Question about RIM BlackBerry Curve 8310 Smartphone
When i try to use the camera on the blackberry 8310 it tells me to close other application, how can this be fixed
  • 32 Answers
Deactivate the media prog
Posted on Jul 03, 2010
BlackBerry 8310 when i open.could not start the camera.Close other applications and try opening the camera again. plz tell me soon whats i m doing
It's basically a memory issue. You need so much available memory for the phone to operate, to run the camera and to store the pictues. Have you changed anything about the phone between the time it worked and when it stopped working? How many emails and txt messagess have you stored on the phone? Check the phone status (menu, options, status) for free memory... recommendation is a minimum of 8-10 MB. I'd also suggest getting a memory card (transflash/micro SDHC).
Check out Blackberryforums.com... there is an excellent sticky in the main section about freeing up memory - removing applications and features that you do not need/want/use to free up memory. Typically, I have about 28MB free plus a 4GB SDHC memory card.
close all apps out also
Dec 05, 2010 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry Curve 8310 camera doesnt work it says close other applications
Download the newest firmware upgrade from Blackberry. In addition to a couple of new apps (movie mode and voice recorder), it should take care of your problem. Of course, this is all free.
Oct 30, 2009 | RIM BlackBerry Curve 8310 Smartphone
My blackberry 8310 camera won't come on, it says close all applications then try again, but i dont have any applications opened. i dont understand
First of all take a backup of all the important data on the handset and then try reloading the OS if this does not help then get in touch with the service provider.
Aug 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
Camera wont work, wants me to close apps and try again
Sounds like you may have a corrupted java system. Try to reload the OS by going to the Blackberry.com website, an downloading the desktop manager 4.7 fairly large, as well as the Blackberry device software. Depending on Carrier it should be the 4.5 version. Install the desktop manager, then install the handset software. Plug the phone in let it detect the settings, and then use the application loader to reload the handset software. It will back up your settings, and applications, and restore them once it's completed.
Jul 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
My camera is not working/ black screen.it tells me to close apps
Alright, I just had this problem. I dont know how this happened, but some settings were changed. If you go to media and press the menu button then go to options. Now change device memory limit to 15mb and reserved picture memory to 2mb. Now try your camera, it worked for me.
Jun 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
My camera on my blackberry curve is not working.
when i try to use the camera on the blackberry 8310 it tells me to close other application, how can this be fixed
Jun 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Blackberry 8310 curves camera won't open
OMFG lol!. I just saw this on pinstack.com
My camera had hte same problem for months and this just fixed it!!
1)Remove back cover
2)Press gently, but firmly on lense (you should hear a click)
3)Battery Pull
Apparently if dropped at all, the camera can shift!!
Cheers, Imma go take some pictures after months of not being able to!
Jan 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
Camera doesnt work or bluetooth
This is the initial sign of the camera coming loose from the socket on the main board.
If it still in warranty then send it out for repair.
If it's out of the warranty then you can put a foam or plastic spacer to under the battery cover.
Just like the battery foam pad under the battery cord to give it firm support.
Place few tab of supporting material under the battery cover. Make sure they does not cover the lense or the flash.
Next time the camera give you the error message again or ghost like image.
Take the battery out and press the camera and flash area firmly until you hear a soft plastic snap sound.
YOU MAKE HAVE TO DO THIS MANY TIMES
Once the camera contacts snap back in place then your are back in business.
Do a firmware update from Blackberry.com support page should fix the bluetooth problem.
It's a 15-20 minutes job, Once you start,it CAN NOT abort.
Jan 02, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
My camera on my blackberry curve is not working. ]
I found this solution on Blackberry forums. You'll need to take the battery cover off, and then push on the camera lens, or more accurately, the ring surrounding the camera lens. You should see the image corrected. I just tried it on mine, and it worked like a charm. Easy, cheap, quick fix.
I'd be curious to know if it's an electrical problem, a lighting problem (most likely) or a physical lens issue (focus).
Anyway, try it - it should work.
Dec 09, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
94 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
