Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
We get a f1 code and some times a fl code - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 1,557 Answers
There is a big problem with your p.c.b bord the main computer in some cases if you contact wirlpool they will fix this for free as it is there fault its a malfunction many thousends of people has endured the units should have been recalled but wirlpool have simply decided to replace the units parts and labour should be free call them and be stern to them and they should come out and fix it at no cost to you if they dont email me and my company will see what we can do to help you perswade them
good luck
Posted on Jul 03, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: oasis he washer error code F1 or Fl
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
What dose a FL code mean on whirlpool cabrio platinum
I will try and help for some reason Whirlpool likes to flip letters around which differ from the service manual FL would be an LF long fill or is it a F1 the model doesn't show in the Whirlpool data base nor parts suppliers I suspect wtw6600sb1 does the machine from initial start fill correctly then wash if so we can eliminate the pressure switch and hose after wash cycle unit should drain then fill with rinse water if the inlet valve does not let water into the machine to satisfy the pressure switch the control times out and flashes a long fill code this unit has a log valve system possible you have a bad inlet valve on the bank of valve or a bad control not outputing voltage to the valve, hope this points you in the right direction
Jan 14, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
I turn on the top load washer ,it starts to fill
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 13, 2009 | Kenmore Washing Machines
What does F1 means
Could it be FL?:
FL Flood condition "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore He2Plus 110.47511701 FL Washer F1 code and
Jul 11, 2009 | Kenmore HE2 Plus Front Load Washer
On the gage cluster what does F1 or FI mean
The Fl lamp lights up when the computer finds a malfunction in the programmed Fuel Injection. There are 33 different codes. The offending code is denoted by how many times the Fl light blinks.
Nine of the 33 codes do not show symptoms since the engine still runs okay. If the Fl light just stays on then the engine will not run because the computer will not let it run, (except in two cases).
"MIL" translates as "Malfunction Indicator Lamp ".
This is what the service manual says:
" The PGM-Fl MIL denotes the failure codes ( the number of blinks from 0 to 33 ). When the indicator lights for 1.3 seconds it is equivalent to 10 blinks. For example, a 1.3 second illumination and two blinks ( 0.5 second X 2 ) of the indicator equals 12 blinks. Follow code 12 on page 5-26.
When more than one failure occurs, the MIL shows the blinks in order of the lowest number to the highest number. For example, if the indicator blinks once, then two times, two failures have occurred. Follow codes 1 and 2 on page 5-12."
BOTTOM LINE > A blinking light that can't be understood, combined with instructions that can't be understood make the entire Honda "malfunction alert system" totally worthless and a pain in the neck to the owner. Why can't someone in Japan write a computer program that would render something like " Code 23 error " instead of a blinking light that means nothing because it is not user friendly.
You asked what the FI light means. It means you are forced to take your bike in for service at a Honda shop and pay big bucks to the dealer for something you could have done yourself for $12.00. This is a built-in money maker for Honda dealers.
Please rate this answer. Thanks.
May 16, 2009 | 2001 Honda CBR 929 RR Fireblade
F1fault appearing on dash
The Fl lamp lights up when the computer finds a malfunction in the programmed fuel injection. There are 33 different codes. The offending code is denoted by how many times the Fl light blinks.
Have a drink of Saki and think about THAT for awhile. Then get back to me with the code ( 0 to 33 ) and I can tell you what the code means.
Please rate this answer as four diamonds.
With four diamonds and some Saki I can now rest for awhile.
Apr 06, 2009 | 2000 Honda CBR 600 F(4)Y
Maytag MAH5500B, FL code and door locked.
Check your drain and the drain line all the way to the pump. Here is some info on the F1 code.
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
I received an error on my Kenmore Elite Calypso washer of FL or could be F1 and I did not receive a manual with the washer to look it up. Can you help me fix this? Thank you
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
The problem could be caused by a blocked or bad water pump but also there is a back up valve or flap in the drain assembly that also sticks and some times causes problems with the FL Error code . If you remove the back up valve flap this can some times clear the problem.
There seems to be a lot of problems of this nature with this washer on the web. It seems there is aclass action law suit between the consumer and Whirlpoos/Kenmore. The phone number to call to get more information. 1-877-567-4297. There is also have a website to download the claim form http://calypsosettlement.com. Depending on when you purchased your machine you might be able to file a claim.
also if you don't qualify for that there is a replacement motor that was designed for the unit that works better than the old one but still seems to have trouble occasionally;-
The pump part number of the pump is 8054954. Here's a direct link:
http://www.partselect.com/PartSearchResult.aspx?PartNum=8054954
It's apparently easy to change the motor, so give it a shot. It's cheaper than a new washer (and partselect.com is even cheaper than Sears, who want $120 for a new pump... and another ~$100 to send someone out to install it!!).
Aug 19, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
146 people viewed this question
Dan Webster
Dan Webster
Sal De
