Question about Kenmore Elite 45986 Front Load Washer
Mould in water inlet assembly how to remove this assembly for cleaning. the fabric softner try never gets drained. Has a three valve inlet sysrem.
    President:
  • 1,554 Answers
Pull the dispenser drawer out until it stops then push down the release tab and pull the drawer out completely. Separate the parts then immerse it in hot water with bleach and give it good a scrub with an old toothbrush.
The dispenser drawer cavity does not need to be removed for cleaning. Otherwise, you have to remove the top panel, console, toe panel, and the front panel. Removal of the front panel requires the removal of the door lock/switch assembly and the boot be separated completely from the front panel opening. Use hot water to loosen the mold then spray it with household cleaner with bleach. Let it sit for a couple minutes before starting to scrub the molds off.
Posted on Jul 03, 2010
  • Jahn27
    Jahn27 Jul 03, 2010
    Here's a video for some washer cleaning tip including the dispenser assembly.
My bosch classixx 1200 expressnot taking fabric softner
Okay first try removing the soap try and cleaning it,secondly get a jug of water and partly fill the softner tray, at this point it should automaticly drain if not then looks like the Solonoid coil valve is at fault quite easy to replace cost of parts around £20......Good luck, hope the first part solves this......
Feb 02, 2011 | Bosch Washing Machines
Fabric softener dispensor does not empty
For the FAV6800A or FAV9800A:
If you have no water flow to the Softener dispenser or Bleach dispenser see if you can turn the dispenser valves on Service Mode and verify water flow to the reservoirs.
Enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the
Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the Fabric Softener dispenser water valve. Did you hear the solenoid hum? If so we will now need to turn on the Cold Water Inlet Valve and see if water flows to the dispenser.
Now press the Spin Only key this will turn on the Cold Water inlet valve after 5 seconds press the Off key. The washer will unlock. Check to see if water did flow to the fabric dispenser reservoir. If you heard the Fabric dispenser valve hum then most likely 120VAC was applied to the solenoid. If water did not flow then the Fabric dispenser valve is stuck closed if you heard it hum.
The Bleach/Fabric dispenser water valve is an assembly and is not repairable you have to replace.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Fabric dispenser solenoid.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price try appliancezone.com…
You can remove the Fabric Softner to clean see page 33 of the Service Manual…Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
Water Inlet Valve Replacement Procedure
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
The fabric softner dispenser does not release the liquid softner
The fabric softener solenoid valve is faulty and must be replaced. It is sold as an assembly with the bleach solenoid valve with part number 997846. You need to remove the front panel to lift the top panel to inspect or replace the valves.
Front panel removal procedure:
  1. Unplug the machine.
  2. Turn off the water supply.
  3. Open the door and remove it by removing the screws on the hinges holding it.
  4. Remove the remaining two screws on the opposite side along the inside lip of the door opening.
  5. Press in on the outer upper edges of the front panel posts then twist it inward to release it from the clips on the face of the cabinet.
  6. Tilt the top of the front panel away from the washer and remove it.
  7. Remove the four screws holding the dispenser bezel to the top of the top panel.
  8. Remove the 5/16" hex head screws securing the two hold down brackets on the top panel.
  9. Swing the hold down brackets to the outside to unhook it from the slot in the top panel lip.
  10. Lift the front of the top panel and tilt it toward the rear of the machine.
  11. The dispenser valve assembly is the one on right of the water inlet valve assembly where the water supply line is attached to. The fabric softener dispenser valve is the one on the right most.
  12. Clean the terminals and the connector of the fabric softener dispenser valve.
  13. Grab a multimeter and check the resistance between its terminals. The resistance should be between 500 to 1000 ohms. If it reads open, replace the dispenser valve assembly.
  14. Remove the wire harness connections to the valve solenoids.
  15. Loosen and remove the hose clamps on the hoses.
  16. Loosen the valve mounting screws by turning it at least three full turns.
  17. Slide the valve assembly to the left and remove it from the bracket.
  18. Place a towel below the valve and remove the hoses.
  19. Install the new dispenser valve assembly in reverse order.
  20. Install the top panel, dispenser bezel, front panel and the door in reverse order of the removal procedure.
Jan 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine fabric softner problem
Remove the detergent compartment itself and clean it all up. Usually such problem is caused by blocked hole for softener. otherwise check coil continuity of the orange coloured water inlet valve
Update me about your progress
Jul 20, 2009 | Washing Machines
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Samsung frontloading washer won't dispense fabric softner
clean filters in washer inlets on back of washer. take off hoses and look up inside of inlet, pull out the filters by pulling stright out on them. then fush backwards to get sand or whatever out of fiter
Dec 30, 2008 | Samsung WF337AA Front Load Washer
E10 error and fabric softner
Close your inlet valve at the wall. Unscrew your washer hose to examine any blockage in the small filter screens; clean out thoroughly and refit carefully, check for any water leak on opening the valve fully. If you have 2 inlets for the machine it would be good to get an F or Y adaptor.
Pl rate if helped................
Jan 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
Erroe code F H
jse, most of the time when I run into this problem it's because of the flow meter. This is a reed device that sits in line with the water inlet valve and monitors the water coming into the machine. Things to check; make sure both water valves are on and that the inlet valve screens are clean. (You get to them by removing the hoses to the washer). The drain pump filter is clean. (Remove the bottom panel and unscrew the pump filter and clean out). The inlet valves are actually working. That the drain hose is not too far down the standpipe causing a siphon. All the harness connecting to the inlet valves, pressure switch, drain pump, flow meter and main control are seated properly. You will have to remove the top to get a look at these. Three screws on the top backside and it slides of toward the back. If all these things check out. Then I would suspect the flow meter itself. Easy job. Catriver..
Jun 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Mar 03, 2007 | Tricity Bendix AW1000W Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
100 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
