Question about Samsung Cameras
Manual for samsung es65 camera I would like to view my pictures on my samsung TV I was told I could do this direct from the camera to the TV just by using the a/v cable Is this correct and if so what ports on the tv do I plug the white and yellow post intoé
    Guru:
  • Samsung Master
  • 1,705 Answers
You can download a user manual from here:-
http://downloadcenter.samsung.com/content/UM/201002/20100202195655453/ES65_ES67_English.pdf
You should have a AV cable with the camera, that has 1 round plug at one end and 3 round plugs at the other.
The single end plugs into your camera, there is a socket on the side marked AV. The three plugs at the other end go intot the TV.
They are colour coded (White - audio left, Yellow - Video and Red - Audio right) you need to find three sockets on your TV which match. Once connected and a slide show running on your camera, select one of the AV tv channels on your tv remote control.
If there isn't the 3 colour coded sockets on your TV, there probably is a couple of SCART connectors on the back (Big black socket with about 20 holes) You can buy adaptors, from electrical stores, which convert your AV cable out to a scart. Its just a box with the 3 coloured inputs and a scart output.
Posted on Jul 03, 2010
ES65 restore firmware
Perhaps you still remember the add from IBM. Where the son says, or we put in the power plug!!! There are more errors with portable equipment caused by empty batteries than all other causes together.
Please remove the battery and charge the battery, before placing it back. And even when the charger indicates the battery is full, it is no 100 % guaranty it is. Even almost new batteries, can lose capacity within minutes. Those are defect and most of the time not to recover.
Be aware, to change firmware, if it should be available, you need a working camera. And a fully charged battery, because if during the update the battery runs out of power, your camera won't work again, without an intervention of the repair shop.
Make it a habit to charge the batterie at least every 3 months, even if you don't use the camera for a longer period.
Jan 03, 2014 | Samsung ES65 Digital Camera
ENABLE TO SHOOT THE PICTURE
Try turning on the camera. :P
Oct 17, 2013 | Samsung ES65 Digital Camera
OPERATING MANUAL SAMSUNG ES65
You may download a copy of the ES65 manual from here.
Mar 31, 2013 | Samsung ES65 Digital Camera
Need a samsung digital camera es65 installer download
You don't need to install any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 01, 2012 | Cameras
When i open my camera. icant find the dcim folder and i cant view my pictures
If you are trying to view on a computer then you will need to download and install the correct drivers on the computer for the camera.
Oct 05, 2012 | Samsung Es65 10 2mp 2 5 Lcd 5x Optical 4x...
Need print off manual for es65
Hello Mrs L Poole,
Download the manual here in pdf.Also,here are some video tutorials on the camera that you may find useful.
Hope this helps.Thanks1
Please rate this answer.
Dec 15, 2011 | Zeikos Samsung ES65 Digital Camera...
I need a Samsung ES65P user manuel sent to me Please to Gordon Glover Apt. 306-2770 Aquitaine Ave. Mississauga Ontario Canada L5N3K5 Phone # 905-814-0348 Thanks
I can't mail you one but I do have the link to the full english owners manual.
I hope this helps!
May 03, 2011 | Cameras
My samsung 5x camerae ES65 HAD A LITTLE WATER INTO THE CAMERA HOWDOIFIX IT?
HI there remove the battery compartment then shake the camera little bit & put it in a sunlight. Make sure the camera is dry. Don't use blower or any other heating process. After that use it. Thanks.
Dec 20, 2010 | Samsung Cameras
My Samsung es 65 digital camera's LCD blacked out after charging. What could be wrong?
What a misery! You are using your cell phone every day,
pushing it in your pockets, swapping your bags, content and purses and for
years it will do just everything you like or what it is designed for. Probably
product testing makes this item fit for such actions.
Samsung cameras react quiet a bit different! Treat them with
outmost respect and fragility and a month after purchase the LCD screen will
quit. Samsung explains that mistreatment would be the cause of it and the cost
of repair would amount to near the purchasing cost of the item! Google the
internet for "Samsung LCD screen not working" to make up your mind.
Samsungs whole product line seems to be crashing out on the
same issue. Is it worth to loose your money for bad product design?
Dec 18, 2010 | Samsung Battery Battery Charger for BP70A...
Cameras Logo
503 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
