Question about Canon ZR85 Mini DV Digital Camcorder
Reading Card Error. followed instructions to turn off and reinsert but the problem still exists
The ZR85 is only capible with an SD card. A SDHC card will not work. SD cards only go up to 2GB, no higher. Make sure your card is 1) not SD HC and 2) no larger than 2GB.
Posted on Jul 14, 2010
  • chris1616 Jul 14, 2010
    The SR85 is only capible with SD cards. The newer SDHC cards do not work. The old SD cards only went up to 2GB. If your card is larger then 2GB and/or a SDHC card, it will not work.
  • jonathan flores Feb 26, 2013
    I tried 512MB SD and 2GB SD card in my ZR85 but it wont work...
How can I solve my sony cyber shot camera modal DSC W630 is shows error as C13:01
This error indicates a memory problem.
The camera can't read or write data to the memory card. Try turning off and on the camera again, or take out and reinsert the memory card several times. Also remove and reinsert the battery.
It also can mean the memory card is not formatted, or there is a format error for an other reason. Format the internal memory or the memory card.
It also could mean the memory card is damaged and can't be used any more. Then you have to place a new memory card.
I hope something will help.
This is also in you user manual.
Mar 19, 2014 | Sony Cyber-shot Dsc-w630 16.1mp Digital...
We just received our brand new canon t3i in the mail. We formatted the card (a 2GB 700X Professional High Speed Error Free (SD) Memory Card Class 10) and immediately started shooting to test out the...
Sounds like there was an error while the camera was writing information to the card. You can try reformatting the card using a computer and a card reader, then replace it in the camera and format it from the menu. If that doesn't work and the camera is locked up you can try to do a "hard reset" by following the instructions on page 176 of the camera manual.
Jan 03, 2013 | Canon EOS 600D Rebel T3i Digital Camera
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
Hi, my Cyber-shot DSC-H55 is displaying System Error C:32:01 everytime I try to view pictures that have been taken. This happens only when I try to view pictures taken and I have to turn off the camera in...
for all those who c.32.01 error is an error related to contacts camera card reading virtually fail to read the card. for this problem must disassemble the camera and exert a little pressure on each contact then to reinsert the card and restart the camera
Jan 23, 2011 | Sony Cyber-shot DSCH55 Digital Camera
I have a kodak c743 with error code #126,1,0,0 and 226,1,o,o the lens will not go in and i cant take a picture
To remove the error, follow the instruction:-
1) Turn OFF the camera. 2) Remove the memory card from your camera. 3) Reinsert the memory card, then push down on the card until you hear a click. check the memory card is firmly fitted in your camera. 4) Turn ON your camera.
This will clear your error.
Have a nice day Rating the solution is highly appreciated.
Mar 06, 2010 | Kodak EasyShare M873 Digital Camera
Sound on the zoomlens and writing error # 45
To remove the error, follow the instruction.
4) Turn on your camera.
This will clear the error. For noise install a fully charged battery or new battery in your camera.
Rating the solution in highly appreciated.. Good Luck
Mar 02, 2010 | Kodak EasyShare Z700 Digital Camera
Message "unrecognized file format"
Is the error message appearing on the caemra or the computer?
I will in both cases recommend to format the SD card and to update your firmware.
Format your SD card. NOTE this will delete all existing data on your SD card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
Scroll up or down to the Format option, then press the OK button
Instructions to uploading new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9637/9640&product=EKN032552
If successful please give me the feedback as a rating or recommendation. Thank You
Jan 25, 2010 | Kodak EasyShare C633 Digital Camera
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Not reading memory card; keeps saying reinsert memory card, diplays error C 13
    not reading memory card; keeps saying reinsert memory card, diplays error C 1
    Aug 04, 2008 | Cameras
    Canon ZR85 Mini DV Digital Camcorder Logo
    362 people viewed this question
    Top Canon Video Cameras Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Steve Mason
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
