Question about Samsung CLX-2160N All-In-One Printer
Constant paper jams (paper does not feed through)
    President:
  • 670 Answers
The problem is probally the feed rollers are either dirty or worn. If they are dirty they can be cleaned with a damp soft cloth or a foam brush. Hope this helps.
Posted on Jul 03, 2010
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
Constant paper jam on Canon PC735 copier. Tried all the usual steps to removing or preventing as paper jam, and they are not helping. The problem started after the cartridge was removed and rocked back...
If the machine did not show a paper jam until the toner cartridge was removed and then reinstalled, I would remove the cartridge and check the paper path for the paper switch, it normally is a small black lever. Make sure it isn't stuck in the down position. If the switch is OK, check the cartridge to be sure there isn't any damage that may cause the paper switch to be actuated when the cartridge is installed into the machine. Sometimes there is a protective cover on the cartridge that moves when installed, this cover can be knocked out of place.
Jul 19, 2017 | Canon Office Equipment & Supplies
Brothers intellifax 2820 - constant paper jam front and back
Among the most common problems with any make of printer are paper jams. A printer will jam for any number of reasons: It's dirty, the wrong paper type is being used, or the rollers on the printer that feed the paper through its pathway are worn down. While cleaning the printer periodically and using the correct paper type are easy fixes, if the problem still persist after all this, replace the roller.
Take care.
Oct 31, 2010 | Brother Office Equipment & Supplies
Only 8 1/2 by 14 paper jamming at the DADF
Does it feed sometimes, and just jams frequently, or every single page?
Are you sure the paper size in the tray is set correctly? Otherwise for frequent or constant jams when the paper simply stays in the tray, then the feed rollers are likely worn out.
Mar 16, 2009 | Office Equipment & Supplies
Printer says it is jammed
unplug printer from wall for 12 secs and plug back in
Jan 15, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
PAPER JAMS
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Office Equipment & Supplies
Samsung CLX-2160N All-In-One Printer Logo
825 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
