Question about Keurig B50 Coffee Maker
Keurig B50 My coffee maker quit working this morning. I cleaned it with vinegar and it still does not push the water through when the k-cup is in the chamber. It pushes the water through without the k-cup.
  • 1 more comment
  • boboderrick Dec 31, 2008
    Coffee maker pushes the water through the valve that empties into the holding tank..puts about 1/5 the normal amount into the coffee cup.
  • patt2000 Jan 12, 2009
    Not sure what to do now, the water comes thru to make coffee if I hold the plastic tube in the water container shut.
  • gracefilled_ Apr 06, 2009
    My Keurig B50 has started doing the same thing! I descaled the unit without any difficulty; full cups of the vinegar are dispensed through, but when coffee k-cup is added to the holder, I too, have very minimal delivery of coffee.
    Problem Solver:
  • 18 Answers
I have the same problem, but overcame it with a reusable K-cup. They are available online and at some national chain stores for about $15.00. It's a not as convenient as K-cups, but better than throwing out a $150 coffee maker.
Posted on May 21, 2009
How do you fix a keurig machine that produces only a half cup each time
Try de-liming it first. Use CLR and follow the instructions for a coffee maker. Then rinse with a vinegar and water solution. Then clean cold water. Let me know if it is fine or improves.
Aug 01, 2014 | Cuisinart Keurig B50 Single Cup Coffee...
My keurig coffee maker is flashing the words DE SCALE. What does that mean and how do I fix it?
"Scale" is deposits of minerals, etc. normally found in water. Boiling a container of water (in a pot, or coffee maker in this case), leaves small amounts or "deposits" of these minerals on and near the actual heat source. If not removed, they can slow brewing time and more importantly, adversely affect the taste of coffee.
Descaling should be done at regular intervals to prevent this from happening. Your machine lets you know when to perform the descaling task. There are a number of products sold in your supermarket that will do this for you - but one of the least expensive; and just as effective - is to use white vinegar. Here's how to do it:
1) Drain your Keurig coffee machine over a sink.
2) Fill the machine with undiluted white vinegar.
3) Run the brew process at least four times, pouring the cups of vinegar back into the coffee maker.
4) Optionally, let your Keurig coffee maker sit for a few hours, then run the brew cycles again. Pour the vinegar into the sink and drain any remaining vinegar.
5) Fill your coffee maker with fresh water. Run multiple brew cycles with fresh water each time to thoroughly rinse the machine before returning to normal use.
That's it!
I know this will help & good luck. Please rate my reply - thanks!
Feb 06, 2011 | Keurig Ultra B50 1-Cup Coffee Maker
How to descale
Use 1/2 cup white vinegar in 1 quart water. No need to let it sit. After descaling, remember to run at least 3 cycles with clean water to remove any vinegar.
Jul 11, 2010 | Keurig B50 Coffee Maker
I've lost my instruction book. Need to know how
Keurig has all of it's manuals PDF'd on their website :)
Aug 21, 2009 | Keurig B50 Coffee Maker
Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Apr 06, 2009 | Keurig B50 Coffee Maker
De Scaling instructions
Also, if you have an in sink garbage disposal, don't waste the hot vinegar.  Pour it into the disposal, turning the unit on as you pour, off when you're done.  The vinegar is mildly acidic and will disinfect the disposal unit.
Feb 17, 2009 | Keurig B60 Coffee Maker
Will not brew a full cup
there may be an adjustnent that allows more water to flow in the same ammount of brew time!
Dec 11, 2008 | Keurig B50 Coffee Maker
Keurig Coffee maker not taking in water
Mine started off that way, then quit pumping any water through the K-cup. I overcame the problem with a reusable K-cup. If it will run a full cup through without the K-cup in place, this will probably work for you. They are available online and at some national chain stores for about $15.00. It's a little more inconvenient than K-cups, but better than throwing out a $150 coffee maker.
Jul 23, 2008 | Keurig B50 Coffee Maker
Keurig troubles
Mine started off this way,then quit running any water through the K-cup. I overcame the with a reusable K-cup. If it will run a full cup through without a K-cup in place, this will probably work. They are available online and at some national chain stores for about $15.00. It's a little more inconvenient than K-cups, but better than throwing out a $150 coffee maker.
Jun 10, 2008 | Keurig B50 Coffee Maker
Keurig B50 Coffee Maker Logo
482 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
