Question about GE WJSR2080V
Making a noise when washing.
Sounds like a coin under the agitator. How does the agitator come off.
  • 1,557 Answers
In most new models there is a large butterfly knob in the middle of the agitator under the fabric sofner dispensor (take it off) undo the plastic screw take the ag out clean and replace if its an older model it will be a 10mm bolt undo as per plastic screw and replace
Posted on Jul 03, 2010
GE washer making scraping noise as it agitates, but clothes are clean and spin is normal
remove the agitator and check underneath for bra wire , coins , and any othering that are left in pockets
Aug 20, 2016 | GE Washing Machines
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
Noise under agitator There is a noise under the agitator only during wash cycle that sounds like a screw grinding on something. There's no noise on any other cycle
Theres most likely a coin in your plastic water pump. Will blow a hole in the pump at some point unless you get it removed. Average repair bill to replace pump $250
Apr 06, 2015 | Washing Machines
How do I remove the agitator from LG top Load washer
the agitator is held by a bolt with a 7/16 drive nut located inside the middle of agitator from the top downward? however by ur description sounds like maybe u have bad bearing in the hub? the cam dogs in the agitator dont usually make any noise especially when bad they just dont allow the agitator to move or catch the groves to agitate. The grinding could also be coming from something stuck inside the tub or on its outside and thus is hitting the wall lining and makes a screeching scraping sound, Ive seen this several times, a bra wire, or loose coin or key, etc
Sep 28, 2014 | Washing Machines
LG top loader slapping noise in wash cycle
Its not the usual problems found on Lg machines. sounds like you have possibly one or more coins being picked up underneath the pulsator. To check, remove pulsator with screwdriver and check .Very possibly you have a bra cup spring caught between the two drums which make an akward sound.
Jan 27, 2009 | Washing Machines
Fridgidaire gallery
From the sounds of things, you are talking about a front loading dryer. The agitators in the dryer can get coins stuck inside them. Remove the top and rotate the drum to reveal the screws which hold the agitators to the drum. Remove the screws and the agitators, empty the coins or other debris and reinstall.
The loud squeal sounds like the pad under the open side of the drum is worn out. There may also be a dry main bearing in the rear of the dryer. Lubricate the bearing and reinstall the drum. The squeal should disappear.
If this is not a dryer or a front loading washer, none of these suggestions will apply, Sorry
Feb 08, 2008 | Washing Machines
Calypso Washing Machine
There are two places a coin could be that will cause a noise. Either in the basket under the nutator or in the pump. If you hear the noise after the basket stops from the spin, look under the nutator, if you hear it during the cycle, check the pump. If you only hear the noise during the agitation, not the spin cycle, you may have a u-joint going out.
Oct 02, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
