Question about Drive Medical Odyssey 4-Wheel Power Scooter - Blue
Motor overheats and stops. Battery loses half of power in 100 yards. Have sought repairs for unit since 2008 will not replace parts.
  • 177 Answers
Hi. Sounds a bit like the motor has a short circuit in the armature. How old is the machine? How old are the batteries?
Remove one or both of the brushes, and try to smell the inside of the motor. A burnt out motor will have a strong smell of burnt varnish.
Is the machine still under warranty?
Another cause could be a seized or binding brake assembly. With the free-wheel lever released, can you easily push the machine along the ground?
Good luck. Neil.
Posted on Jul 07, 2010
Have a 2008 Chrysler Aspen. Rear drivers side window rolled half way down and stopped. Replaced switch and will not work yet. any ideas?
Yes , take it to a qualified repair shop ! You have no idea of the electronics involved , C.A.N - controller area network ,serial data communication network . How the system works ! Part stores love people like you , Making them rich . If you persist in your endeavor learn how to diagnose automotive electrical system's , how to use a DVOM digital volt ohm meter , how to read a wiring diagram . An most important Buy a subscription to alldata , identifix or from the dealer . You can't fix anything if you don't know how it works ! Automotive Repair Power Window Troubleshooting How to Diagnose Controller Area Network CAN
Aug 30, 2016 | 2008 Chrysler Aspen
What would cause a 2008 hyundai lose power and not restart?
I had something similar happen my car, literally disconnected battery half hour reset computer and it started. Dont know Why but hey car still running six months later
Oct 05, 2017 | 2008 Hyundai Accent
Situation--Having a discussion with son-in-law while sighting in my Winchester Model 94 30-30. I think it's sighted at 100 yards but shooting at 50 yard target. It is consistently high by about 5 to 6...
He is right the bullet at most will be 1/2 high at 50yards. Zero at 100 if sighted correctly. The bullet is flat to about 100 yards and will drop significantly for the next 300 yards. At 400yards your drop is almost 7-8 inches and at longer than that the bullet loses most if its effective stopping power for hunting and the drop is really significant. Not worth the effort......
Nov 03, 2013 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Timer rotates but whenever it reaches the tripper to turn the lights on it gets stuck there. It's like there isn't enough power to rotat the switch to turn the lights on. Have checked the switch...
The clock motor gets weak and sticks on the tripper and then stops working.
Possible solution: Some people report they disassembled clock motor, cleaned the gears and added a bit of vaseline or white grease to gears because they get dirty.
Then afterward, you might try duct tape to seal unit from dust
Others report they got the clock motor apart and didn't mark parts and take photos along the way, and forgot how tiny gears went back.
My experience with clock motors, and motors in general, is when they slow down, they overheat and don't last much longer.
There are no replacement clock motors for ML series power packs, which is shortcoming since Intermatic makes replacement clock motors and modules for many of their products.
Work-around: Set timer to override, then plug power pack into cheap wall timer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Jun 26, 2011 | Intermatic Malibu 300W Power Pack...
2008 saturn vue power seat stopped working. changed 20 amp breaker but was not the problem.
look under seat and check wiring and connections if good check power to the switches and test power to the motor- repair or replace damaged or burnt out part
Mar 26, 2010 | 2008 Saturn VUE
Coil pack keeps craking
The engine computer is supposed to drive sections of the coil pack in pulses. If a defect in the computer caused current to flow continuously, it would overheat and crack the coil case. Rent a scanner, read any code(s), and pursue to repairs. Replacement of the computer is likely. If so, remove the battery--the computer is bolted to the inner fender panel with several long sheet metal screws. Remove two large plugs from it's case and install the new one in reverse order. The dealer will need the number off of the old unit for proper replacement. You might be able to find one in a wrecking yard for half price. A reputable company will guarantee their parts for 90 days. You will likely need a fresh coil pack too. Hope this gets you running. We put nearly 300,000 miles on '96 Dodge Caravan, but had to replace the transmission @ 120,000.
Nov 17, 2009 | 1996 Plymouth Grand Voyager
Condenser Fan stops turning.
If you have a amp meter you could measure the amount of current the fan is drawing and compare that reading with the amperage value printed on the fan motor.
More information is needed:
Is the compressor running?
How old is the unit?
What brand and size?
Are you getting a 240v where the fan connect to the power terminals?
Aug 27, 2009 | Ruud Central System Air Conditioner
Pegasus 150 looses power then overheats
Check for a fuel filter inline between the gas tank and the carb. Replace that filter ! Also dump half a bottle of Techroline (Chevron) into the gas tank. You are starving the engine of fuel which will lose you power and can cause overheating...check your oil and change often..Techroline can also be found at your local auto parts store....good Luck to you...Tim
May 02, 2009 | 2006 Qlink Pegasus 150
I need a memory battery for a ft 50r both sides are sorderd the main board
I just had my FT-50R repaired due to a overheat issue with a reverse polarity diode. When I asked Yaesu to alao check my Yaesu for the memory battery I was told by their top technican that the radio does not have a memory battery in it. I hope this helps.
Apr 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Drive Medical Odyssey 4-Wheel Power Scooter - Blue Logo
91 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
