Question about Maytag MER5770 Electric Kitchen Range
I have a maytag range M# MER57700AAW S# 18143682yq After a self clenaing cycle the display read "off" I reset the power to the range now the diplay is blank unless you push a button on the display then it will display "off for a minute or so and then go blank. If the control module is bad this woulld be the second one in as many years is there something else that could be damamging the control module?
  • 2,272 Answers
The control board got overheated in self cleaning cycle which you performed.some times this happens with self cleaning cycle. The control board needs to be replaced.this problem is related to power supply board from where the control board receives power to function.If there is any component in the control board which is getting overheated and making the control board short.It has typo be checked and replaced. but your problem will get solved after control board is replaced. Thanks.Rate the solution and show your appreciation.Keep updated For any further query.
Posted on Jul 03, 2010
Oven does not function after self clean cycle
I can only suggest you call a repairman .many time the self clean melts things .
Sep 15, 2015 | Maytag Kitchen Ranges
How do i start self cleaning oven
To Self-Clean:
1. Press SELF CLEAN to set the clean time to HI (4 hours
30 minutes).
2. Press the TEMP/TIME "+" or "-" keypads to cycle between LO
and HI clean time.
3. Press START.
The oven door will automatically lock. The CLEAN indicator
light will be displayed. The time remaining will also be
displayed.
4. When the self-clean cycle is complete and the oven cools, the
CLEAN indicator light will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth
Remove the broiler pan, grid, cookware and bakeware, all
cooking utensils, oven racks and aluminum foil and, on some
models, the temperature probe from the oven
Dec 07, 2012 | Maytag MGR5751AD Gas Kitchen Range
When trying to use either upper or lower oven, panel flashing "Control Locked." Won't work.
Try this:
ToChangeFactorySetDefaultOptions:
1, Controloptionsmay be changedby se-
LectingtheSetupOptions(0)padandthe
desiredoptionpad.(SeeOptionsbelow.)
2. Currentoptionwillappearin thedisplay.
3. PresstheAUTOSETpadtochangethe
option.
4. PressCANCELpadtosetthe displayed
optionandexittheprogram
The LOCK is option 4 change the OPTION from 4 to 9.
9 is the factory default settings.
This should work. However.... there is the possibility that the unit had performed a self clean function. If you just completed a self clean cycle it can but up to 1 hour AFTER the cycle before you can open the door or use the oven as the range must cool down and cycle a thermostat before it wil work again.
There is also the possibility that the door lock has not completely retracted. If you can get it to start a self clean cycle.... after 1 minute press cancel and the lock should retract. (I know you said won't do anything) I am hoping that after you reset the options from 4 to 9 that you might be able to do this.
Thanks for choosing FixYa,
Kelly
Sep 06, 2011 | Maytag MER6772 Gemini Electric Kitchen...
How does self clean oven work
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Jun 06, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Can not work automatic clean cycle on Maytag range
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
May 05, 2010 | Maytag MER5775Q Electric Kitchen Range
Magtay self cleaning oven. I let it clean and now
Did you interrupt the cleaning cycle if so that is why the error code, or a power failure during the cleaning cycle. You may have to unplug the stove for five minutes and then plug it back up, it should reset.
Nov 05, 2009 | Maytag 30" Self-Cleaning Freestanding...
Maytag gas oven after self-clean cycle door locked "dr" on displa
unplug it and let it stand for a few minutes
let the e- prom clear
plug it back in, should unlock
if it does not you need a new sensor
Sep 27, 2009 | Maytag MGS5770 Gas Kitchen Range
Self-cleaning oven will not start.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
sad
Dec 11, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag slide in range - MES5752BAW - when you press BAKE or BROIL the power cycles off and the number 30 flashes on the display then the power cycles back on and the clock is reset to 12:01.
I had similar issue with my Maytag slide in range MES5552BAB. Pressing Bake or Broil would sporatically cause clock display to go blank, show "30" then reset clock to 12:00. Under warranty, the service technicians replaced the clock unit twice. On last visit the range performed the error while technician present.
The suspected problem is that the clock unit is experiencing high frequency interference.
The proposed solution is to place noise suppressors on L1, L2 and Ground wires at the clock. (Noise suppressor: Ferrite beads, Sears Part #12001500.) Reverse L1 and L2 at the pigtail terminal block.
May 06, 2008 | Kitchen Ranges
Maytag MER5770 Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
