, I wouldn't worry about it.). X may have been a common, or a dead terminal.
Bottom line, if you open your furnace to see the circuit board and where the thermostat wire connects, and match above, you should be just fine. Make sure you turn power off prior to opening the furnace, and when landing the wires on the stat. You could inadvertently blow the 24v transformer.
May 08, 2010 | Heating & Cooling
Thermostat runs aux. heat all the time
sounds like a wiring issue to me
either there are wires going to the wrong terminals on the t.stat, or there is a physical problem with 1 or more wires somewhere
it is also possible that the new thermostat will not correctly control the unit that you are trying to operate. Unfortunately, just because it has all the right color terminals, does not always mean that they all operate the same.
Good Luck!
Feb 11, 2010 | Heating & Cooling
I have a Totaline thermostat for my upstairs and downstairs. I have the thermostat in the OFF position but it keeps kicking the fan on. The green LED light is not lit up showing me that it is even on. What...
First make sure the thermostat fan switch is on "auto" and not set to "on". Also some thermostats have the ability to run the fan intermittently for air circulation in the house using the FAU filter to keep the inside air clean. So check your manual for the thermostat and see if it has this capability & how to turn it off if it does. Otherwise it could be a malfunctioning thermostat or FAU.
Oct 29, 2009 | Heating & Cooling
A/C thermostat wiring problem
call a technician
check all indoor n out door wiring of unit
if u do wronge connection wireing of unit may be burn
take care
Apr 04, 2008 | Heating & Cooling
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
565 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
