Question about NexxTech N600D DVD Player
Invalid id key
I have a NexTech DVD player. I don't know at the moment the model number, but I bought it about 2 years ago from "The Source" (aka Radio Shack) in Canada.
The player is connected to a Sony Bravia 32" TV.
I recently borrowed a movie DVD from the library here in Canada. When I try to play it, a message is displayed:
"Invalid ID Key"
There is no audio content other than the music. Everytime I press the "Audio" button on the player's remote, I get the same message.
I have no idea what this means, or what to do about.
2 Suggested Answers
  • 53 Answers
SOURCE: Nextech N600 DVD player problem
You may have connected one of the component outputs (usually colored red, green, and blue) of your DVD player to the composite input of your TV. Connect yellow to yellow. See section 3.2 for hookup details. Also, if you've hooked up component video, check the three cables to make sure one of them hasn't become disconnected or developed a short and that they are connected in the correct order. If you use an s-video connection, the chroma wire maybe broken -- try a different cable or try the composite connection.
If you live in a PAL country (most countries outside of the U.S., Canada, and Japan) you may be playing an NTSC disc in a PAL player, but your PAL TV can't handle the signal. If your player has a switch or on-screen setting to select the output format for NTSC discs, choosing PAL (60 Hz) should solve the problem. See section 1.19 for more information.
Posted on May 03, 2008
Where can I purchase a REMOTE for the Durabrand 1002 DVD Player?
Durabrand is a possible source but also one of several online vendors of OEM remotes.
Oct 28, 2014 | Durabrand DVD-1002 DVD Player
I want to change region on my dvd Coby 209 -what do I do to achieve the goal ?
Thankfully you asked it new. fixya has changed since i was last here about 4 years ago and trying to figure out how to add the 2 new ways to my old post has been annoying. It appears they changed it so the old way only works on the older versions. Heres the new ones tht should work:
1) Open DVD Tray
2) Press "MENU"
3) Press 8888 (you will find the modification interface)
4) Press "OSD"
5) Enter YOUR desire region code number 0-6.
6) Insert your Movie Disc.
OR if above doesnt work try:
1) Open Disc tray
2) Enter: 9735
3)From the internal menu one of the items on the menu is region
code. Click on it and change (zero is best then any disk will play)
While entering 9735 you may see "INVALID KEY" on the TV, just ignore it and
keep typing.
Hope it helps :)
Jul 01, 2012 | Coby DVD-209
Hello, I have jusy bought a HTS3011 home theatre system, but I had try to play a lot of dvd s, and I had an error related to the disc regionin the most part of the discs I tried. Can someone help me? As I...
Hello Patricia -
Please follow the instructions below for unlocking your Philips HTS3011
1. Switch on the DVD player
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the DVD player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Regards,
BElectric
May 01, 2011 | Televison & Video
Need the car adaptor for this model CyberHome CH-LDV712. Radio Shack said it is a 10 Volt and they do not carry it.
Reading from the tag attached to my original CyberHome car adaptor included with the CH-LDV712:
Input: 12 VDC
Output: DC 9V = 2.2 A
Model #: SEG-018
I don't know where the Radio Shack guy gets 10VDC from.
Aug 18, 2010 | Cyberhome CH-LDV 712 Portable DVD Player
I bought this Centrios recordable DVD player; model #1611305 five years ago at the Radio shack store in Ottawa. now it can not open & inject the window. can any body help me out. Thank you very much.
hello,
the disc tray is operated by a mechanism inside the player, the problem would be that it is old and weak and cannot perform its functions anymore.
all you have to do is open the dvd player, gently unscrew the mechanism and replace it with a similar mechanism.
goodluck.
Feb 04, 2010 | Centrios EDW8020 DVD Recorder
Dear Sirs, I have a Venturer Portable DVD Player model number PVS11022 which was bought for me about 3 years ago. The player still works in the car but I have lost the mains adaptor which is a DC in 9v-...
Radio Shack or a similar type of electronics store , carry a multi use power adapter 9 to 12 volt 1.5 amp with the correct fitting included for about $25.00 U.S. We bought one for our Venturer PVS 11022 and it works very well.
Aug 16, 2009 | Televison & Video
Need code remote...clarion model zv-5100n-a
i have the same dvd player for my pathfinder and was able to get my universal remote that i bought from radio shack to work. its a kameleon 8 in 1 model number 15-2137 its pretty bulky but it works.
i have a question, do you know if the dvd player works with wireless headphones?
Aug 09, 2009 | Clarion Car Audio & Video
NexxTech N600D DVD Player Logo
94 people viewed this question
Top NexxTech Televison & Video Experts
jasbo
jasbo
Computer Repairing
Computer Repairing
Tygh Duval
Tygh Duval
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
