Question about Nokia 3110 Cellular Phone
Please give me ptt settings - Nokia 3110 Cellular Phone
  • 32 Answers
Contact service provider
Posted on Jul 03, 2010
Puxing PX-777 PTT problem
It sounds like a PTT fault as presumably the headset has its own
ptt?
Try a reset?
Jan 25, 2014 | Radio Communications
Ptt on setting
Improve the FixYa experience for everyone by voting.
Unfortunately, you have not provided me a model number and an explanation of what your exact problem is. Therefore, the best that I can do is give you a definition of PTT:
Push to talk (PTT). Push to talk (PTT) functions as a two-way radio. The PTT option is available only if enabled by the service provider.
I have no personal interest or association with any product that I may suggest.
May 18, 2012 | Nokia Cell Phones
How to got setting ptt for nokia e72-1 my operators is maxis
ptt needs subscription. afaik, maxis will stop ptt soon.
http://www.maxis.com.my/personal/mobile/vas/ptt/ptt.asp
Jun 30, 2011 | Nokia E72 Smartphone
One radio will receive messages but will not send a message
It is possible you have your PL code set differently between the two radios.
Instructions: Hold the PTT in while turning the radio on, listen for the code to be announced, use the PTT if needed to change the setting, then press the monitor button to lock in the setting. It will then announce whether it is 12.5 or 25k channel spacing. Use the PTT to change the setting if needed. Then press the monitor again to lock it in.
If you need more assistance give us a call. (google our name)
Best regards.
Oct 18, 2010 | Motorola Talkabout Distance DPS (10...
In my Nokia 3230, The message displaying again & again that "unable to switch ptt on chek ptt settings". what is the solution to stop this message
PTT means Pus to Talk.May be your Push to Talk button is damaged or stuck.PTT button situated in right side top .You can reset the phone settings by restore factory settings.Default code is 12345.
Sep 29, 2010 | Nokia 3230
VX210 GIVES 3 TONES WHEN PTT PRESSED. WHAT
Check to ensure you don't have the "WIRES" setting enabled. A common issue with Yaesu radios. You can turn it off with a combination of a "F" key press and the button that has a little symbol that looks like an atom with electrons orbiting it.
Oct 05, 2009 | Vertex Radio Communications
When I turn on the radio the indicator light on the top of the unit just flashes. I cannot set the frequency or code. When I push the monitor button I hear static but otherwise the radio is dead.
The flashing light can be an indication there is activity on the frequency the radio is set to. Pressing the monitor button should give you the white noise (static) sound, so this function is working correctly. This also tells us your speaker is working fine, as well as your volume. The typical reason you cannot go into programming mode (when you hold the PTT in while turning on the radio and hear the female voice announce your frequency) is a bad or moved internal PTT switch. This typically happens over time as a user presses ever harder on the PTT to communicate. However, this does not explain why you are not receiving. This could simply be a result of an incorrect PL code in conjunction with the bad PTT. If you have a frame removal tool, you can extract the component board and physically look at the internal PTT. You can then hold in the very small button and program the radio to the frequency/PL you desire. If you are needing the radio repaired, you can get this style unit repaired for around $69 flat rate
Jul 16, 2009 | Motorola MU24CVS UHF (4 Channels) 2-Way...
PTT Button cuts me off
Among the things which might be wrong with your radio, you could have an intermittent PTT button or a weak/bad battery. The PTT button has an internal button attached to the component board. Over time the button wears out from continued use, or it gets bent further way from the external portion of the button and simply doesn't make good contact. Also, a weak battery can give the same symptoms, as it takes more energy to transmit than to receive. Try a known good battery in the radio and see if the same problem persists. Either way, a visit to your local dealer could probably give you a free diagnosis.
Apr 02, 2009 | Motorola Walkie Talkie 2-Way Radio
Nokia 6070 ptt problem
PTT is off. Switch on now?
This message is appearing on my mobile screen and does not allows me to do anything else.
Please Help.
Jai Parmar
Feb 02, 2009 | Nokia 6070 Cellular Phone
Nokia 3110 Cellular Phone Logo
193 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
