My computer restarts when i turn off the computer
  • 435 Answers
Most Win XP shutdown problems reported thus far have been that it reboots when shutdown is attempted. This may be a global symptom emerging from several distinct causes, because, by default, XP executes an automatic restart in the event of a system failure. Therefore, more or less anything compromising the operating system during the shutdown process could force this reboot.
Disabling the “restart on system failure” feature may permit the exact cause to be isolated: Right-click on My Computer, click Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” uncheck the box in front of “Automatically restart.”
Here are some of the things that may have produced this reboot-instead-of-shutdown symptom. Please refer below and perform the steps which are appropriate to your situation:
  • By now, the Roxio/Adeptec Easy CD / Direct CD software is well documented as being the major cause of this undesirable shutdown behavior. SOLUTION: Roxio has released new drivers (here) to solve this problem in both the Platinum and Basic editions of Easy CD Creator 5. As expected, at least half of the Win XP shutdown problems went away with the release of these patches.
    One warning about this patch comes from correspondent Bert Smith: Be sure to read the directions! “Roxio Easy CD Creator Platinum 5.0 can be a real hassle to get working under Win XP,” Bert wrote, “and there is the risk of your computer not booting if you blindly go ahead and install it without first consulting the Roxio Web site.” Bert also mentioned that Roxio’s “Take Two” backup program (normally part of Easy CD Creator 5 Platinum) is uninstalled when the Roxio patch is applied.
    • Direct CD. Many Easy CD users (but not all) found that installing Easy CD 5.0 does not cause the shutdown problem, provided they do not install the Direct CD component.
    • UDFRINST. Several people solved this reboot-on-shutdown problem by deleting the UDFRINST file. This file is part of the Roxio CD-RW software for systems not using Direct CD.
    • CDRALW2K.SYS. Correspondent Larry Blumette identified the CDRALW2K.SYS file (version 1.0.0.1048) as the Roxio file causing his shutdown problems and error conditions. When he deleted or renamed this one file, his problems went away. (Of course, you lose your CD functionality that way, too.)
    • Video Pack 5. Roxio’s Video Pack 5 causes the same problem because it contains includes the main parts of Easy CD 5. SOLUTION: Uninstall Video Pack 5 and also delete CDRALW2K.SYS (Tip from Christian Männchen). However, this solution may also have the side-effect of disabling access to your CD or DVD drive. SOLUTION TO THE SIDE-EFFECT: Apply one of the repair methods in MSKB Article 270008, Code 31 Messages Occur After Removing Adaptec Easy CD Creator 4.02c in Windows 2000 (Tip from Peter Kingsley).
  • Whether or not APM is enabled makes a difference — but the effect could go two ways. Some users report that XP reboots on shutdown if APM is enabled, but shuts Windows down just fine if APM is disabled. Other users report exactly the opposite behavior. According to Jack Dunne, this is similar to a known Windows 2000 problem. The issue seems related to the computer’s specific hardware or BIOS — so, as with all NT operating systems, stick to the Hardware Compatibility List where possible.
  • USB Connections As can be seen from remarks in the Misc. Hardware Issues section below, several different USB-related issues can impact shutdown. One of the most concrete examples was a “reboot on shutdown” problem contributed by correspondent Rick Bross. If his several USB devices (PDA cradle, flash card reader, etc) were plugged into the motherboard’s USB ports, his computer would reboot on an attempted shutdown; but when, instead, he plugged them into an external USB 2.0 hub, shutdown went just fine. (This was with Win XP Professional SP1 on a Supermicro X5DAE dual Xeon motherboard. The same devices plugged into an Asus A7M-266D dual AMD 2000MP system on the same OS worked without problem.)
  • “Wake on” power settings Power-management settings that have the computer “wake” on LAN, USB, modem, or (for that matter) probably anything else may also trigger a restart after shutdown. Correspondent Simon Wei provided this tip after a friend of his found an old old Logitech USB mouse would trigger “wake on USB” after every Windows shutdown. Their solution was to remove that particular mouse and all worked fine. The principle is much more far-reaching than this one example.
  • Hidden “wake on” power settings If you have an Ethernet card integrated into your motherboard, you may have hidden “wake on” settings that are harder to find. Site visitor Jim Porter found that his Asus P5GDC-V Deluxe motherboard had a “wake on” setting in Device Manager | Properties | Advanced rather than in the BIOS or Power Management settings. (The Asus P5AD2 and P5GD2 boards have this also.)
