Question about HP P910 (White) 19" CRT Monitor
I need password access HP P910 19'' CRT hidden service menu
I need the password to access the HP P910 19'' CRT Monitor hidden service menu for adjust focus on parts of the screen because of aging.
  • addysoftware Jul 05, 2010
    The password was 7711, one guy from elforum.ro gave it to me yesterday
elyse09
  • 18 Answers
SOURCE: Hp Compaq FS7600 17" monitor screen adjustment needed
Um, lets see. Does any of the buttons work? Try and find a button that will switch settings back to factory default. If not go to control panel and change the screen resolution to see if that helps in the mean time.
Posted on Jun 26, 2009
SOURCE: hp w2207h screen in blank but flashlight shows icons are
The power supply-inverter board is probably at fault. Remove the back cover and locate the standard ac power cord connector. The board that the power input connector is soldered to is your power supply - inverter board. Check the electrolytic capacitors on the board. They probably went bad. A visual inspection is usually enough to find out which ones are bad. They will be either bulging or cracked at the top and leaking fluid. I usually replace all of the capacitors that have the same rating whether they look bad or not. Will save you another repair later. If the caps don't look bad, you can take the board to your local tv repair shop and have the caps checked with a esr tester. It's more accurate and they can be tested with the caps in place. Hope this helps.
Posted on Mar 08, 2010
mahjid
  • 202 Answers
SOURCE: On starting up my computer my HP W1907 LCD Monitor
the resolution of your computer is too much for the graphic of the monitor. if you can see your mouse on the desktop screen, then right-click on the desktop, a dialog box will appear, click on properties, then settings. here you reduce the screen resolution. if this did not help then get your friend's monitor just for you to reduce the screen resolution. good luck
Posted on Jun 18, 2010
SOURCE: my hp 7540 crt monitor menu displays automatically
<div style="FONT-SIZE: 14px; PADDING-TOP: 10px" itxtvisited="1"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblProblem" itxtvisited="1">my hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.</span> </div><!-- answer --><!-- from fixya rte -->
Posted on Aug 16, 2010
SOURCE: Hpm-705 crt monitor fault?
switch prees no power on
Posted on Oct 11, 2010
What is hp service mode?
Depending on which printer, it is a normally hidden menu to allow service technicians to change things like the total page count, or the serial number, or do some direct hardware diagnostics. the actual items that are accessible in the service menu are usually found in the service manual of the printer. but different HP printers have different level of service that can be accessed.
Feb 23, 2015 | HP Office Equipment & Supplies
How to enter service mode for WS73615 tv
Model is a v-25 chassis which has 3 hidden menus:
Done with the original remote: Menu 2470 enter is option menu (hard reset etc.)
Menu 2457 enter is circuit adjust menu
Menu 2459 is convergence adjust menu
be rather careful in the circuit adjust menu and write down settings before adjusting there
Oct 29, 2012 | Mitsubishi WS-73615 73" TV
My hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.
May 12, 2010 | HP S7540 17" CRT Monitor
my monitor model is HPm705 CRT as and when i use the system the monitor screen gets switched off and on every 2mins... pls consider the issue and tell the solution for it... to get resolve......
Sep 05, 2009 | HP Computers & Internet
"monitor has a green tint AOpen f2915"
moz-screenshot.png The solution: a hidden menuwithin the main menu itself. Hold the Menu button down while pressing Power topower on, and release power button only when the screen comes up, still holdingthe menu button. The menu will appear and there will now be a hidden selection,"Auto Color", printed in a red-on-black font at the bottom of themenu. Use the +/- buttons to access it, and press Menu. My green/yellow tintwent away! Now my picture works great, and the setting lasts throughAuto-Adjusts and Resets!
May 09, 2009 | AOpen F2913-8S Monitor
Static on Screen
Is this an LCD type of monitor or CRT? either case, there's a problem with the horizontal IC. My best solution for this case is to have the unit serviced by an authorized personnel as meddling with the internal circuits of the monitor is dangerous.. Have them estimate the price for repair, if it costs too much... better buy a new one.
For CRT type of monitors: try degaussing, this feature can be found on the OSD (On Screen Display). This can be accessed by pressing Menu on the monitor buttons.
Hope this helps!
Feb 21, 2009 | HP Compaq WF1907 Monitor
MONITOR MENU COMES UP BY ITS SELF AND FLASHES
There is a problem with the IC which is the driver IC. The part number of that IC is 24LC08B. It is manufactured by Microchip. I'm sure the brand of your CRT monitor is HP. I have the same problem too and HP can't fix this problem. Even their service center can't fix it also. This is the problem usually of new HP/Compaq monitors. I think this is a factory defect problem but HP isn't doing anything to repair these defective monitors. HP sucks!
Aug 24, 2008 | Compaq FS7600 17" Flat Glass Monitor
Display adjustments
Is the H. Position not showing up in the menu? Or is it that you can't seem to get to the Horizontal positioning that is the problem? Usually there are 4 keys: Auto, <, >, and Menu (I'm NOT counting the power button of course) Menu starts off the process while the < and > get your through the menu. When you see the V. Position, hit the "menu" key and the H. Position should pop up.
Mar 26, 2007 | HP P1110 21" CRT Monitor
Need access to service menu to adjust vertical size
No service menu for this set. Sounds like you have a bad yoke winding on this one....accordianman
Oct 25, 2006 | Emerson SpongeBob SquarePants TV
HP P910 (White) 19" CRT Monitor Logo
87 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
