Question about Ovens
My wife used the self cleaning function over the night, it cleaned, however when she woke up the next day, the oven was clean, but no power to the oven. The breaker is on. not tripped. I did click it on and off with still now power. Is there a fuse in the oven that may have blown ? Thank you !
  • Ovens Master
  • 8,220 Answers
Yes their is a fuse in the control panel that melts if the temp threatens to wreck the controls:My wife used the self cleaning function over the - 38bbbcb.jpg
Posted on Jul 03, 2010
Is the oven self cleaning and if so how does it work?
if its self cleanin it will say right on it "self cleaning"
self cleaning ovens do exactly that they clean themselves no harsh chemicals (oven cleaner foam) are needed to dissolve the baked on cooking goo that builds up inside ovens , although if one uses a foil liner in bottom then one might never need to self clean it , but some models cant use liners due to convection fans air flow getting in the way ,
self cleaning ovens have the ability to get very hot (500 degrees plus) no one should ever open a oven in cleaning cycle as this hi temp can spontaneously combust to ashes your hair/clothing never the less burn the hand that opened it severely(most lock the door for safety) all that needs done after cycle, is ashes need wiped out with damp towel next day after cleaning cycle is done and oven cooled off completely , im waiting on the day they make one that sweeps its self out into the dust bin ,(not yet )
Sep 26, 2015 | Ovens
Why doesn't oven work after using the self- cleaning mode?
Check for incoming power; you may need to change the heater element.
Sep 11, 2015 | Whirlpool GBS307PD Electric Single Oven
I have a modern maid double wall oven (gas). I set it to clean last night (at 3:00AM). It is now 12:PM the next day and it can't unlock it. What should I do?
Try turning the main power off to the house for 5 mins and turn it back on see if that reset your oven.
Jan 01, 2015 | Ovens
Are you working christmas night? we had a small
Clean that oven by hand before you cause more problems...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 26, 2010 | Frigidaire Ovens
After using self cleaning function my oven had no power. Replaced the thermal relay and it worked fine. Now, we have run the self cleaning function once more and the oven died again. Is there another...
There is always going to be a problem whe you run your self clean feature. Your oven heats to over 800 degrees and this high heat takes out electronic parts.
Oct 18, 2009 | Whirlpool RBS245PDS Electric Single Oven
Self cleaning oven help
There is nothing wrong with cleaning a self-cleaning oven. Now, I don't have experience with your speicific oven, but I do have experience with other self-cleaning ovens. The self-clean function simply heats the oven up really hot. The actual temperature varies but the oven will get hotter than the hottest temperature setting. What happens is that when it get that hot it actually burns up spilled food and crumbs. sometimes in mine I even see small flames. The oven usually requires you to lock it as well since the temperature will be so high. Eventually you have to clean out the burnt "ashes" which are basically the stuff you get on food if you burn it. So the answer to what happens if you clean the oven is that you get a clean oven, nothing else. It won't hurt the oven at all. As a matter of fact even if you use the self-cleaning feature you will eventually have to clean out the "burnt crumbs" and such by hand anyway. So self-cleaning oven are designed to be cleaned by hand as well. And you won't hurt it by doing so even if you did it every day.
Jun 19, 2009 | GE Profile JTP56 Electric Double Oven
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool RF367LXS Ceramic Glass Range not working
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Feb 02, 2008 | Ovens
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
