I am using my d-link dir 300 router for 14mons. And suddenly it could not connect to the internet anymore or simply no wi-fi. How can I fix my router?
    Guru:
  • 1,705 Answers
Assuming its not dead, ie there's some flashing lights somewhere.
First switch it off, leave if for a couple of minutes, then switch it on again.
If you've already had a go at that, then try resetting the unit.
First, resetting sets the unit back to factory default, so you need all you set up details and passwords ready.
It may be worth connecting by cable to the back of the router, logging into it and saving the setup as a file on you pc.
While the router is still switched on, at the back of the router, there's a small recessed button, you'll need a biro or something similar, press and hold the button in for about 15 seconds. Once done, you should be able to gain wireless access, but you will need to reset all the passwords and link details.
If you were able to save that setu file, you should now be able to download it back to the router.
This in turn will break contact again, but your wireless network setting on you pc should log you back in again.
Posted on Jul 03, 2010
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
My n750db wireless n + router suddenly no wi fi
Unplug the router's AC power adapter for 5 minutes to ensure all capacitors have drained. Plug it back in and the router will reboot.
If your wireless doesn't start working. Log in to your router and check your wireless settings
Aug 18, 2014 | D-Link Wireless N 750 Dual Band Router...
How do we get wi-fi on ipod touch
in i phone touch u have to manu Tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth then turn on wi fi detection and connect it
Feb 22, 2011 | D-Link DIR-300 Wireless Router
Hi! im having a problem on connecting via wi-fi using this router, my iphone3gs is connecting but theres no internet connection. please help me...
The main problem is with the Internet port connection on this router.
Make sure that the internet port is connected to your DSL modem, or Cable modem. The 3rd light from the left on the front panel is the WAN (Internet) light. It should be solid green or blinking.
You should also be able to connect into the router using a web browser.
http://192.168.0.1
enter the username and password.
If it has never been configured before: username (admin) / password (leave it blank)
Try running the setup wizard in the web browser.
Dec 10, 2010 | D-Link DIR-300 Wireless Router
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
How do i setup my dir-300 wth a password so other people cant log in to my internet?
First connect your router to computer with ethernet cable.
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to wi fi security set your WEP code it is your password to connect wi fi network.
Let me know if you need more assistanse.
Thanks
Sep 26, 2009 | D-Link DIR-300 Wireless Router
How do i install my WIRELESS G ROUTER without the cd
you don't need to install a router on a PC. The wireless card or ethernet cable should talk to the router.
Sep 21, 2009 | D-Link DIR-300 Wireless Router
Hi. I just configured a DLink DIR-300 wireless router on my laptop. During the installation, it required me to keep the ethernet cable connected between the router & the laptop. I finished the...
First you have to check on your laptop that your wi fi network drivers are installed correctly.
Also check it is enabled.
Also check wi fi switch on laptop is turn on.
Check its ip addreses and subnet amsk and gateway is proeprly.
Aug 19, 2009 | D-Link DIR-300 Wireless Router
D-Link DIR-300 Router not working properly
Try to configure your router again, maybe that will solve your problem.
Jun 24, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
48 people viewed this question
jasbo
jasbo
