Question about Freezers
Freezer says that powers on & running but it is not cold
  • 1,557 Answers
Try replacing the thermist stat
Posted on Jul 03, 2010
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 01, 2011 | Arctic Air Freezers
Brand new freezer. power light is on. run light is on. I can clearly hear the compresor running. does not cool at all. ??? help
Chest freezers produce cold very slowly, so it could be an hour or more before you start to feel the cold. If still no cold, ( and I mean absolutley no cold) then you most likely have adamaged refrigerant line and the (freon) refrigerant has been lost. Take it back, or call for warranty repair.
Nov 27, 2010 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
My freezer wont stop running
either the cold control thermostat is defective or the rtc overload contactor has welded itself together and cant open and close the power contacts to the unit,un plug the cold control and see if the unit stops then
Feb 27, 2010 | Nor-Lake Freezers
Frig is not getting cold at all and the freezer is not freezing Thanks
Hi, I can help you. What brand & model# is this? Is there any frost built up on the inside rear freezer wall
Vic
May 27, 2009 | Freezers
Freezer is not running even the power receptacle is working
there are no fuses on a domestic freezer that i have ever seen. there are no fans and there are no traditional freezer coils. so you have only a few things that could be going on. if the temp is way up the thermostat should sense hot and close and send power to the compressor and it should run. you can do one of two things . find the thermostat inside the freezer usually . gently remove cover and check incoming terminal and outgoing terminal. if you show 120 volts its open and the stats bad. if you don't show 120 volts between terminal connections then its closed and the compressor is failing to start. if power is coming into the stat when checked to ground then go to compressor and see if there are starting components . they are a start capacitor and a START RELAY AND PERHAPS A OVER LOAD . SEE IF POWER IS ARRIVING AT THE COMPRESSOR. IF SO CHECK THE MICROFARED OUTPUT OF THEcapacitor . you need within 10 percent of the rated value. also you can gently remove the overload , a little plastic disc and look on the bottom side and see if its cracked or burned looking. an amp probe on the compressor will tell you what amps it pulls if it trys to fire up . 6 to 10 is good 30 to 50 is mechanically locked up and then the overload trips. if compressor is ice cold to touch then your not getting power to the compressor and its not trying to run. if its hot to the touch thens its trying but start caps weak , or its locked up. most domestic freezers are not worth the cost of a new compresssor anymore. good luck
Oct 31, 2008 | Frigidaire 11.6 cu. ft. / 328 liter...
Freezers Logo
41 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
