Question about Radio Shack Pro-2052 Scanner
Scanner trunks, won't scan
My radio shack scanner, believe pro2052 trunks but won't scan other channels. Also the words search & data continously stay lit on the screen, don't beleive they were on there before.
Works in trunk mode onlly
Posted on Jan 08, 2011
I can't turn off the squelch on my Radio Shack Digital Trunking scanner.
On all channels, or on one channel ? Some channels are "birdie" channels, check your user manual. Others are problem channels receiving false signals from computers, monitors, receivers, internet equipment, FAX machines, etc. If your in conventional mode, if in Digital mode the squelch is set by the processor, and I don't believe the squelch has any effect in that mode.
Sep 18, 2014 | Radio Communications
I am looking for software to program Uniden SPU480K Handie Talkies
http://download.cnet.com/scancat-gold/3000-2130_4-10041190.html Scancat-Gold for Windows is an 'All in One' computer program to take control of your Police Scanner or Shortwave Receiver. Scancat supports all radios within one program. We support most popular manufacturer's radios such as: AOR, ICOM, KENWOOD, JRC, UNIDEN, YAESU RADIO SHACK. New trunk tracking support has recently been added for models such as the BC780, BC245, BC895 Uniden and PRO2052 Radio Shack. Hope thie helps
Aug 04, 2011 | Computers & Internet
Scanner works in trunk mode will not scan regularl mode
If it is an older pro 2052 they dont scan trunked and conventional at the same time. The newer models do both.
I'm not sure what tear they changed it but search Google for an answer.
Jan 06, 2011 | Radio Shack Pro-2052 Scanner
HOW DO I ENTER FREQUENCIES AND SCAN.
Unlike most every other RS scanner, the 2052 has Uniden firmware, and is fully PC controllable. If you have the cable and CD its easy or download the software here. http://www.qsl.net/kd5lmy/software1.htm
If not, download the manual here.http://mirror.bachelorsgrove.com/pro2052/
Aug 02, 2010 | Radio Shack Pro-2052 Scanner
Problem with PRO-2066 scanner not receiving local 800mhz Motorola trunk system II. It does trunk with the current data channels used (showing the ---- line) but I only hear transmissions on freqs ending...
It is difficult to explain in simple terms but I will try.
Google rebanding.
Some radios can have their firmware updated but I don't think your PRO 2066 can.
Channel numbers and frequencies preprogrammed into your scanner have changed over the past few years.
When a data signal says go to channel X that channel is now Y, but your scanner is still looking for X
Hope this helps
Aug 21, 2017 | Radio Shack Pro-97 Handheld Scanner
When scanner is turned on it says all channels are locked radio s
If this is a trunking scanner, then you can go to your local radio shack store and have them reprogram the scanner with your local frequencies. This does sometimes occur if the trunking is not set correctly.
luthierrick@yahoo.com
Jan 24, 2010 | Radio Shack Pro-96 Scanner
Pro 82 Scanner from Radio Shack problem!!
While its in scan mode press the # of the channel to select.. you will see the bar go under the # Then it will scan the channel
Jun 04, 2009 | Radio Shack Pro-82 Scanner
Pro 95 dual trunk tracking scanner just stays on channel 3 does not scan up to the other 10 channels
the manual at "http://support.radioshack.com/manuals/ome20-525.pdf" (if you don't have it)
says that you may be in manual mode OR that the channel at 3 might be a "trunk guide", that means that the channel is used to send out digital permissions to the system for each radio in the unit(s) to use a certain freq. when they transmit. good luck!
Mar 04, 2009 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Scanner Model # 20-527 1000 channel triple trunking
The manuals for radio shack equipment are available on the Radio Shack website. I just viewed and downloaded the one for the 20-527 last night and that is an older unit. In the search window, put in the Cat number, and searched it. If this doesn't work search the word manuals and try that. You can totally re-initialize the 20-527, those instructions are there too. The disadvantage; you loose all your programmed information and will need to start over. Which is ok if you'd like to start fresh again.
Jul 13, 2008 | Office Equipment & Supplies
Edacs frequencies
Are you getting talkgroup ID's? If not, you're probably monitoring the EDACS system in conventional mode rather than trunking. When the scanner hears those beeps, it's supposed to go back to monitoring the control channel if you're in either trunking mode (search or scan). This also happens if the CC isn't coming in very well. If you're not in trunking mode, read the manual to find out more about programming and monitoring trunked systems. If you are in trunking mode and receiving ID's, the unit is probably malfunctioning.
Sep 23, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-2052 Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
