Question about Samsung RB1955VQ Bottom Freezer Refrigerator
Samsung RL36SBMS keeps cutting out, it runs for a few hours the stops and gets warm if i turn it off and on again at the panal at the front it will start working for a while? any ideas?
  • Anti-Cowboy Jul 28, 2008
    My fridge/freezer (Samsung RL36SBMS) has worked fine for 3.5 years. Then a few days ago, it starts making a rattling sound. Then a couple nights ago (after rattling for 3 days), it turned itself off in the night. Now, if I turn it back on, it runs for about 1 minute, the rattling starts, and then it turns itself off. The temperature display then lights up the number 5 only, which must be an indication of a fault.
    The user guide from the Samsung is useless and provides no guidance as to what it means.
    So far, I have tried to defrost it, but no luck. Any ideas?
This is not a full solution, but I'll tell you what I did. Somewhere along the way, something worked.
First, I defrosted for about 48 hours. I turned it on, and the same thing happened, as if it was broken.
I took off the back panel (and also the support for the ice rack) mostly. I got all but the top bit off, so it hinged on the top (I was afraid of breaking the plastic. I checked that there was no ice around. I spun the fan, and wiped the grooves where the air flows (to clean it off a little). I put everything back together. It was tricky making sure the wires on the left did not get caught.
Bizzarrely, having disassembled and reassembled everything, it all started working again as if there was no problem.
Incidentally, the blinking light under the "5" seemed to indicate it was in test mode. I tried to somehow get it out of that by holding down buttons for 8 seconds or so, but that did not seem to work.
If this or something else works for you, please do post, but at least this worked for me, and it is worth a shot before buying a new fridge.
Incidentally, I have read enough to know that I will not buy a Samsung fridge again.
Posted on Jul 28, 2008
Posted on Sep 07, 2009
Starts and cuts off
serial number/keygen for registry reviver
Jan 28, 2014 | Cars & Trucks
Engine acts like it is out of gas keeps stalling i can turn it off for a few minutes will run for a mile or two then does it again
Vent valve has failed closed or cannister is clogged up. Have the evap system checked from the tank to the charcoal canister. If you need to drive to a mechanic, try driving with the gas cap loose.
Dec 16, 2017 | Hyundai Motor 1999 Elantra
Why is my samsung fridge is power cut off when the door open
fridge indoor bulb wiring short,check the wiring line
Mar 29, 2012 | Samsung Refrigerators
Ac goes from cold to warm shut off the ignition and it works again for awhiile then goes warm again
How long does it run for before going warm?
What is the outside air temp?
Does it do the same thing whilst parked?
Does it ever cut back in on it's own [wait a few mins] or do you always have to turn the ignition off?
Some possibilities:
The over-pressure cutout is operating.
Can be caused by the condensor [in front of the radiator] becoming blocked up with to much rubbish restricting air flow, or the a/c auxillary fan [usually in front of the condensor] is not cutting in which could be a bad motor or refrigerant pressure switch is not operating.
Another is that there's a refrig, gas leak and enough gas has escaped so as to cause the low pressure switch to stop the compressor.
When the a/c is first turned on, there is enough pressure for the compressor to run, but as it runs, the low side goes too low and cuts out the compressor.
Aug 08, 2011 | 2004 GMC Sierra
How to reset house alarm after power cut
alarm may be in battery back up mode when power is lost it will automaticly start running off these batteries that are usually located in the panel. diffrent devices have diffrent ways or restoring regular mode. i would contact the maker.
Feb 27, 2010 | Lorex 4 Channel Business & Home Security...
Heat isnt working...place on heat and turn on but it just stays cold?? Its been like this for like a week or so..it was doing this then started for a few days where it would kinda get warm again and then...
Try bleeding the air out of the cooling system. At the front of the engine, on top, should be a bleed valve. It's small, and looks similar to a grease fitting. This is the highest point in the cooling system and eventually all air in the system will accumulate here.
Make sure the coolant reservoir is serviced to the correct level. With the engine cold, but running, open the bleed valve until coolant starts coming out. Close it and wait for a few minutes. Keep opening it intermittently until no more air bubbles out -- until the engine is warm.
Oct 24, 2009 | 2002 Dodge Intrepid
Starts well,runs wellfor five mins but then cuts
My first guess would be the fuel filter. It is probably almost completely plugged.
Oct 23, 2009 | 1991 Volkswagen Passat
Samsung RL36SBMS Bottom Freezer problem
LOW HUMMING NOISE COULD BE THE COMPRESSOR CHECK CAPACITOR
Aug 19, 2009 | Samsung RB1955VQ Bottom Freezer...
It just won't keep running after running fine a while.
PROBLY NOT TRIP CHARGES ARE AT LEAST 45.00 AND THEN 65.00 PER HOUR PLUS PATS WHICH ARE EXORBENT
May 20, 2009 | Mitsubishi VS-55707 TV
Samsung RB1955VQ Bottom Freezer Refrigerator Logo
1,493 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
