Question about Garden
Wehave a weedeater featherlite string trimmer, how do you adjust the low and high idle screws on the carburetor?
    President:
  • 1,545 Answers
Without removing them and slotting the heads on them, a special tool to turn them is available. They have them on E-bay and sell for about $10 and up...but be careful messing with the factory settings as the carb is quite sensitive to change, unless it is so worn that it needs to be rebuilt.
Posted on Jul 04, 2010
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
What is the proper adjustment for the carburator on the h / l screws
Start with 1-1.5 turn out . Adjust, slowly, high speed first then high speed screw first, screwing until RPM increases then slows open back up, slightly. Do low speed the same way at idle.
Jun 14, 2014 | Troy-Bilt Troy-Built Gas String Trimmer...
L opened and cleaned my carburetor nw its idling very high.even if l adjust the idling screw
on a lot of weedeaters there is a holddown nut collar that
secures the weedeater throtlle cable to the motor housing . if you removed the cable from the carbuerator and loosened this collar
you can adjust the idle speed by adjustng the collar back and forth
towards and away from the carbuerator . Simple adjustment to a major headache.
Nov 20, 2013 | Garden
Two stroke weedeater starts,idles, but boggs down when gas is applied. it won't reach top end speed.
have a look on side of carby should see 3 small screws a high and a low idle screw , when running unsrew the high idle srew slightly and it should fix
Sep 18, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
How to adjust the carburtor high and low on my weedeater head cutter?
Hi jamesbj44...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns to lightly bottom the adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know when you go to replace them.
Normally you adjust your idle jet to 1/2-3/4 turn open from the bottom seated position to start with...you re-adjust when the engine is warm turning the screw in or out till the engine runs smoothly.
The high speed jet is normally adjusted to 1 1/2- 1 3/4 open from the bottom seated positon, then re-adjusted to run smoothly when running at high speed by turning the screw in or out.
Free Answer...Please take time to rate me
Jun 06, 2011 | Garden
What is the proper adjustment for the carburetor on my WeedEater Hedge Trimmer?
turn both hi and low set screws in on side of carb and then back them both out 1 1/2 turns. This is called the initial adjustment and you can fine tune it from there if needed, but only turn the screws about 1/8 of a turn at a time.
Nov 26, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Have a sears 32cc craftsman weedeater that turns on but as soon as I push thegas trigger it turns off. Put a new fuel line, spark plug and clean the carb. What should I do next?
Sounds like your idle fuel mixure is too lean, depending on how old you trimmer is, it should have 3 adjustment scews, one for the idle, one for the low idle mixure, and one for the high idle mixure. If all three are a flathead screw type you can make the adjustment yourself. look for the one labeled "low" and make your adjustment counterclock wise in 1/4 turn increments until it runs properly. you shouldn't have to adjust the high mixure screw. if you don't have the screw type adjustments, them you may need to buy a special tool (available at most lawn mower shops) to make the nessesary adjustment. make sure you leave the Idle Screw alone though( the one that move the cable) as adjusting this one will make adjusting the mixure harder to get right.
Sep 13, 2010 | Garden
Runs ok at low choke then stalls out when choke is moved up
You are having issues with you carb then. If you disassemble the weedeater partly then you will see to screws/adjusters sticking out. The one on the left side is the low idle, and the right side the high idle. You need to adjust the high idle side little by little. I'm talking a 1/4 of a turn at a time until desired results are recieved.
Aug 15, 2010 | Troy Bilt Tb70ss Gas Trimmer
On weedeater mac 85-sx whats low high set screws
fully turn in back out 1 1/4 turns start machine then fine tune adjust high idle when machine is running wide open and low at idle
Aug 21, 2009 | Garden
How to adjust mix on WEEDEATER FEATHERLITE PLUS STRING TRIMMER Model FX 260
Red=High speed and White = Low speed
Clockwise closes needle, Counter clockwise opens needle. Set both needle to 1 1/2 turns open, then fine tune from there.
Apr 05, 2009 | Garden
Garden Logo
345 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