  • Y-SB3 Logitech Internet Keyboard can also cause this problem. If you use it as a simple generic keyboard, there’s no problem; but, if you install the Key Commander software that drives the special Internet functions, Win XP will restart instead of shut down. Unfortunately, Logitech has decided that they will not be updating this driver for this keyboard. (Tip from Jan K. Haak.)
  • Logitech MouseWare 8.6. Windows reboots when shutdown is attempted. The software caused a BSOD with KBDCLASS.SYS. Removing the software solved the BSOD the problem. (Tip from Pablo Cheng.) MouseWare 9.0 and 9.1 also have been linked to reboot-instead-of-shutdown in Win XP. Removing the software resolves the problem. (Tip from Aswin Kindts, Greg Williams, and others)
  • Webstar DPX USB cable modem. In the one case known to me, the problem was solved by switching the modem’s connector from the USB 1.1 port on the motherboard to the USB 2.0 PCI card. (The modem was provided by Telewest Broadband, manufactured by Scientific Atlanta.) (Tip from Ann L. Goonan.)
Posted on Jul 04, 2010
The WiFi keeps turning itself on. I turn it off and it turns itself back on ..
Why would you turn it off unless you are using another wifi adapter?
Most computers are set up to start the wifi when restarting the computer as default. If you don't want it on, don't restart the computer. I never restart mine, I just put it to sleep. It is dormant until you click something to make it wake. Nothing is working while asleep or hyberated. Perfectly safe, (but turn off the mouse it may wake with vibration of walking across the room).
Oct 25, 2014 | Computers & Internet
HOW CAN I RESET MY COMPUTER
if there is no reset button on your computer just restart it
first go to start, then look for turn off button. there are three options turn off button, restart button and stand by button.choose restart buttonkenthhirke_0.jpeg
May 18, 2011 | Acer Computers & Internet
My documents go in queue and never print till I restart my computer. The printer is not paused. Help!
Welcome to FixYa.
Restarting your computer is not enough for you to be able to print documents.
Here are some steps:
1. Turn off your printer.
2. Unplugged the USB cable to your computer.
3. Restart your computer.
4. Plug the USB Cable to your Computer.
5. Turn "ON" your Printer
Hope this information can help.
Thank you for using FixYa.
Mar 23, 2011 | HP PSC 1401 All-In-One Printer
How do i restart my computer
hello dear, to restart your computer, simply click on the start icon on the task bar and you will see the turn off options, if you are using windows xp, click on turn off, in the turn off dialogue box, choose restart and if you are using the latest version of Microsoft windows, beside the power option you will also see the restart button.
Dec 22, 2010 | Dell Studio One 19 Desktop Computer (Intel...
Can not print envelop with Dell 1110 Laser printer.
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
restart the computer:
  1. Click Start and then Shut Down.
  2. Click Restart.
    The computer restarts.
Nov 02, 2010 | Dell 1100 Laser Printer
The mp3 keeps restarting if you turn it on
Try and connect it to another computer the back 2.0 or laptop and format if recognized
Jun 28, 2010 | SanDisk Sansa e200 MP3 Player
How do I restart a Dell Dimension 4600 PC Desktop
Hello gabeymybabey,
If the computer is using Windows XP, do the following to restart the system:
•Click the Start button
•Click Turn Off Computer.
•Cick Restart
The computer will restart after the shutdown process finishes.
Also, here's is a link to the Dell 4600 Series user guide:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/index.htm
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 31, 2010 | Dell Dimension 4600 PC Desktop
Computer won't restart or turn off.
Be brave your computer needs to reset. turn it off with the switch and hold it untill it turns off , it is sometimess necessary to unplug as well. You wont cause any damage but your computer might want to run a check when you switch it back on. this is normal
Apr 23, 2009 | Microsoft Windows XP Professional SP3 Full...
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
Can't access software
when i turn on the computer it says something that press Ctrl+Alt+Del to restart my computer cuz it wont work and i try it so the computer restarts then when it restarts it says again that press ctrl+alt+del to restart i do it many times and still didn't work i can't use my computer
Jun 23, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
233 people viewed this question
David Payne
David Payne
