Hi there! i have a problem with my cd player where
Hi there! i have a problem with my cd player where the sliding cd cover is movibg slow and where I have to help opening. Is it possible to "lubricate" is somewhere or do I have to do someting else? where do I open to see what and where is causing the problem. I do not have any repair manual and I do not want to destroy my fine peice of hardware. can anyone help me "the big Dane"?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
Some models use drive belts to control the trays and drawers. Check to see if you have a loose belt. Take the bottom and top cover off if possible to see whats happening or not happening.
Posted on Jul 03, 2010
How to remove cover from Yahama CD Changer #805
There's normally small screws around the back and side edges of the lid. Make sure they are all undone. Then, gently prise the side panels apart but 1/4" (5~6mm) just to release the tension. The lid should then be free to either slide or tilt off.
Aug 31, 2014 | Audio Players & Recorders
How I change the batteries ?
hi,
do the following
1. Carefully turn your system upside down.
2. Locate the battery compartment on the bottom
3. Press the arrow on the cover to slide the compartment open.
4. Match the large (-) terminal on the battery to the small terminal on the clip (which lifts out
of the compartment for easier connection).
5. Snap the terminals together firmly.
6. Slide the cover closed.
Use a standard 9V battery (IEC 6F22 in Europe), available at most retail stores. Use an
Dec 20, 2010 | Bose & Wave& Music System
Hold on and off is not working
Hold switch operates by sliding its cover little bit and if you slide cover all the way, usb port will pop out.
Slide cover few times that might fix stuck hold switch inside.
Hop this info will help you.
Thanks
Nov 24, 2010 | Sony Walkman Bean NW-E305 MP3 Player
Cd no run
is eject / insert cd function. is disk clean and work in other player? next is to open upper cover and clean optical lens area including the lens itself you can clean that using cotton badge. slow not to miss align that lens.
Apr 14, 2010 | JVC KW-XC770 CD / Cassette Player
CD/DVD drawer won't open so CD stuck inside :(
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
TABLE ERROR SHOWS IN WINDOW
What probably happened is that some CDs fell off their tracks and are blocking the main wheelhouse from turning. To solve this you will need a philips head screw driver. First unplug the machine. You will need to remove the top of the unit (which slides off towards to the back) after removing the 9 screws (2 top, 4 side, and 3 top back). Once you slide off the cover, you will expose the wheelhouse and you should see the CDs that fell off. Simply take the cds out. Once you have taken out all the CD that came off the tracks, slide the cover back on and screw in the 9 screws. The CD player should work again. This worked for me and hopefully will work for anyone encountering this error.
Dec 01, 2009 | Sony CDP-CX300 CD Player
There is a disc jammed in my cd player and the tray sometimes opens and closes but wont bring the disc out
Hi
Thanks for using FixYa. Locate your CD player’s manual Eject button. It is usually a small hole located underneath the CD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the CD and see if there is a problem with it. Most CD player drawers get stuck when a CD is warped or the label is starting to peel. If the CD is warped, discard it. If the label is peeling, remove the label.
To open the CD player top to remove the cd/CD manually--
  • Unplug the CD player and take the outer casing of the CD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Locate the disc loader cover. The disc loader cover is located where the extending CD tray finally comes to rest within the CD player. It’s the part that holds the CD loader in place.
  • Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
Points to remember while performing above steps---
 Before you remove the CD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
 Use the opportunity while you have the outer casing off to clean the lens of your CD player.
 Never work on an electrical device that's still plugged in.
 Opening a CD player may negate the warranty. Read your warranty carefully before you proceed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 18, 2009 | GPX KC318S CD Player
Cd cover doesn't open
Fiddled with it, looked at hinges to figure direction should open and pulled it slowly open. Button doesn't work but I can open/close unit. Just flips up from the front edge, doens't slide back or anything.
May 13, 2009 | Sharper Image GM402 CD Shelf System
Top popped off.
I just removed the cover from my wave radio. There are 3 screws that hold the top cover on. Two are exposed and in the rear of the unit and the other is under the CD player lid.
To replace the cover find the two tabs in the front on the bottom cover. Slide the top on and using a screwdriver carefully pry back the front of the top cover so that the two tabs slip by and move into place. Then open up the CD player cover and make sure the spindle fits through the hole in the top cover. Push down and replace the screws.
I didnt remove the ribbon cable so you will have to check on how to refit the connector.
Apr 07, 2008 | Bose Wave Radio
51 people viewed this question
 Grubhead
Grubhead
