Question about Xerox WorkCentre 4150 Black and White Copier
I need to change my Xerox workcentre 4150 toner cartridge. The old cartridge is stuck and I cannot get it out. Any ideas? Thank you. Russ thornock
    President:
  • 2,072 Answers
You have to twist them clockwise and then counter clockwise. There is a locating pin they stick on in back, All I can say is twist and pull.
You can try opening the right side door and sliding a thin bladed screwdriver in there to assist in lostening it .
That is not uncommon and is frustraiting.
Posted on Jul 09, 2010
Code 09-700 xerox 4150
09-700 Toner Supplying Error RAP
The toner module has stopped supplying toner to the xerographic module.
Procedure
WARNING
Switch off the electricity to the machine. Disconnect the power cord from the customer
supply while performing tasks that do not need electricity. Electricity can cause death or
injury. Moving parts can cause injury.
1. Check that the tape seal has been removed from the xerographic module, PL 9.10 Item 1.
2. Remove the toner module, PL 9.10 Item 2. Check that the locking lever opens and closes
the toner shutter.
3. Install new components as necessary:
• Toner module, PL 9.10 Item 2.
• Xerographic module, PL 9.10 Item 1.
Jul 27, 2011 | Xerox WorkCentre 4150 Black and White...
How do I change the toner cartridge on a 4150 workcentre. Where is it?
Open the front access cover and find the toner cartridge unit on the left, next to the drum. Unlatch it and slide out the toner.
See the attached diagram
Nov 17, 2010 | Xerox WorkCentre 4150 Black and White...
I need to know what the part number is for the maintenance kit for work centre 4150
Here is a link to all the available parts and supplies for the Xerox 4150. This includes part number, yields and even pictures.
http://www.precisionroller.com/search.php?q=xerox+4150
Good Luck and Thank You for using Fixya.
Oct 12, 2010 | Xerox WorkCentre 4150 Black and White...
I have a Xerox 4150 printer, I install a new cartridge and get a message,"The toner cartridge is not for this machice, install the correct cartridge", I also want to add that want I took out the toner...
There are a couple of different cartridges for those machines. One is a "sold" the other "metered" if the cartridge part number is different it will give you that message.
Also remove the cartridge and shine a falshlight into the machine . Look all the way to the back and locate the springs, they make contact with the cartridge. Try gently stretching them to see if they area making good contact.
Feb 07, 2010 | Xerox WorkCentre 4150 All-In-One Laser...
Xerox workcentre 4150 printer cartridge not installed correctly
i'm going to try to explain this in english even tought is not my native language, i had the same problem with my xerox 4150, when i bought a new cartridge it worked perfectly but at some point it stoped working, and it says in the screen something like "remove toner cartridge and reinstall", the problem was that the chip (is like a sticker under the toner) was in bad position from factory, a men who worked in xerox told me that there was a lot of toner cartridge that came with this problem, and this chip is ultrasonic or something like that because it never make contact with the printer circuit, so the fact is that you only have to remove and re-paste the chip in the correct position, but you have to do it several times until it works, that's how i repaired it...
Aug 26, 2009 | Xerox Office Equipment & Supplies
I am using the workcentre and it says toner supply failed
You wont find any tape on the cartridge. There is none. That is an improper message. It is possible the ink cartridge will solve it, but it is more likely that one of the springs located in the copier where the back of the toner cartridge inserts is bent and not making proper contact with the toner cartridge. I have seen that cause that very problem several times.
Because you are receiving that message about the tape. That strongly suggests that you need to have the machine firmware updated to the current version. Sound like the machine you have has an older version of the machine firmware.
You can find the firmware and installation instructions at Xerox.com. It will be under Drivers and Downloads.
May 29, 2009 | Xerox WorkCentre 4150 Black and White...
Toner installation error
take it out and try again, there are often adhesive tabs protecting certain areas of cartridges, that need to be removed, and that are not obvious
Not a guarantee, just something to try
Sep 09, 2008 | Xerox WorkCentre 4150 All-In-One Laser...
SMART KIT DRUM CARTRIDGE
Call 1-800-821-2797. Thats a machine software issue..
Here is the note on it.
Problem:
The DRUM and TONER cartridges are not installed correctly. Web page indicates replace %0 empty cartridges. The Machine doesn't copy. Cause:
Firmware and work-process problem. . Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Don t worry about cartridges. They are safe. Upgrade firmware. The message goes away and machine copies
Mar 07, 2008 | Xerox WorkCentre 4150 All-In-One Laser...
Toner Cartridge
CHANGE THE DEVELOPER IT HAS OLD,AND ALSO CHECK THE DRUM
Sep 20, 2007 | Xerox WorkCentre XD155DF Laser Printer
Xerox WorkCentre 4150 Black and White Copier Logo
184 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
