Question about Sony new- Mz-b10 Mdlp Minidisc Recorder W/voice Mirror
Suddenly the record button won't work...it just won't depress or light up...it has always work so well. Can you tell me what the problem is?
  • Sony Expert
  • 509 Answers
Check your disc - do you have the little tab slide over to prevent recording? (like a cassette has on the top)? Also, very important with MiniDiscs, or home CD recorders, when you press STOP, you still need power for another 30 seconds or so for the unit to write the TOC - table of contents. Without the TOC, your disc cannot find where anything is. So , make sure you have a FRESH battery and/or AC adapter when recording. Try a new blank disk with fresh batteries, okay?
Posted on Jul 15, 2010
My pilot light will only light after i heat the thermal coupler. Even with the button depressed gas won’t flow to pilot until heat on thermal coupler is applied. Is this normal?
No this is not normal .The pilot should lite first then when you hold button down until thermocouple sense the flame and tell pilot to stay Lit .
I think you should change out the whole pilot assembly.
Does this pilot needed to be lit manually or has a sparker
Feb 23, 2018 | Heating & Cooling
How do I fix 1996 Rav4 brake lights always on?
You may have a bad brake liggt switch or just need to adjust it. It is found on the back side of the brake pedal. When the brake is depressed the button should come out when released the button should be depressed telling the lights to come on or go off
Sep 03, 2014 | Toyota RAV4 Cars & Trucks
Changed Assigned CO numbers
Try Googling (Panasonic)(KX-NT343)(manual) without parens or contact Panasonic directly to request a copy.
Oct 26, 2017 | Panasonic KX-NT343 IP Phone - KX-NT343
Sony PS-LX250H Player arm won't set down to play
Have you made sure the "up/down" button is not depressed? It's the furthest button to the right of the player if you are looking at it head-on. If it is depressed, it will cause the needle to simply hover above the spinning record. A good thing if you want to "pause" your musical experience, but not much help if you are trying to enjoy some sonic sensations.
Nov 23, 2012 | Sony PS-LX250H Turntable
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
Buttons not always working
Mine had that trouble too. Sometimes worked and sometimes stop working the buttons. I depressed some of them, random and angry and suddenly came back to work again.
Jan 14, 2012 | Pentax Optio 33LF Digital Camera
Red record button will not depress to start recording
Check that you have not knocked the record tab out of the tape you are using.  Try a new tape.
May 28, 2009 | Panasonic RN-405 Handheld Cassette Voice...
05 katana new bat new starter new relay still won,t start when I push the srart button when i push the starter button head light goes dim.
check these things: is the engine run/stop switch pressed? is the bike in gear? is your safety switch always depressed?
Apr 05, 2009 | 2006 Suzuki GSX 750 F (Katana)
When shutter depressed "AF" and "SB" LED's flash
My camera's shutter will not depress all the way due to a red flash light coming up all the time in the Flash-Ready indicator lamp (refer to pag 28 in the Nikon manual). It can be full sun outside but it will not work due to the red flash light coming on.
A work around is to select a flash mode of 'cancel'.
There is a button toward the front of your camera called the flash mode button. Click that until you see strike mark on the flash icon of your monitor screen (see page 32 in the Nikon manual).
The camera must have a malfunction of determining the lighting so it always thinks you need to have a flash on the picture. Of course this is not 'fixing' the flash/lighting issue but you can take typical day pictures for now with this work around.
Dec 17, 2008 | Nikon Coolpix 5400 Digital Camera
Cant erase
To select your message to erase depress REC/STOP button. Then "scroll" thru recordings by using the "rocker" style switch on the upper right side of recorder labeled INDEX. When you have the recording on the LCD display you wish to erase, depress the ERASE button for more than a second and release when the display starts blinking "ERASE" - then depress the ERASE button again and the recording will be erased. Do the same for each numbered recording to fully erase all recordings.
Apr 08, 2008 | Sims SVR-B445 Handheld Digital Voice...
Sony new-  Mz-b10 Mdlp Minidisc Recorder W/voice Mirror Logo
95 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
