Question about Whirlpool Duet GHW9150P Front Load Washer
Dial reads control locked. Will not operate. - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance. This feature can often be set unintentionally and usually is not an indication of an actual problem with the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Posted on Jul 03, 2010
My control panel reads loc why want it turn on
child lock is turned on , controls wont operate if child lock is on (safety)
holding down stop for 30 seconds usually on most models turns off child lock
Oct 20, 2015 | Washing Machines
My right side passenger door does not lock automatically anymore. Is there a fuse that operates this.
no all is related to one fuse you can remove the door internal controls and decore and remove center lock motor plug and test two connectors with multimeter with set on 12v and then lock un lock door and check the reading of the multimeter if it read signal then all plugs and wires from central lock control unit to the door central lock unit is okay it this cae you have to replace the door central lock unit with the same if no signal is readed while you lock unlock the door then you have to check central control unit and all wire plus out of it to the door plug
2- you can remove central control unit from driver door and test it in passenger door (usually the same unit ) if it works with lock unlock its then the replaced unit is faulty and needs to be replaced if it not work then check plugs wires from central lock unit (usually found inside driver door ) to the central lock unit in passenger door
3- check signal for said door fro the output of central door unit if no signal then it mean that faulty central lock control unit
Feb 23, 2015 | 2005 Honda Accord
How do I read the owners manual for model FGRB6600FSO
Instructions Operating Problems
  • 1 Check your dryer's power supply. Reset any flipped breakers, and replace any blown fuses.
  • 2 Open the door, shut it and press "Start" to be sure an open door isn't hindering the dryer's operation.
  • 3 Turn the dryer's control dial beyond "Off," into a cycle selection, before starting it.
  • 4 Check the gas supply valve. An opened valve will appear parallel to the line. If it is perpendicular, turn it to open it.
Jan 15, 2013 | Frigidaire Electric Dryer
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I do not know the passcode for my phone
Resetting Phone Settings
Resetting the device restores all of the factory defaults,including the ringer types and display settings.Onboard data such as Contacts, History, Scheduler,and Messaging are not affected.
  1. Press Home and touch Main > Settings > Reset> Reset Settings. (A disclaimer is displayed.)
  2. Read the disclaimer, write down the lock code, and touch Proceed.
  3. Enter the lock code provided on the disclaimer by using the onscreen dial pad.
  4. Touch Done to reset the device's settings.
Resetting Phone
Resetting the device restores all of the factory defaults,including the ringer types and display settings and deletes all content stored on the phone.
  1. Press Home and touch Main > Settings > Reset> Reset Phone. (A disclaimer is displayed.)
  4. Touch Done to restore all factory settings.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.*Disclaimer:Performing a master clear/master reset/hard reset will erase all your data (photos,videos,contacts etc) completely and reset all the settings to Factory default. The information contained in this website is for general information purposes only.In no event will resetcellphone.com be liable for any loss or damage including without limitation, indirect or consequential loss or damage. For complete disclaimer notice please visit Disclaimer. The brand names are the registered trademark of respective manufacturers.
Sep 06, 2012 | Samsung SPH-M800 Cell Phone
Having keypad issues with my HTC EVO. It locks up and the only thing I can do is turn it off. The #pad for the phone dialer malfunctions in that it will read the incorrect numbers from the middle set
It might be a software update problem, or touch screen need to replaced, got ur dealer Incase u have warranty, they will solve it without a penny. Good luck
May 15, 2012 | Google Android
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Whirlpool Duet dryer
look for a button with lock symbol beside it press and hold button 3-5 secs lock light should go out and control resume operating
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
