Question about DeLonghi DE400P Dehumidifier
Have a Delonghi DE 400P Dehumidifier which does not collect any water. The fan and compressor is running and has been running for almost two days now. The filter is clean. It worked fine in May but the humidity has gotten up to 70 and the setting is 55. That is the setting we have always used. Has worked fine over the last three years until now. Help. Richard E Parker dparker1002@yahoo.com
    President:
  • 1,070 Answers
Welcome to FixYa
Dehumidifiers collect the water that has been removed from the air in a collection tank located at the bottom of the unit. The tank should be emptied regularly to avoid spilling. Empty the tank before the water level gets too high. Some dehumidifiers feature a continuous drain capability that allows you as the user to install a drain hose onto the unit that will direct the water to a floor drain so you will never have to empty the accumulation tank.
Not Collecting Water:
  • Check the number on the "Room" humidity display. If the number is less than the "Set Humidity" number, the machine is not drawing moisture out of the air. The dehumidifier is functioning normally.
  • Increase the "Set Humidity" number by pressing the "+" button. The higher the setting, the more water the unit will draw into the water-collection bucket.
  • Turn off the power and pull the filter out of the right side of the dehumidifier. Clean the filter in warm, soapy water, shake it dry and place it back in the dehumidifier. If the filter is clogged with dust, dirt and debris, air will not flow through the machine.
Start the unit on the lower fan setting, at a humidity level of around 60%.Then adjust the humidity level to normally use it.
After vacuumed the filter-not work-use fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in till completely dry.
You may also Refer this Instruction Here
I hope you got an idea...thanks for Contacting FIxYa...
Posted on Jul 03, 2010
I have a De Longhi de500p. Runs and I can hear the compressor kicking on and run. But I am not getting any water in the tank. Room temp 75 degree and humid meter set at 40 .Please give me some advice
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 31, 2011 | DeLonghi DE500P Dehumidifier
De Longhi dehumidifier DD40P Not collecting water.
heatman101
Jul 27, 2011 | DeLonghi Dehumidifiers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Pressure relief tube behind the collection tank ?? should it point up or down?? model DH 400P
Down. If it's pointing up ans was activated, water could go into parts of the unit, where it doesn't belong.
Jun 08, 2011 | DeLonghi DE400 Dehumidifier
Fan working but not compressor. Had been making noise when compressor on but now just fan working
heatman101
Oct 06, 2010 | DeLonghi Dehumidifiers
I have a DeLonghi dehumidifier Model DN 40G. The fan runs but the cooling fins do not get cold. It sounds like the compressor is running because I hear it click on and off. The fins do not even get moist....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 08, 2010 | DeLonghi Dehumidifiers
My delonghi DN40G can not hear the compressor kick in
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 20, 2010 | DeLonghi DN40G Dehumidifier
COMPRESSOR DOES NOT TURN ON I HERE THE FAN AND LOW TEMPLIGHT COMES ON. DELONGHI DEHUMIDFIER MODLE NUMBER DH90U
heatman101
Feb 22, 2010 | DeLonghi DH90U Dehumidifier
I have a DE 500p it runs but does not collect water
heatman101
Jun 24, 2009 | DeLonghi DE500P Dehumidifier Dehumidifier
Dehumidifiers Logo
352 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
