Question about Bosch Classixx WFC 2465 Front Load Washer
Drum does not go round on any cycle. - Bosch Classixx WFC 2465 Front Load Washer
  • 1,557 Answers
Sounds like either a broken belt drive or burned out drive motor if you can hear the motor running then i would say its the belt
Posted on Jul 03, 2010
Spin cycle does not work on simpson genisis 511 and drum is very stiff to turn round
Bearing had crashed. Replace the drum bearing. Or the drive motor has failed.
Feb 06, 2014 | Computers & Internet
Drum not going round on any cycle, empties and fills ok
check if drive belt still on the drum rear.. if so then you need new brushes on the motor...
easy fix cheers
Jun 05, 2011 | Washing Machines
Drum doesnt go round and machine wont spin when it reaches this part of the cycle
The programmer may be faulty. check the drum belt and cable connections
Feb 06, 2011 | Washing Machines
Drum not rotating on washing machine
change the carbons in the motor
Jun 28, 2010 | Washing Machines
Hi Friend,
welcome to fixya....
may be the drum belt is the fault, Here are some possible causes of a washing machine belt coming off :-
1.The drum pulley is loose
2.The drum bearings have gone (collapsed) causing the drum pulley to wobble
3.The drive belt was to slack
4.A motor fixing bolt or bracket securing the motor to the tub has broken or come loose
5.Water has got onto the belt causing slippage
6.An obstruction or item of clothing temporarily jammed the drum causing the belt to spin off ,,,,,,,,,,,,
first check whether it is hard to turn the drum if not then check the above situations,,,ok
if you think that i helped you please rate it\\\\\\\\
thank u...
Apr 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My Candy automatic washing machine will not spin
Try the drive belt from motor to the drum it could have stretched a little? The noise you can hear could be the heating element catching the inner drum or something like a wire from a bra came loose in a wash and is trapped between the drums ?
Nov 05, 2017 | Candy Washing Machines
The drum wont go round
either motor faulty or carbon brushes worn down take motor out and inspect
Jul 08, 2009 | Washing Machines
Wont go into spin cycle
will the drum go round when on a wash. and is it drianing water out if the drum goes round its not your brushes. if it not emptying water you pump as gone and will not spin if there is water in the drum
Jun 28, 2009 | Kenmore Washing Machines
Washing machine problem
That means that there is either a problem with the belt, or with the drum bearings.
The machine should be inspected by a technician.
If you want to get repairs for your appliance you can call the number listed on the owner manual.
Oct 16, 2008 | Washing Machines
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
184 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
