Have paper stuck and handle will not go back to lift all the way.
    President:
  • 3,085 Answers
Let me guess, India
Posted on Jul 03, 2010
I replaced the #1 drawer for a RICOH MPC2051 after install it keeps saying on the screen add paper to tray 1 and the paper tray is full? can you help. James
Take of the lower back cover and check the lift mechanism to see if it is lifting the paper. Make sure there no paper debris stuck behind the cassette.
Apr 03, 2017 | Ricoh Office Equipment & Supplies
Hp p1606dn printer paper jam under the toner
Have you tried to lift the green handle from right of the metal plate that sits under cartridge? If you cand see the piece of paper, maybe you can grab it with a tweezers. Otherways you will need to remove the front dor assembly and then the feed/transport section. With some technical skills, you will succed to put it back, but don't start if is the first time you disassemble an printer.
May 14, 2014 | HP LaserJet 9050 Printer
Kyocera paper jam duplexer
The duplexer unit is located at the bottom of the printer. You have to remove the paper cassette first. Second, tilt the printer a little on the back side. In place of paper cassette, you will see an iron plate with a green handle in the left. Push down on the handle and the plate will go down. You may find paper jam there or pice of paper stucked. Release the handle and put back the printer and paper cassete, then open top cover and close it down. You may have paper jammed also under developer unit, or in the fuser section. Verify there, if the first solution won't solve the problem.
Apr 07, 2014 | Kyocera FS2020D ECOSYS Monochrome Laser ...
Brother 2170W, toner is stuck after paper jammed. I try to pull out the toner (even with force!) but it stuck, there is a paper at the bottom that i can't pull either. I guess this paper holds the...
If the paper get stuck inside the printer you can also remove it fro the back of it. Open the back cover and try to remove the jammed paper inside of the printer. If still the paper can't be remove try again to removed the drum and toner.
Open the front cover or pull down the cover right above the brother logo infront of the machine then hold the handle of the drum and toner assembly.Pull the drum and toner assembly towards you, just put a little force on it. Then remove the jammed paper.
Just to make sure, remove the toner from the drum by holding down the tab on the side and lift the toner out. Look for any small piece of paper inside of the drum unit. Reinstall the toner back to the drum. reinstall the drum and toner back to the machine, make sure that you here a click sound. After that close the front and back cover.
The blue light should lit up again.
Hope this helps. Thanks
May 06, 2011 | Brother HL-2170W Laser Printer
The lever to adjust bowl height will not move.
most of the times it is because of build up between lift handle and pedestle case use wd-40 and even some heat from a torch to help loosen up stuck handle. also wd-40 the ways on the mixer ped. where the bowl yoke is
Dec 15, 2009 | Hobart A200 Stand Mixer
How do you get the toner cartridge out of brother 2040? we have paper stuck under it
The toner and drum come out together, open the front door and pull the handle in the center straight out toward the front. The toner lifts off of the drum by pushing the blue lever on the right or left rear side and lift up and out. You need to inspect the underside of the toner and drum for paper scraps that could cause jams.
Nov 12, 2009 | Brother HL-2040 Laser Printer
Paper misfeed how do i open side cover to expose stuck paper?
Very Simply
If you have a Duplexer on it their is a Latch or handle pull the Handle towards the side direction
>>>> this way then after that there is a latch near the from lift that latch in the UP direction
then the side door will open and then remove paper.
Sep 09, 2009 | Toshiba E-Studio167 Copier
Stuck in incline position
Hi.
If you look at the front left side of machine there is a removeable inspection port it will have 2 coloured buttons you press these in & pull it up to remove.
Now pull handle back as if vacuuming the floor.
Now where the inspection port was you will see that there is a square hole pull forward on the flap in front of square hole it pivots just behind the round rubber seal.
Slowly lift handle back up at the same time The part with the 2 long grooves in it must go under the flap as you lift handle.
Chris.
http://dysonmanuals.llc.nu/
Aug 11, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
PAPER JAM IN AN CANON IMAGERUNNER 400S COPIER. IT SAYS TO LIFT FRONT COVER AND THEN LIFT LEFT COVER. I DON'T KNOW HOW TO OPEN THE LEFT COVER.
Open the front door and do you have a sorter on it? If so, you need to move it away. The finsher has a bracket and right under the bracket there is a handle pull the handle up and find you will see your jamed paper. Also, look at the duplex area under the transfer unit. It has a green handle lift it up and maybe find a jam there. You may have found it by now
Jul 10, 2008 | Canon imageRUNNER 400S Copier
Paper tray stuck
On the Brother DPC130C
Take off the back cover, sort of triangular piece of plastic.
Take power cable out, turn the device on its side and look at the back in the centre there is a white piece of plastic lift that up with a ruler or such device lift the white plastic thingo and slide the tray out.
Don't forget to put all pieces back in place before using printer.
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
21 people viewed this question
k24674
