Question about Kenmore HE2 Plus Front Load Washer
Kenmore he2Plus washing machine power button does not work. How do I turn on my machine.
  • 883 Answers
SOURCE: washing machine will not run
main control board has expired-replace it
Posted on May 28, 2007
SOURCE: Kenmore HE2plus wont spin...F-21 error
Apparantly the F21 error means there is a drain problem...I removed the drain hose from the output in the wall and held it down at ground level and let it drain into a pot...I ran the rinse, drain and spin cycle while I did this but before I hit the start button I hit the 2nd rinse button to turn off the rinse portion of the cycle. It seems to be draining fine now.
Posted on Jul 02, 2008
  • 382 Answers
SOURCE: kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Posted on Dec 16, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Kenmore Calypso washing machine has is
Where the power cord goes into the washer is a small box called a line filter. It is there to protect the electronics in the control. It might be that the line voltage filter has failed. Remove the rear panel on the control to access it. Calypso Service Manual
Posted on Jul 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: f21 error on kenmore he2plus washmachine
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
Kenmore he2plus what's troublecode f-21
F21 on the tech sheet says Long Drain If the drain time exceeds 8 minutes the water valve turns off.
NOTE: After 4 mins the "Sd" error will be displayed then 4 mins later the f/21 error code will be displayed.
Press Stop two times to clear the display.
(Solutions:) Check drain hose
unplug washer and check electrical connections at pump
Check filter for foreign objects
If these fail it says to replace pump.
Dec 11, 2011 | Kenmore Washing Machines
Kenmore HE2Plus White Front Loader. Drain pump seems weak, wet clothes, and f-21 flashing..???
Hello & Welcome to FixYa
F21 error code is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer (HE2Plus)
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore (HE2PLUS) front-loading washer leaking out the front door,,,,,,,,C. Pellecer
check the inner door seal it may be damaged that may be why it is leaking
Kenmore He2Plus Washer: Controls Locked button lites up & beeps
plug it back in and there should be a buttong somwhere toward the corner and in small lettering"un-lock/lock" hold that button for 5 secs and see if it un-locks the board. if it dont the your board might be bad....hopefully this helps
Jul 30, 2009 | Washing Machines
What is code f21 on kenmore he2plus washer and how do i fix it
It means you have a drain problem. It could be a pressure switch or the drain filter plugged.
Jul 14, 2009 | Kenmore HE2 Plus Front Load Washer
Jul 01, 2008 | Washing Machines
Kenmore front load washer he2plus
My HE2 Plus vibrates terrible. Moves all over the place. Anyone else with this problem
Jan 24, 2008 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
132 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
