Question about Keurig B60 Coffee Maker
Pump does not prime, sometimes does not move water
Pump does not prime sometimes does not move water into brewer.
  • Anonymous Mar 21, 2014
    prime shows on screen will not pull water into brewer
  • 3 Answers
I had a similar problem and I found the symptoms misleading! I used a pin to clean the upper needle and I found that after I did that the pump worked again. Not 100% sure it will work everytime, but cheap and worth a try!
Posted on Jul 11, 2010
Http://www.youtube.com/watch?v=v09GbrnAsPI&NR=1
Posted on Aug 04, 2010
    Problem Solver:
  • 8 Answers
If this is a newer unit contact Keurig and they will probably replace it. They did for me but now the new brewer is starting to do the same thing. Good luck.
Posted on Jul 03, 2010
NO COLD WATER
"Solenoid". No, you probably don't need one. You shouldn't even HAVE one.
I suspect strongly that you need to prime the new pump. There should be a priming plug on the top of the pump. Remove the plug and pour water into it. Replace the plug quickly and turn on the pump immediately.
You may need to do this several times before the pump starts drawing water. You can hear the change in pump sound when it starts moving water.
It does help, while you're priming, to close any valve you find between the pump and the pressure tank. As soon as the pump draws water, slightly open that valve or the pump will cycle on & off very rapidly. When the pressure tank is pretty full of water (you're getting fairly significant pressure on the gauge), open that valve fully.
I always liked to have a globe valve on top of the pump with a bell reducer and cap above that for priming purposes. The globe valve permits VERY fast pump repriming, and the bell reducer acts like a funnel, making it easy to pour water in. With the globe valve closed (normal operation), the cap doesn't even have to be tight - I need no tools to prime my pump that way.
Jul 28, 2014 | Washing Machines
My swimming pool pump is loosing it's prime
is there enough water in pool sometimes skimmers suck air also check the intake union of the pump you have a leak in one of your intake lines
Jul 12, 2014 | Pool & Spa
Won't disperse the water. The left side is very hot after 3 tries.
I assume you hear the pump running, and you are not using a k-cup. No water comes out of the empty k-cup holder, and no water comes out the left rear side drain (back into the water tank).
Perhaps a line is totally plugged up or a valve is stuck, and the pump is over heating from having to work too hard with no water moving through to help cool it.
Try squeezing the drain closed then open then closed a couple of times during a brew cycle and see if this changes things. I doubt it will, but this action can cure some pump priming problems.
Remove the water tank, and be prepared for more water from the brewer while you take this next step. Turn it upside down and spank its bottom, hard, a few times. This has freed obstructions for other users. But if a tube/valve is totally blocked, this may not dislodge anything.
The ultimate thing is to take it apart and check each line and valve for obstructions. This is not an easy task, and will take Torx(r) style screw drivers, needle noise pliers, and probably wire nuts.
If you can get it to pass any water, do a de-scaling just as if the de-scale light had come on. I'd use CLR(r) cleaner (which is stronger than the vinegar called for in the de-scale instructions), and run a extra couple tanks of water through before using the brewer. Check the odor/taste of the last flush to be sure all the CLR is washed out.
Unless you're a bored DIY with an OCD symptom for making the brewer work again, I'd start watching the sale ads for a replacement.
May 21, 2014 | Keurig Elite B40 Coffee Maker
Wont prime.just moved in house and pump goes to lake.turn it on and it runs but no water.do i have to prime
yes fill it with water from top plug and turn it on and keep adding water til it picks up
Sep 02, 2013 | Myers Pump HJ50S
When i turn it on it says not ready. you hear the pump come on and the water starts comeing out. it wont stop until you turn it off
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 05, 2011 | Keurig B70 Coffee Maker
Water doesn't always want to pump through the machine. If I fiddle with the water level - it will go through, but then it drips for a while. Additionally, the machine says to descale, I have run...
heatman101
Jun 24, 2011 | Keurig Platinum B70 Coffee Maker
My coffee maker shows PRIME what does that mean
The pump is not getting water...slam the tank down or bang on the side of the unit...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Mar 04, 2011 | Keurig Platinum B70 Coffee Maker
I have a flotec water pump that sits on top of my pressure tank, pump worked ok last season, and when we tried to prime the pump to start this season, it wont pull water up from the well pipe, pump will...
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Apr 06, 2009 | Flotec Corrosion Resistant Shallow Well...
How to prime my Pool?
Prime is the term we use to state that the air has been mostly purged from the pump and the pump is moving water. When you have lost the prime, your pump is no longer pumping water through it. Sometimes it can be very difficult to regain the prime on the pump. This will tell you how to get the prime back in these difficult situations
Aug 27, 2008 | Intex 2500 Gallon Sand N Sun Pool...
Keurig B60 Coffee Maker Logo
1,594 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
