Question about HP Pavilion dv4000 Notebook
I want to connect my laptop with computer, i am using s.video cable but not a good cleararity. so getting a good clearity which cable i have to use. there is a 15 pin female socket in my laptop, so i can use that port ?
    Scholar:
  • 166 Answers
Please use a normal monitor/VGA cable .... If you have a DVI output in both your laptop and desktop which is white in color and has 29 pins... that would be great and the best one is HDMI which is black in color and has 29 pins ... the best quality you can ask for
Posted on Jul 03, 2010
There is no color when playing games
If you are using the RCA out puts one of your connections is probably bad. I could just be loose or the wire could be broken. If you are using HDMI make sure the plug is lugged STRAIGHT in and not at an angle and fully plugged in. The color components are on different pins so all must me fully in contact at both ends of the cable. Same for VGA, make sure ALL pin have full contact.
If you get colors otherwise but not during games them you may have color depth issue with your monitor but I doubt that since that is usually detected automatically.
Mar 28, 2015 | Microsoft Xbox 360 Console
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
Nov 22, 2009 | Dell Latitude D600 Notebook
Connect to a tube TV
hi mr. pavilion dv6700z. i have the same problem before but after i tried and use my genius mind. i made it. and the television is working in my laptop as a external monitor. pixel is good. just connect in card video out to video iput to television. romsky79@yahoo.com.
Jun 06, 2009 | HP Pavilion DV6700Z Notebook
Cemara clearity
Try adjusting the lens, the circular knob around the actual glass, rotate it left or right and see if that clears up your image
Jan 08, 2009 | A4tech Xmaster PK-835 Webcam
Webcam has no clearity & live continuously
the ring aroubd your camera lens is a focuser, twist it till is clear.
Sep 03, 2008 | Creative Labs WebCam Live!
L6 and contacts
L6 must be cool bcoz i gives more clearity
May 28, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Problem downloading picts.
you can get a memory card reader at any walmart or wolf camera and you can tfer the pictures that way. your data connection or cable might be having a problem. you can pick up the card reader for around 15 off ebay maybe cheaper. hope this helps
Apr 30, 2008 | Casio Exilim EX-Z500 Digital Camera
DVD from laptop to computer
MaionP:
you need to connect your TV to your laptop with the audio cable as well. A simple S video cable will only gives you video. You can buy a simply audio video cable and use the audio output from your laptop to your TV and keep on using the S video for video.
Or you can use simple external laptop speakers to gives you sound with your TV output.
Hope that helped!
Dec 09, 2007 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
