Question about Line 6 TonePort UX2 Sound Card
The left channel of my toneport is higher than the right side in the outputs...even in the headphones its the same. When i push play with very low volume i start listening first on the left channel. I change the way outs in the toneport to the mixing board and it changes in the speakers to, so it has to be from the toneport. And the headphones/output proves the same. How can i put them iqual? Hope that you can help me, please!! Thanks
  • davidhumb103 Jul 03, 2010
    But when i am listening directly on the pc its perfetc.. its only when i plug on the toneport.
    Guru:
  • 1,705 Answers
Check out your speaker settings in Sounds and Audio devices, in your control panel.
Start - Control panel - Sounds and audio devices - Check the speaker volume under the "volume" tab and the volume controls for audio playback under the "Audio" tab.
Posted on Jul 03, 2010
  • dgsturt Jul 04, 2010
    I had assumed you had set up your Toneport, and so went directly to other aspects which could affect the output.
    But the fact remains, you'll have to check the settings of your Toneport and balance the outputs. That may mean having the left on volume level A and the right on volume level B.
Both sides of my headphones are outputting sound however music that is supposed to be left isn't outputted at all. That is, if a song has instruments playing on the left side of the track, it won&
Are you using the 1/4 inch adapter- if so- make sure the mini plug is fully seated- you should feel 2 detents as you push the plug into the adapter- if you do not, you may be bridging the tip and ring colar with one channel and because it is not seated fully, it is not contacting the other channel at all.
Also make sure the plug for the headphones is fully seated into whatever device you are listening to. you should feel the 2 detents each time.
Apr 01, 2012 | Music
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Line 6 Toneport KB37 Phones output has lost one channel after being dropped. Need the circuit for the phones preamp so that I can replace/or repair the preamp. Is there a service manual or wiring diagram...
You will probably have to go to Line 6 to get a schematic... HOWEVER, it is likely a visual inspection will reveal the failure due to dropping. Look first for bad solder at the headphone jack. Next under a bright light look for circuit board cracks. This is going to be surface mounted parts and unless you have an equiped shop, it is not likely you can successfully work on the board if it is not a visible problem.
Jul 04, 2011 | Line 6 Tone Port UX2
Aiwa 8100 amplifier, low output on left hand channel, need to turn balance control way to left.
Aiwa xx8100??? What are the missing letters? Maybe it's a source or preamp problem, eh?
I presume you have proven the channel is dead by trying multiple sources, swapping a different speaker onto it and that the balance control is NOT all the way to one side; headphones don't work either and we're down to proving it's dead before you take it in to a tech, right?
There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure. One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you
Apr 09, 2011 | Audio Players & Recorders
No problems for serval years. Right sound output died on both speaker and headphones, very slight buzz on increasing volume. Left sound output okay. Suggestions please. Jim Conway jmrc@aol.com
Feb 21, 2011 | Nakamichi AV-2 Receiver
The right output channel on the right side of my pmc 05 pro 4 has very low output. I can hear both right and left output channels in the headphones when I have the cue selected but when I try to monitor...
I assume you swapped thee output leads as well as the inputs which you di mention, to verify you amps and cables...
The Vestax schematic I have is NOT your same model, but the companies often re-use circuitry. In the schematic I have it appears that the two channels go through two levels of NJM2068L op amps.
In these two levels there is both a master gain control. It is important to know whether the gain control varies the output level of the right, even if it is low. Also in this gain control area is a master balance pot which varies the ratio of the left and right and is CAPABLE of taking either channel to near zero output... IF you have that control check it for sure !!! The pot is a dual employing both an A taper and C taper which is a reverse of the A.
The right tool for troubleshooting this is an oscilloscope, but first an inspection looking for board cracks around the output and pot area is in order.
Jan 01, 2011 | Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
Headphone output distorted on one side. Replacement jack?
studiospares (in london) or radioshack in USA, unscrew and get busy with a soldering iron, its not too hard, only 4 cables.
Jan 22, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
TrekStor 1beat emo 2 GB: Volume Control Low
There are a number of factors.  The maximum milliwatts per channel (left and right) is only 5 mw.  This is fairly low, plus the sound level in decibels is pretty low, about 90db, while others are usually 95db or higher.  The other factor is the fact that the stock earphones, the one that came with the emo, has a lot of extra plasic covering the metal part that protects the earphone speakers.  If you take off the plastic 3 spoke designed protector carefully, and cut all of the spoke design leaving only the circle, and place it back on carefully, then it will almost double the output of the sound.  Another reason that the sound is lower, regardless of any headphones you use, is the fact that the higher the ohms used, generally the softer the sound.  Most mp3 players will be only 16 ohms, but the Emo is in fact 32, and that alone lowers the db level and milliwatt output.  I would suggest either going to FYE and purchase the Skullcandy Ink'd earbuds like I did, or something similar to it with at least 100db output.  Don't worry about the warning about using 16 ohms instead of 32 ohms as in most cases, it doesn't do much harm.  If you can find a decent 32 ohm headset or earphone (personally, the in ear design would be best for the Emo as it is already fairly quiet, plus it cuts out some outside noise) that has 100db or more output, I'd get those instead just to make sure the Emo will last it's full lifespan.  The higher the db on the headphones, the lower the battery consumption, also.
Jan 08, 2009 | Trekstor 74412 i.Beat emo MP3 Player
Mono Sound Playing through Headphones
Simplest solution, from experience: make sure your headphone jack is pushed all the way into Zen 3.5 output jack. Sometimes it will feel like it's clicked in but you need a little extra push to get it all the way in.
Another thing to look at: I pretty sure the is a preference setting that controls right/left balance (my son has my Zen right now). If you can find  this control, it could be set all the way to one or the other side.
Give it a try, or see if resetting zen helps.
Good Luck.
Jun 10, 2008 | Creative Labs ZEN V Plus MP3 Player
Line 6 TonePort UX2 Sound Card Logo
119 people viewed this question
Top Line 6 Computers & Internet Experts
David Payne
David Payne
Are you a Line 6 Computer and Internet Expert? Answer questions, earn points and help others
